06-05-2005, 11:09 | #1 (permalink) |
Junior Member Join Date: May 2005
Member: 147279 Status: Offline Thanks Meter: 0 | 3 Branded Z800i, all options disabled. Thanks, Zoo |
06-05-2005, 11:37 | #3 (permalink) |
Member: 147279 Status: Offline Thanks Meter: 0 | I don't use EMMA. I understood from previous discussions that Cruiser at some point should ask me to connect the TP, but it doesn't. The only thing I can do is "Attach to phone", when done attaching the only thing possible is "Detach phone" |
06-05-2005, 16:09 | #7 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Sweden Age: 50
Member: 36361 Status: Offline Thanks Meter: 0 | Yea, Do as sven.soltermann is saying. I had to do the same, manually choose Z800i and then it works like a charm... Only have to be steady on your fingers when connecting TP to ground and using for example your nails when opening the phone as described earlier. //Niclas |
06-05-2005, 18:38 | #8 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Yes, manually selecting Z800i will be needed since the TAC list is not updated. You should also send Lead the first several (8 or so) digits from your IMEI and the details found on the label of your phone. The type listed there will most likely end in BV. Then he can use that to later update the TAC list. |
06-05-2005, 20:40 | #10 (permalink) |
Member: 147279 Status: Offline Thanks Meter: 0 | I'm slowly getting the hang of it now.... But opening the Z800, what a nightmare! Couldn't take apart the lower part without disassembling the upper part. Do you pros need to disassemble the entire phone to access the TP? |
06-05-2005, 20:54 | #11 (permalink) |
No Life Poster Join Date: Apr 2000 Age: 55
Member: 1246 Status: Offline Thanks Meter: 25 | yes ...u have to be very carefull while openning the Z800. i did like that.. after temoving the screws..i used a very thin plastic knive to dissassembe the upper cover of keybord (the black circle should deattach from each other ) be carefull for attachments from keys to board. be careful for the two metal lines also. sorry difficult for me to find english words for describing how to do |
how to flash kg 290 ....options disabled | biochemistali | Infinity-Box | 10 | 05-26-2009 10:00 |
cruiser 5.0 unlocking option disable | flash | Cruiser Suite | 8 | 08-31-2005 10:41 |
5120 fail 3 in feild test option!!! | jamsab18 | Various CDMA/TDMA Cell Phones | 0 | 08-12-2005 15:22 |
Branded Z800i to Unbranded and back | Zoo | Cruiser Suite | 0 | 06-09-2005 20:23 |
Dead T205 connect to OmegaSW but all button disabled? | NSerN | Motorola ODM | 5 | 04-01-2003 13:33 |
