Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 09-25-2008, 15:29   #1 (permalink)
scutarus's Avatar
Member: 80036
with 2 supreme credits i cannot use ultimate unlocker, WHY?
  16:24:04  Ultimate Unlocker v1.01 by Cruiser Team
  16:24:04  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  16:24:04  Initializing...
! 16:24:04  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 16:24:04  2. Choose the phone model
! 16:24:04  3. Select the desired options
! 16:24:04  4. Please connect the phone either via USB while holding 2-5…
! 16:24:04  - or via a serial cable and double-click on it in the device list
  16:24:21  Connecting via Generic EMP USB Flash Device (USB3)…
  16:24:21  Device driver version: 1.1.0.12
  16:24:21  Device driver date: 9-25-2006
  16:24:22  Connecting to the baseband CPU...
  16:24:22  Entering baseband CPU service mode...
  16:24:22  Detected chipset: DB2020
  16:24:22  Boot mode: ROM
  16:24:22  Sending loader...
  16:24:22  IMEI: 3590xxxxxxxxxx
  16:24:22  Please reconnect the phone (disconnect, connect while holding 2-5)
  16:24:31  Sending loader...
  16:24:31  Communicating with server…
E 16:24:35  Error: 0xE1E2479D
E 16:24:35  Error: 0x41F19ADB
E 16:24:35  Error: 0x07F5EFDA
E 16:24:35  Error: 0x51A411A0
E 16:24:35  Error: 0x78E56923
E 16:24:35  Error: 0x5C5AEBE3
E 16:24:35  Error: 0x3D35EAF1
E 16:24:35  You are not authorized to use this application
E 16:24:35  Login to server failed
E 16:24:35  Failed!
! 16:24:35  Please disconnect battery and cable from the phone!
! 16:24:35  To report errors right-click this window
i have 2 supreme credits into my account and i cannot use this ultimate unlocker free, like u said
WHY?
Old 09-25-2008, 15:33   #2 (permalink)
Member: 67277
If you have account for Cruiser Suite Full Unlocker, use SE Ultimate Unlocker v1.01. It can be downloaded from Download section in the subdirectory Cruiser Suite.
Old 09-25-2008, 15:44   #3 (permalink)
scutarus's Avatar
Member: 80036
and will be fre for me too?i do not undestend
""All customers which have SE Full Unlocker account or D-Unlocker account with at least 1 supreme log can unlock unlimited quantity of phones for free until the end of September 2008""
Old 09-25-2008, 15:46   #4 (permalink)
Member: 67277
Yes ofcourse. It will be free for you too, as you have met the condition of minimum 1 supreme credit on your account. Use Ultimate Unlocker or SE Ultimate Unlocker (if you have an account for Full Unlocker).
Old 09-25-2008, 15:51   #5 (permalink)
Member: 670274
Server Errors
Hi, i have already explained this trouble in detail here:
.. !!! BIG NEWS - Ultimate Unlocker 1.03 just released - click here for more !!! ..
but i copy it here anyway:
So, dear all,
There are lot of reports of server errors and confusion here on the forum. I'll try to explain the most mistakes and give a detailed description what to do.
First of all, there are two different applications:
1. Cruiser Suite Ultimate Unlocker (sometimes referred as "SE Ultimate Unlocker")
this application is used by users who own and use the Cruiser+ dongle
it can be found on support area, in the section:
Downloads > Software_GSM > CruiserSuite > Cruiser_SeUltimateUnlocker > SeUltimateUnlocker_v1.01-installer.rar
2. Ultimate Unlocker
Users who are used to use the D-Client and D-unlocker software, can use this application
Downloads > Software_GSM > UltimateUnlocker > UltimateUnlocker_v1.01-installer.rar
The Errors...
there are (or were) these main issues:
- wrong server port (correct is 9001)
symptoms: Error - "Cannot connect to server"
solution: correct the port number to 9001 in the settings tab and click 'Save'
(in the version 1.01 has been the default port corrected to 9001, but once you have run v1.00, this must be corrected manually)
- usage of wrong application (Cruiser+ dongle owner uses Ultimate Unlocker and vice versa)
symptoms:
  • "Server error, Try again in a few minutes"
  • "Username / card-id not registered"
  • "You are not authorized to use this application"
solution:
install & use the correct application
- Ultimate Unlocker v1.00 bug - it was not possible to use the application without a Cruiser+ dongle inserted
solution:
use Ultimate Unlocker v1.01
Regards
GLaDOS
Cruiser Team
Old 09-25-2008, 15:52   #6 (permalink)
scutarus's Avatar
Member: 80036
but why i cannot use the ultimate unlocker too 4 free until the end of this month?
it will be really nice to test it
Old 09-25-2008, 15:55   #7 (permalink)
Member: 67277
Did you read my previous post? As soon as you have the account with at least 1 Supreme credit (you have 2), you can use Ultimate Unlocker or Se Ultimate Unlocker for unlocking for free until the end of September 2008.
