Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Mastertools
Old 04-24-2012, 03:43   #76 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Originally Posted by laptop.dz View Post
How can I fix this arror each time i run mastertool exe file this one appears
install it
dotnetfx35
MasterTools Team
Old 04-24-2012, 10:21   #77 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
Celkon c770i flash file
CELKON C770I FLASH FILE READ BY MASTER BOX
B.R.,
B.Uttam
The Following 2 Users Say Thank You to uttam4u2002 For This Useful Post:
Old 04-24-2012, 11:52   #78 (permalink)
sabby_singh's Avatar
Member: 100376
Sonork: 100.1591842
Yxtel c6 flashed successfully & no restart after flashing THOUGH IT WAS SHOWING SOME ERRORS BUT FLASHING SUCCESSFUL
Old 04-24-2012, 13:16   #79 (permalink)
niloy2007's Avatar
Member: 1426012
Sonork: ICQ#618627674
City-call m73_6252-cpu succ....
Uploaded with ImageShack.us
Old 04-25-2012, 12:47   #80 (permalink)
Member: 834813
Microsoft .Net Framework
Originally Posted by Roni2000 View Post
install it
dotnetfx35
MasterTools Team
Thank you for reply , i did install dotnetfx35 (it was already installed) but always the same error , even i tried in another pc.
here the message that appears when i run master tool exe file :
Unhandled exception has occurred in your application.
if you click Continue, the application will ignore this error and attempt to continue
if you click Quit, the application will close immediately.
input string was not in a correct format
thanks again.
Old 04-25-2012, 15:10   #81 (permalink)
Azam Pathan's Avatar
Member: 840953
Sonork: 100.1602229
thanks again.
100% netfirmware problem bro
1) Goto control panel
2) Goto addremove program
3) Remove all netfirmware file
4) uninstall mastertool
5) delit mastertools folder in C/program/mastertools
then restart you PC
now install all netfirmware file
then install mastertools setup
restart PC
your problem will be solved
Pathanazam
Old 04-25-2012, 15:11   #82 (permalink)
Member: 936020
Sonork: 100.1611462
contact with me i will try to fix it
Old 04-26-2012, 08:21   #83 (permalink)
yasintaj's Avatar
Member: 771334
master box latest setup
MasterBox_V3.3.1.945 master box latest setup
Old 04-26-2012, 08:49   #84 (permalink)
yasintaj's Avatar
Member: 771334
i need downlod linck ...................................i need downlod linck ........
Old 04-26-2012, 12:23   #85 (permalink)
Member: 834813
Re
then restart you PC
restart PC
Pathanazam
Thanks bro, I'll try that and post the result.
Old 04-26-2012, 12:30   #86 (permalink)
Member: 834813
Re
Thank u Roni2000 , I'll contact you if it doesn't fixed by the way of what ajuu53 said.
Old 04-26-2012, 12:43   #87 (permalink)
Member: 523972
Sonork: 100.1596548
Don't Forget to Install dotnetfx35 (231 MB Size). Other All Net Framework & necessary Files (dotNetFx40_Full_x86_x64,vcredist_x86,wic_x86_enu, WindowsInstaller-KB893803-v2-x86) Added in main Full setup.
B.R.,
B.Uttam
Old 04-26-2012, 23:05   #88 (permalink)
Member: 834813
Matertools last update
.... Here it is ....
Old 04-27-2012, 02:35   #89 (permalink)
Member: 834813
Re
B.R.,
B.Uttam
I followed all the steps in my laptop and in pc-home (home computer) but always the same message appears even with the latest update .
Here's the pic : (please , copy & past the url as i couldn't upload it in gsmhosting)
http://i44.*******.com/u/f44/12/34/88/31/master11.jpg
******* = s e r v i m g
Regards.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.49713 seconds with 12 queries
