Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GSMSP.com - Any inquiry about our online shop! Do not hesitate to post your issues
Old 01-17-2012, 16:07   #1 (permalink)
piroxi's Avatar
Member: 1134315
Z3X Box from GSMSP
Hi I have a problem with my box in Order ID: 9857807898
Box has a problem with RJ45 port, when I use soft says "data card not found" and soft crashes.
Alredy trying to solve but no answer from you.
Old 01-18-2012, 05:40   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
hello,
please give me screen shot ....
Faisal_Computer
Old 01-18-2012, 20:54   #3 (permalink)
piroxi's Avatar
Member: 1134315
Card not connected:
Card removed:
Thats always when I have to use RJ45 com port.
Thanks in advance!
Old 01-20-2012, 04:52   #4 (permalink)
Member: 151871
Kinldy check drivers
Faisal_Computer
Old 01-20-2012, 14:36   #5 (permalink)
piroxi's Avatar
Member: 1134315
Faisal_Computer
How? Where are correct drivers? Because drivers are different of original Z3x Box.
Old 01-22-2012, 13:20   #6 (permalink)
.::Pieta::.'s Avatar
Member: 921088
use latest card / box drivers then update your card firmware.
Old 01-22-2012, 15:06   #7 (permalink)
piroxi's Avatar
Member: 1134315
Thanks for your answer, but where are smart card drivers as the one inZ3x card drivers are not valid.
Old 01-22-2012, 18:02   #8 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Sonork: 100.1593677
Originally Posted by piroxi View Post
thanks for your answer, but where are smart card drivers as the one inz3x card drivers are not valid.
uninstall all driver and shell,install jaf pkey driver,and shell too,then install only box driver from shell
The Following User Says Thank You to ORANGE MOB For This Useful Post:
Old 01-30-2012, 23:45   #9 (permalink)
piroxi's Avatar
Member: 1134315
My z3x box from GPG has finally faulty: I'm trying to unlock E1190 and "card removed" and windows restart.
Please, don't say drivers problem or usb problem: box it's bad and I want to return!!
Old 01-31-2012, 00:21   #10 (permalink)
mquimpanes's Avatar
Member: 765233
Sonork: 100.1607578
bro just remove the card put in jaf p-key
all done
i think the box cannot handle the card
The Following User Says Thank You to mquimpanes For This Useful Post:
Old 02-03-2012, 13:33   #11 (permalink)
piroxi's Avatar
Member: 1134315
all done
Thanks bro for your help, finally solved!
I did this:
1- open box, take out and put again smartcard. Result: still problems.
2- quit smartcard and put in pkey reader & use z3x GPG box as interface. Result: soft it's stable but when use box as interface STILL PROBLEMS!!!
3- final solution: use smartcard with pkey and another box (nano box) as interface. Result: ALL OK.
Conclusion: z3x box from GPG = BAD.
Any solution? Can I get another one or credit back?
Allways problem with you: same order, SAGEM 5 in 1 cable not works, Blackberry 2 in 1 cable not works!!!!
Old 02-04-2012, 23:13   #12 (permalink)
Member: 151871
Kindly contact me o. Sonork I'll find way to make you happy
I am also using same box which you using I have really no problem at all
And you can see if this happen to every one you will find lot of threads and posts about it so it's very rare case cause we have good quality control agents anyway contact me
Faisal_Computer
Old 03-20-2012, 04:24   #13 (permalink)
DavidServer™'s Avatar
Member: 1175556
Sonork: 100.1609034
@piroxi
maybe is windows problem, coz no one copy of windows is restard when card removed appear in sw, only if A modified copy of windows and is too fully of programs and crap.
so try in another pc, just for test, run windows 7 or win xp sp3 original, no copy modified.
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
How can i get IMEI Number from a nokia 6185 X-plot Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-10-2000 18:47
Ringtones from the charts and new Links GM GSM Mobile Links 0 09-26-1999 13:54
FREECALL HACKED SIMS ON SALE FROM FREECELL! FREECELLUK Main Sales Section 0 07-07-1999 23:22
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.33879 seconds with 11 queries