Old 09-25-2008, 15:56   #8 (permalink)
scutarus's Avatar
Member: 80036
  16:49:54  SE Full Unlocker v2.13 by Cruiser Team
  16:49:54  Initializing...
! 16:49:54  1. Please see the documentation first (a PDF installed with the application)
! 16:49:54  2. Make sure the appropriate phone modem drivers are installed
! 16:49:54  3. Fill in the connection settings under settings tab
! 16:49:54  4. Turn the phone ON
! 16:49:54  5. Connect the phone…
  16:50:50  Connecting via SEMC WMC Device (COM55, COM54)…
  16:50:50  Starting communication...
  16:50:50  Communicating with server…
  16:50:54  Remainig credit (supreme): 2.00
  16:50:55  Restarting phone …
  16:51:02  Connecting via SEMC USB Flash Device (USB3)…
  16:51:02  Device driver version: 1.1.0.12
  16:51:02  Device driver date: 9-25-2006
  16:51:02  Starting communication...
  16:51:02  Connecting to the baseband CPU...
  16:51:02  Entering baseband CPU service mode...
  16:51:03  Detected chipset: DB2020
  16:51:03  Boot mode: EROM
  16:51:04  Initializing loader...
  16:51:04  Initializing GDFS access...
  16:51:19  Communicating with server…
! 16:51:23  Operation has been scheduled, please wait 0h 0m 19s
  16:51:45  Connecting to the baseband CPU...
  16:51:45  Restarting phone …
  16:51:51  Starting communication...
  16:51:51  Communicating with server…
  16:51:58  Remainig credit (supreme): 1.00
  16:51:58  Done.
  16:51:58  The phone has been successfully unlocked.
! 16:51:58  Disconnect cable and restart the phone (turn it off and then turn it on)
i lose a credit to unlock a phone
u say is free but for me isn't like this
Old 09-25-2008, 15:58   #9 (permalink)
FilipLudvik's Avatar
Member: 135110
@scutarus:
you should use Ultimate unlocker.
you used: 16:49:54 SE Full Unlocker v2.13 by Cruiser Team
Old 09-25-2008, 15:59   #10 (permalink)
Member: 67277
Use SE Ultimate Unlocker. Mate, read carefully this release info:
http://www./showthread.php?t=600795
Here is the download link for the SE Ultimate Unlocker v1.01:
http://rapidshare.com/files/14808401...-installer.rar
Old 09-25-2008, 16:00   #11 (permalink)
scutarus's Avatar
Member: 80036
sorry 4 duble posting
now i have only ONE remained
i'm very sad
the k530 i can unlock with patch metod without pay one supreme credit
Old 09-25-2008, 16:16   #12 (permalink)
scutarus's Avatar
Member: 80036
yes is working
neither 5 seconds and the phone is unlocked
thank u
btw Mizar can u give me back my credit lost (by my mistake, but i'll be grateful if u help me, thanks)
Old 09-25-2008, 16:23   #13 (permalink)
srkhan's Avatar
Member: 153695
Sonork: 01713115300
D-unlocker user
Dear mizar,
I have D-unlocker credit (1 special credit) can i use free for this months
Thanks
Old 09-25-2008, 20:23   #14 (permalink)
Member: 567351
yes is working
thank u
you are really mad guy..
crying for 1 log when cruiser team give compliantly free till 30 September.
unlock as you want
repair as you want.
4 full days you have man do any qty you have its unlimited free as long you are using correct software and its have 1log..
Old 09-25-2008, 22:17   #15 (permalink)
Member: 106488
becasuse my mystake ok but my log return please
return my log team please
k530 after unlock with cruiser supreme credit acelai00 SETool2 7 10-06-2009 11:45
What happened with Cruiser Supreme Credits reduction? Troubleshooter GsmFatherOnline Unlock Terminal 2 08-17-2009 13:41
Cannot unlock w760i using Ultimate Unlocker soudies Cruiser Suite 4 03-29-2009 08:38
Page generated in 0.40599 seconds with 11 queries
