Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Mastertools
Old 07-20-2012, 09:53   #1 (permalink)
Member: 725038
Sonork: 100.1613635
rokea r9010 not canect
rokea r9010 phon is not canect .....
spd6600h cpu ....
http://img835.imageshack.us/img835/3919/73993609.png
Tring to find PinOut
Please waiting ......
Fail to Find PinOut !
Be sure Keep press power on key while Pinfinder working.
Be sure use Box's power wire to supply your Mobile.
Click 'Reset' then try again.
Or Manual set PinOut.
If you Manual set PinOut.You must manual set Port CPU and Flash type etc.Attemp to connect 1st.Attempt to connect is failed.
Attemp to connect 2nd.Attempt to connect is failed.
Connect fail.
Old 07-20-2012, 10:24   #2 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
use pinfinder
check usb port
Old 07-20-2012, 10:29   #3 (permalink)
Member: 725038
Sonork: 100.1613635
halo sir ...only rx and tx ya all pin lagana he
Old 07-20-2012, 12:27   #4 (permalink)
Azam Pathan's Avatar
Member: 840953
Sonork: 100.1602229
on board GND RX TX use three cable sold and open pin finder select spd tab and search with com
with usb cable connect handset open pin finder and search with both option usb and com
azam pathan
The Following User Says Thank You to Azam Pathan For This Useful Post:
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
hope it is not too comercial aleksj Wanted Products 0 06-12-2000 13:22
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 03-02-2000 21:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-26-2000 13:31
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.31785 seconds with 11 queries
