09-05-2008, 12:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | se full unloer v2.13 error unlocking K850 Code: 13:35:07 SE Full Unlocker v2.13 by Cruiser Team 13:35:07 Initializing... ! 13:35:08 1. Please see the documentation first (a PDF installed with the application) ! 13:35:08 2. Make sure the appropriate phone modem drivers are installed ! 13:35:08 3. Fill in the connection settings under settings tab ! 13:35:08 4. Turn the phone ON ! 13:35:08 5. Connect the phone… 13:35:46 Connecting via SEMC WMC Device (COM250, COM247)… 13:35:46 Starting communication... 13:35:46 Communicating with server… 13:35:56 Remainig credit (supreme): 1.00 13:36:00 Restarting phone … 13:36:29 Connecting via SEMC USB Flash Device (USB4)… 13:36:29 Device driver version: 2.0.0.4 13:36:29 Device driver date: 9-12-2007 13:36:29 Starting communication... E 13:36:29 Error: 0x30AB2B59 E 13:36:29 Error: 0xFEC2C417 E 13:36:29 Error: 0xFEC2C417 E 13:36:29 Error: 0xFEC2C417 E 13:36:29 Error: 0xFEC2C417 E 13:36:29 Error: 0xFEC2C417 E 13:36:29 Error: 0xFEC2C417 E 13:36:29 Error: 0x07F5EFDA E 13:36:29 Error: 0x05190628 E 13:36:29 Error: 0x852D9D91 E 13:36:29 Error: 0x4B4AFEF3 E 13:36:29 Failed to start communication E 13:36:29 Error: 0x319AC5CC E 13:36:29 Error: 0x28FF3CA4 E 13:36:29 Failed! ! 13:36:29 Please disconnect battery and cable from the phone! ! 13:36:29 To report errors right-click this window |
09-05-2008, 12:50 | #2 (permalink) |
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | And now after xx try I get this: Code: 13:49:53 SE Full Unlocker v2.13 by Cruiser Team 13:49:53 Initializing... ! 13:49:53 1. Please see the documentation first (a PDF installed with the application) ! 13:49:53 2. Make sure the appropriate phone modem drivers are installed ! 13:49:53 3. Fill in the connection settings under settings tab ! 13:49:53 4. Turn the phone ON ! 13:49:53 5. Connect the phone… 13:50:09 Connecting via SEMC WMC Device (COM250, COM247)… 13:50:09 Starting communication... 13:50:12 Communicating with server… 13:50:15 Remainig credit (supreme): 1.00 13:50:15 Restarting phone … 13:50:36 Connecting via SEMC USB Flash Device (USB4)… 13:50:36 Device driver version: 2.0.0.4 13:50:36 Device driver date: 9-12-2007 13:50:36 Starting communication... E 13:50:36 Error: 0xFEC2C417 E 13:50:36 Error: 0xFEC2C417 E 13:50:36 Error: 0xFEC2C417 E 13:50:36 Error: 0xFEC2C417 E 13:50:36 Error: 0xFEC2C417 E 13:50:36 Error: 0xFEC2C417 E 13:50:36 Error: 0x07F5EFDA E 13:50:36 Error: 0x05190628 E 13:50:36 Error: 0x852D9D91 E 13:50:36 Error: 0x4B4AFEF3 E 13:50:36 Error: 0x319AC5CC E 13:50:36 Error: 0x28FF3CA4 E 13:50:36 Failed to start communication E 13:50:36 Failed! ! 13:50:36 Please disconnect battery and cable from the phone! ! 13:50:36 To report errors right-click this window |
09-05-2008, 15:12 | #4 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 670274 Status: Offline Thanks Meter: 165 | Hi, Problem is, that the program cannot initialize the communication with the phone in the flash-mode. Try to: - install newer USB Flash drivers (2.1.0.0) - clean-up drivers for WMC devices (you have reached COM 250 - quite a lot) - in this case, i recommend to connect the phone in flash mode - turn it off and connect the cable when holding 'C', or holding '2' + '5' Regards GLaDOS |
09-05-2008, 15:45 | #5 (permalink) |
Banned Join Date: Sep 2004 Location: msaken Age: 43
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | and me same probleme for a long time see this https://forum.gsmhosting.com/vbb/f569/cant-unlock-w910i-server-not-work-578452/ |
K850 can't unlock with SE Full Unlocker!!! | egidijus | Cruiser Suite | 15 | 09-29-2010 16:22 |
error unlocking k850 | Weeguy | Seking Server | 1 | 07-30-2008 16:44 |
!! Cruiser Suite SE Full Unlocker v2.11 was released !! | Mainboard | Cruiser Suite | 21 | 06-26-2008 20:12 |
!! Cruiser Suite SE Full Unlocker v2.11 was released !! | SHANU | Service Products News & Updates | 0 | 06-18-2008 10:40 |
CruiserSuite Full Unlocker v2.02 error unlock W890 - Solved by GLaDOS (no error) | tasos1971 | Cruiser Suite | 4 | 06-10-2008 19:05 |
