Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-01-2010, 07:04   #1 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
1.01 supreme gone for gdfs repair !!! - FIXED
how it's possible !!!
just repair a k800i with supreme and it takes 1.01 supreme credit ( !!
here is log :
  13:45:43  SE Ultimate Unlocker v5.02 by Cruiser Team
  13:45:43  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:45:43  Initializing...
! 13:45:43  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:45:43  2. Choose the phone model
! 13:45:43  3. Select the desired options
! 13:45:43  4. Please connect the phone either via USB while holding 2-5…
! 13:45:44  - or via a serial cable and double-click on it in the device list
  13:47:24  Selected phone: K800
  13:47:24  Connecting via Generic EMP USB Flash Device (USB1)…
  13:47:24  Device driver version: 2.2.0.5
  13:47:24  Device driver date: 4-1-2009
  13:47:25  Connecting to the baseband CPU...
  13:47:25  Entering baseband CPU service mode...
  13:47:25  Detected chipset: DB2020
  13:47:25  Boot mode: ROM
  13:47:25  Sending loader...
  13:47:27  IMEI: 35170801069986
  13:47:27  OTP CID: 49
  13:47:27  Effective CID: 52
  13:47:29  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:48:31  Sending loader...
  13:48:31  Communicating with server…
! 13:48:37  News: Your credit consumption policy: Level 4 (Senior)
  13:48:38  Remainig credit (supreme): 7.57
  13:48:42  Remainig credit (supreme): 6.56
  13:48:45  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:49:26  Sending loader...
  13:49:36  Initializing GDFS access...
  13:49:36  Writing GDFS…
  13:49:44  Code NCK for relock: 6499059881441133
  13:49:44  Code NSCK for relock: 3318888146097587
  13:49:44  Code SPCK for relock: 3330083689066412
  13:49:44  Code CCK for relock: 2824846418011792
  13:49:44  Code PCK for relock: 1980806475545260
  13:49:44  Code ESLCK for relock: 8217754245085056
  13:49:44  Code NCK for unlock: 4683208567377780
  13:49:44  Code NSCK for unlock: 2559517693232026
  13:49:44  Code SPCK for unlock: 5429431102015245
  13:49:45  Code CCK for unlock: 5453224522014534
  13:49:45  Code PCK for unlock: 2927263050714362
  13:49:45  Code ESLCK for unlock: 5711982539997224
  13:49:45  To enter a code, type < * * < on the phone with SIM-card inserted
  13:49:45  Writing flash…
  13:49:46  Turning off the phone...
  13:49:48  Done.
  13:52:27  SE Ultimate Unlocker v5.02 by Cruiser Team
  13:52:28  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:52:28  Initializing...
! 13:52:28  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:52:28  2. Choose the phone model
! 13:52:28  3. Select the desired options
! 13:52:28  4. Please connect the phone either via USB while holding 2-5…
! 13:52:28  - or via a serial cable and double-click on it in the device list
  13:52:30  Communicating with server…
! 13:52:37  News: Your credit consumption policy: Level 4 (Senior)
  13:52:38  Remainig credit (supreme): 6.56
! 13:52:38  Your card activation ID is: 3748D960D96FEFACE9F6887D5D2xxxxx-07
  13:52:38  Done.
Old 01-01-2010, 07:12   #2 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
So can I request to cruiser team to refund my credit !!!
or make me understand the reason of this incident pls ...
Old 01-01-2010, 07:15   #3 (permalink)
Member: 367723
I also faced same problem.today i unlocked w395.see detailes and refund my credits.thanku.happy new year cruiser team.
The Following User Says Thank You to cellcarekphb For This Useful Post:
Old 01-01-2010, 07:46   #4 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
ohhhh! I have just forgot to mention that, that k800i which tried to reapir still not repaired with supreme )
I think its server problem right ???
can we get any answer from the team ???
Old 01-01-2010, 08:23   #5 (permalink)
I_sumo's Avatar
Member: 38103
Sonork: 100.100782
Unhappy w395 why ONE [1.01] supreme log taken ?
ANY things needs to be done or is it normal ???
