05-25-2011, 18:02 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Brasil: MS Pantanal Age: 38
Member: 65397 Status: Offline Thanks Meter: 19 | Semp Toshiba CT65 bin? Please I'm looking, the firmware for a phone Semp Toshiba CT65. the processor he has MTK6229 , I've managed to do via masterbox format, but after a few hours it comes back the same defective lock on the home screen. Does anyone in the forum would have the firmware of this device working properly? thanks |
05-25-2011, 18:19 | #2 (permalink) |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | Hi, what problem in your phone and how you repair it please post screen shot and log phone picture too then we can help you |
05-25-2011, 19:32 | #3 (permalink) |
Member: 65397 Status: Offline Thanks Meter: 19 | this log: Now press Power-on button of the mobile BBCHIP: "MT6229_S02", EXT_26 CODE(0x6229), VER(0x8A02), SW(0x8A02) NOR_DETECTION: "S_DA_NOR_FLASH_NOT_FOUND"(3011) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 0Mb (0x00000000) NAND_DETECTION: "S_DONE"(0) NAND_ID: "[HYNIX] HY27XA081G1M" NAND_ID: 0x00AD, 0x0079, 0x00A5, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 1Gb (0x08000000) NAND_INFO: (512+16), 32 pages/block, 8 bits I/O, 4 addr cycles EXT_RAM_DETECTION: "S_DA_DEVICE_NOT_FOUND"(3008) EXT_RAM_TYPE: "Unknown" EXT_RAM_CHIPSEL: "CS0" EXT_RAM_SIZE: 0Kb (0x00000000) INT_SRAM_DETECTION: "S_DONE"(0) INT_SRAM_SIZE: 1Mb (0x00020000) Nand flash now, Please power on the moblie again. BBCHIP: "MT6229_S02", EXT_26 CODE(0x6229), VER(0x8A02), SW(0x8A02) NOR_DETECTION: "S_DA_NOR_FLASH_NOT_FOUND"(3011) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 0Mb (0x00000000) NAND_DETECTION: "S_DONE"(0) NAND_ID: "[HYNIX] HY27XA081G1M" NAND_ID: 0x00AD, 0x0079, 0x00A5, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 1Gb (0x08000000) NAND_INFO: (512+16), 32 pages/block, 8 bits I/O, 4 addr cycles EXT_RAM_DETECTION: "S_DA_DEVICE_NOT_FOUND"(3008) EXT_RAM_TYPE: "Unknown" EXT_RAM_CHIPSEL: "CS0" EXT_RAM_SIZE: 0Kb (0x00000000) INT_SRAM_DETECTION: "S_DONE"(0) INT_SRAM_SIZE: 1Mb (0x00020000) Reading phone info... Reading Flash Successfully! MT6229_S02.MAUI_07A_W07_28_MP_V22_F1.BIN |
05-25-2011, 19:34 | #4 (permalink) |
Member: 65397 Status: Offline Thanks Meter: 19 | The phone is locked in the home screen. After a format, it goes back to work. But after a few hours back on the home screen is slow resetting. |
05-25-2011, 20:10 | #5 (permalink) | |
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | your phone have hardware problem just replace its touch glass it will work fine. Quote:
05-25-2011, 20:34 | #6 (permalink) |
Member: 65397 Status: Offline Thanks Meter: 19 | Works 100% touch screen. 1 dead phone home screen, Semp Toshiba logo 2 masterbox format, 100% functional, phone work 3 is a matter of time, cell again becomes locked screen Semp Toshiba |
05-25-2011, 20:59 | #7 (permalink) |
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | ok, do you have its flash file readed from good working phone? if ye then flas it with good file. if not then we will try to provide you flash file |
05-25-2011, 21:17 | #9 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Quote:
Code: Now press Power-on button of the mobile BBCHIP: "MT6229_S02", EXT_26 CODE(0x6229), VER(0x8A02), SW(0x8A02) NOR_DETECTION: "S_DA_NOR_FLASH_NOT_FOUND"(3011) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 0Mb (0x00000000) NAND_DETECTION: "S_DONE"(0) NAND_ID: "[HYNIX] HY27XA081G1M" NAND_ID: 0x00AD, 0x0079, 0x00A5, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 1Gb (0x08000000) NAND_INFO: (512+16), 32 pages/block, 8 bits I/O, 4 addr cycles EXT_RAM_DETECTION: "S_DA_DEVICE_NOT_FOUND"(3008) EXT_RAM_TYPE: "Unknown" EXT_RAM_CHIPSEL: "CS0" EXT_RAM_SIZE: 0Kb (0x00000000) INT_SRAM_DETECTION: "S_DONE"(0) INT_SRAM_SIZE: 1Mb (0x00020000) Nand flash now, Please power on the moblie again. BBCHIP: "MT6229_S02", EXT_26 CODE(0x6229), VER(0x8A02), SW(0x8A02) NOR_DETECTION: "S_DA_NOR_FLASH_NOT_FOUND"(3011) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 0Mb (0x00000000) NAND_DETECTION: "S_DONE"(0) NAND_ID: "[HYNIX] HY27XA081G1M" NAND_ID: 0x00AD, 0x0079, 0x00A5, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 1Gb (0x08000000) NAND_INFO: (512+16), 32 pages/block, 8 bits I/O, 4 addr cycles EXT_RAM_DETECTION: "S_DA_DEVICE_NOT_FOUND"(3008) EXT_RAM_TYPE: "Unknown" EXT_RAM_CHIPSEL: "CS0" EXT_RAM_SIZE: 0Kb (0x00000000) INT_SRAM_DETECTION: "S_DONE"(0) INT_SRAM_SIZE: 1Mb (0x00020000) Reading flash Reading Flash Successfully! Code: Estou enviando para o servidor :D | |
05-25-2011, 22:12 | #10 (permalink) |
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Semp Toshiba CT65 bin? MT6229_S02.MAUI_07A_W07_28_MP_V22_F1.BIN |
The Following User Says Thank You to LuisinhoCell For This Useful Post: |
F_loaders.bin and Boot.bin .. . | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-29-2001 14:49 |
Change Bin-file? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-24-2000 17:02 |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
Bin files to 6150 | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 12-20-1999 14:08 |
Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-20-1999 16:56 |
