Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Mastertools
Old 05-21-2012, 19:10   #1 (permalink)
Member: 835033
Sonork: luca
Some thing new may be for me in Masterboxtool
Hi mates,I found some thing in masterbox but may be it is new for me,
In masterbox there is cable which has no sticker like others as Ms L5+L10E and it has catted,there you can see ten wires.I try to use this cable Mediatek CPU 6252 and 53 after having a problem to format,repair same imei problem on Mediak,at first I face problem cause of connection fail even if after found pinout,But through this no need to find pinout,
open phone,get Pcb see TX and RX connect wires to the poin,
connect that cable to main cable from masterbox,
start Operation as read ifo,after that you can do job for easier and you can save your time.
For me I found TX and RX for L5A+L10E is red wire and arange,
for L8A+L10C is blue and green,
For most of these mediatek are using these usb port,
I am trying to find other port like Ms L12C.
Thanx for all members.
The Following 4 Users Say Thank You to magucha For This Useful Post:
Old 05-22-2012, 06:01   #2 (permalink)
Member: 1030392
Sonork: 100.92089
thanks you to share with us your experince and help all MASTERBOX user .
but i have a question, i want know what kind of problem you have when format 6252 , i want know clear what happen and can help you to fix it without open your phone and solder the external wire .
Old 05-22-2012, 13:50   #3 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
it is very good procedure and also not work only with 6252 cpu but also can work with all mtk some time u need to do this with china mobile in many cases damage connector,not finding pinouts etc
i make more simple for u that even u sold rx and tx and not found pinouts it is more easy and staible method with master box
just use cables which have 4 wires
in my case i use msl4a(ear phone) as u said
Red =RX,
Orange=TX
Gnd=BLACK
Brown=VCC
just sold red cable to rx and and orange to tx now open pinfinder of master box from pinfinder manually select
3=TX 4=RX
now press confirm button and do wht u want
no need to scan when ever u try to find pinouts from the pcb .this procedure is only when u cannot find pinouts and u r sure it is soft problem or damage connector.
Old 05-22-2012, 19:17   #4 (permalink)
Member: 835033
Sonork: luca
Thanx br for your help,I was facing the problem during format,repair and password remove on MTK Cpu,but the error was in conncting phone I can find well pinout but I can't connect phone to read info,sometimes I had to reinstall old updates coz I wasn't able to use new updates and I succeed for other phone but not all and use a lot of time.After this method I managed to repair MTK like remove pass,error same emei restore,format without stress though there are litle prblem wich I can fix myself,It confuse me coz on SPD no prlobem like MTK.Always connection fail,I did'nt able repair many MTK unless for old cpu,that is my problem at all.
thanx in adv.
The Following User Says Thank You to magucha For This Useful Post:
Old 05-22-2012, 19:19   #5 (permalink)
Member: 835033
Sonork: luca
Red =RX,
Orange=TX
Gnd=BLACK
Brown=VCC
3=TX 4=RX
Thanx bro I will try.
Old 05-22-2012, 22:11   #6 (permalink)
Member: 1030392
Sonork: 100.92089
thanx in adv.
contact me by msn or sonork , i will help you to fix your problem with mtk , if you use mtk usb port you should install driver.
maybe have some thing wrong with you that why you cant work well or maybe we have need update our data base so please talk with me at sonork. 100.92089
The Following User Says Thank You to Mastertool For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
Page generated in 0.30660 seconds with 12 queries