Select model - w395 & Used com interface - tick 'signed' and 'unlock (uses server + supreme credit )
  13:45:21  SE S1 Flasher & Unlocker v2.13 by Cruiser Team
  13:45:21  Initializing...
! 13:45:21  1. Choose the phone model
! 13:45:21  2. For flashing, select flash files and additional options
! 13:45:21  3. Double-click on the appropriate device (serial cable)
! 13:45:21  - or connect the phone via USB while holding its C button
  13:46:50  Connecting via Cruiser UC-10 Cable (COM3)…
  13:46:50  Device driver version: 1.0.2154.0
  13:46:50  Device driver date: 4-16-2004
! 13:46:50  Connect the phone now
  13:46:51  Connecting to the baseband CPU...
  13:46:52  Entering baseband CPU service mode...
  13:46:52  Phone type: W395
  13:46:53  CDA info: 1228-1723 R4A
  13:46:53  Phone software: 1217-5563 R1EB001
  13:46:53  IMEI: 35876703602799
  13:46:53  Sending loader...
  13:47:03  Reading TA…
  13:47:07  Communicating with server…
  13:47:10  Remainig credit (supreme): 4.54
  13:47:12  Remainig credit (supreme): 3.53
  13:47:12  Searching...
  13:47:15  Unlocking…
  13:47:17  Turning off the phone...
  13:47:19  Done.
! 13:47:19  Please disconnect battery and cable from the phone!
PLz clarify the situation.
i was not expecting this kinda welcome on the very first day of year 2010.
Old 01-01-2010, 08:36   #6 (permalink)
sharif_tell's Avatar
Member: 789364
Sonork: 100.1585484
New year gift......
Old 01-01-2010, 10:33   #7 (permalink)
Member: 768564
1.01 supreme gone for gdfs write
how is it possible !!!
just repair a w200i with supreme and it takes 1.01 supreme credit .
what is the problem ? is it possible to recover that credits.
Thanks
Old 01-01-2010, 11:36   #8 (permalink)
kabirhossain's Avatar
Member: 271880
Sonork: 100.1578866
same to me 1.01 cradit gone
  17:26:37  SE Ultimate Unlocker v5.04 by Cruiser Team
  17:26:37  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  17:26:37  Initializing...
! 17:26:37  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:26:37  2. Choose the phone model
! 17:26:37  3. Select the desired options
! 17:26:37  4. Please connect the phone either via USB while holding 2-5…
! 17:26:37  - or via a serial cable and double-click on it in the device list
  17:29:41  Selected phone: K510
  17:29:41  Connecting via Generic FTDI Cable (COM16)…
  17:29:41  Device driver version: 2.0.0.0
  17:29:41  Device driver date: 5-19-2006
  17:29:42  Connecting to the baseband CPU...
  17:30:54  Entering baseband CPU service mode...
  17:30:55  Detected chipset: DB2012
  17:30:55  Boot mode: ROM
  17:30:55  Sending loader...
  17:30:55  IMEI: 35839701737198
  17:30:56  OTP CID: 50
  17:30:56  Effective CID: 50
  17:30:56  Restarting phone …
  17:32:25  Sending loader...
  17:32:26  Communicating with server…
! 17:32:29  News: Your credit consumption policy: Level 4 (Senior)
  17:32:31  Remainig credit (supreme): 7.65
  17:32:33  Remainig credit (supreme): 6.64
E 17:33:03  Error: 0xE1E2479D
E 17:33:03  Error: 0x07F5EFDA
E 17:33:03  Error: 0x6C729765
E 17:33:03  Error: 0x8CDFAB78
E 17:33:03  Error: 0x3E161E3C
E 17:33:03  Error: 0xA577BDCD
E 17:33:03  Error: 0xC448BD46
E 17:33:03  Error: 0x4EC89901
E 17:33:03  Error: 0x5C5AEBE3
E 17:33:04  Error: 0x3D35EAF1
E 17:33:04  Failed!
! 17:33:04  To report errors right-click this window
Old 01-01-2010, 12:49   #9 (permalink)
Member: 164628
same problem with me ,answer cruiser team.
Old 01-01-2010, 13:20   #10 (permalink)
Member: 274624
Same problem for me.2 handsets consumed 1.01 * 2 = 2.02. Before it would have been 0.15 * 2 = 0.30.
1) K800
16:24:54 SE Ultimate Unlocker v4.11 by Cruiser Team
16:24:54 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
16:24:54 Initializing...
! 16:24:54 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 16:24:54 2. Choose the phone model
! 16:24:54 3. Select the desired options
! 16:24:54 4. Please connect the phone either via USB while holding 2-5…
! 16:24:54 - or via a serial cable and double-click on it in the device list
16:25:29 Selected phone: K800
16:25:29 Connecting via Generic EMP USB Flash Device (USB1)…
16:25:29 Device driver version: 2.2.0.5
16:25:29 Device driver date: 4-1-2009
16:25:31 Connecting to the baseband CPU...
16:25:31 Entering baseband CPU service mode...
16:25:31 Detected chipset: DB2020
16:25:31 Boot mode: ROM
16:25:31 Sending loader...
16:25:31 IMEI: 35908701484887
16:25:31 OTP CID: 51
16:25:31 Effective CID: 52
16:25:33 Please reconnect the phone (disconnect, connect while holding 2-5)
16:25:39 Sending loader...
16:25:40 Communicating with server…
! 16:25:45 News: Your credit consumption policy: Level 4 (Senior)
16:25:45 Remainig credit (supreme): 3.84
16:25:47 Remainig credit (supreme): 2.83
16:25:50 Please reconnect the phone (disconnect, connect while holding 2-5)
16:25:57 Sending loader...
16:26:00 Code NCK for relock: 8511657969178138
16:26:00 Code NSCK for relock: 8340621605715405
16:26:00 Code SPCK for relock: 8480825390109550
16:26:00 Code CCK for relock: 1366466001466572
16:26:00 Code PCK for relock: 5374261032784681
16:26:00 Code ESLCK for relock: 5414662769070207
16:26:01 Code NCK for unlock: 1018631716460216
16:26:01 Code NSCK for unlock: 7967742334715475
16:26:01 Code SPCK for unlock: 1933560489391374
16:26:01 Code CCK for unlock: 3741061766169599
16:26:01 Code PCK for unlock: 3685817750912427
16:26:01 Code ESLCK for unlock: 0244146782228058
16:26:01 To enter a code, type < * * < on the phone with SIM-card inserted
16:26:01 Writing flash…
16:26:03 Turning off the phone...
16:26:05 Done.
2) K800
18:33:38 SE Ultimate Unlocker v4.11 by Cruiser Team
18:33:38 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
18:33:38 Initializing...
! 18:33:38 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 18:33:38 2. Choose the phone model
! 18:33:38 3. Select the desired options
! 18:33:38 4. Please connect the phone either via USB while holding 2-5…
! 18:33:38 - or via a serial cable and double-click on it in the device list
18:34:06 Selected phone: K800
18:34:06 Connecting via Generic EMP USB Flash Device (USB1)…
18:34:06 Device driver version: 2.2.0.5
18:34:06 Device driver date: 4-1-2009
18:34:07 Connecting to the baseband CPU...
18:34:07 Entering baseband CPU service mode...
18:34:07 Detected chipset: DB2020
18:34:07 Boot mode: ROM
18:34:08 Sending loader...
18:34:09 IMEI: 35908801638950
18:34:10 OTP CID: 51
18:34:10 Effective CID: 52
18:34:11 Please reconnect the phone (disconnect, connect while holding 2-5)
18:34:17 Sending loader...
18:34:18 Communicating with server…
! 18:34:23 News: Your credit consumption policy: Level 4 (Senior)
18:34:24 Remainig credit (supreme): 2.83
18:34:26 Remainig credit (supreme): 1.82
18:34:29 Please reconnect the phone (disconnect, connect while holding 2-5)
18:35:03 Sending loader...
18:35:06 Writing flash…
18:35:08 Turning off the phone...
18:35:10 Done.
Please respond.
Old 01-01-2010, 13:33   #11 (permalink)
Yarik's Avatar
Member: 295509
Sonork: 100.1579955
sad story i have the same problem =( i hope thay will back credits or money i just lose 5 suprime credit
the main problem that no 1 answering and i have a lot of phones =((
Old 01-01-2010, 13:43   #12 (permalink)
Member: 114143
yes some problem in server i lost 2.02 credits for one handset unlocking
waiting for refund credits from cruiser team
  13:27:27  SE Ultimate Unlocker v5.04 by Cruiser Team
  13:27:27  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:27:27  Initializing...
! 13:27:27  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:27:27  2. Choose the phone model
! 13:27:27  3. Select the desired options
! 13:27:27  4. Please connect the phone either via USB while holding 2-5…
! 13:27:27  - or via a serial cable and double-click on it in the device list
  13:28:08  Selected phone: W995
  13:28:08  Connecting via Generic EMP USB Flash Device (USB13)…
  13:28:08  Device driver version: 2.2.0.2
  13:28:08  Device driver date: 12-5-2008
  13:28:09  Connecting to the baseband CPU...
  13:28:09  Entering baseband CPU service mode...
  13:28:09  Detected chipset: DB3210 P2A
  13:28:09  Boot mode: ROM
  13:28:10  IMEI: 35402203740199
  13:28:10  OTP CID: 53
  13:28:10  Product type: Retail
  13:28:10  Effective color: Red
  13:28:10  Sending loader...
  13:28:15  Communicating with server…
! 13:28:18  News: Your credit consumption policy: Level 4 (Senior)
  13:28:18  Remainig credit (supreme): 4.31
  13:28:19  Restarting phone …
  13:28:23  Sending loader...
  13:28:30  Remainig credit (supreme): 2.29
  13:28:30  Restarting phone …
  13:28:34  Sending loader...
  13:28:38  Sending loader...
  13:28:39  Writing flash…
  13:28:41  Code NCK for relock: 7090294043998866
  13:28:41  Code NSCK for relock: 0330127994283542
  13:28:41  Code SPCK for relock: 3228695493554106
  13:28:41  Code CCK for relock: 2787317135621660
  13:28:41  Code PCK for relock: 2785541388744052
  13:28:41  Code ESLCK for relock: 7347711565399348
  13:28:41  Code NCK for unlock: 9756198560658847
  13:28:41  Code NSCK for unlock: 3436179506391272
  13:28:41  Code SPCK for unlock: 5561089656127277
  13:28:41  Code CCK for unlock: 1772797992777136
  13:28:41  Code PCK for unlock: 1761298139285053
  13:28:41  Code ESLCK for unlock: 2371121024113057
  13:28:41  To enter a code, type < * * < on the phone with SIM-card inserted
  13:28:41  Converting phone to red…
  13:28:42  Turning off the phone...
  13:28:42  Done.
Old 01-01-2010, 14:21   #13 (permalink)
cdma-india's Avatar
Member: 98139
whats going on here i also lost to repair 1.01 creadit to repair just one w200
Old 01-01-2010, 15:12   #14 (permalink)
Member: 223120
Arrow not enough credit
hi today i purchased 1 supreme credit for cruiser id o7 card and i try to repair gdfs and am getting not enough credit error wats the reason here is the screen shot
[img]http://flashfiles.*******************.net/pictures/not enough.jpg[/img]
Old 01-01-2010, 15:33   #15 (permalink)
Mainboard's Avatar
Member: 25671
Hi,
admin is looking for this problem, please wait until this problem will be solved. Of course additional consumed credits will be returned back to your accounts.
The Following 2 Users Say Thank You to Mainboard For This Useful Post:
What is the TA file for GDFS repair for C902? dune2 SETool2 0 11-17-2009 05:26
MAME 1.01.108 Emulator For Symbian S60v5 murtaza_nns Nokia Multimedia 0 09-19-2009 13:20
i am looking for tp cable for gdfs repair biochemistali SETool2 4 10-15-2008 23:06
w580 came for gdfs repair only once connected now error chiragp DreamBox 2 08-20-2008 13:17
what is the best box for gdfs repair ruvanw1979 Sony Ericsson 9 07-31-2008 11:59
Page generated in 0.50287 seconds with 12 queries
