05-13-2006, 14:23 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Location: Turkey Age: 45
Member: 94508 Status: Offline Thanks Meter: 0 | k750i CID49 Problem Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED OTP CID: 49 Sending applet... RSA protection state cannot be determined for this CID. Phone hardware initialized OK then unlock rsa ok Please remove battery from the phone... Remember to restore the main firmware in the end. Unlocking RSA damages first 128/256KB of main FW in red CID49 phones. but when i try to flash restore files; Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... Invalid response Please turn the phone off and then unlock RSA! Script error: Unspecified [9.61.41] i try to convert it to brown49 but no luck it cant, so i try with testpoint its converted to brown49 but then cruiser says i must to have erom repair but when press button it says erom file for this phone not found or something like this. can anyone help me? P.S: i tried these for more than 10 times but no luck... |
05-13-2006, 16:15 | #4 (permalink) |
Member: 94508 Status: Offline Thanks Meter: 0 | ok, thanks for guide but....; Version 9.63 ready! attaching Phone: .... OTP CID: 49 Sending applet... RSA protection state cannot be determined for this CID. Phone hardware initialized OK attaching ok!!! ... Programming flash... Time: 00:00:01 Flash process done. Phone automatically detached. Please remove battery from the phone... Remember to restore the main firmware in the end. Unlocking RSA damages first 128/256KB of main FW in red CID49 phones. Unlocking Rsa Ok!!! re-attaching (removing battery.....) Ok!!! Security RSA Tab-->Restore Firmware Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... !! It hangs there and; Invalid response Please turn the phone off and then unlock RSA! You have to reflash main FW. i tryed to flash main fw but same it hangs on Waiting acknowledge... So i try to change phone color to brown --> cruiser says changed but when i re attach i can see its red so i tryed to change phone color with tp... but when i changed the phone color i cant flash main fw or raw fs cause cruiser says repair erom but repairing erom impossible .. am i right? i try all combinations but i cant get the phone alive... |
05-17-2006, 11:46 | #6 (permalink) |
Member: 94508 Status: Offline Thanks Meter: 0 | all senario caught on; The phone contains recovery certificate! You MUST repair EROM! Phone hardware initialized OK Sorry, no EROM is available for this phone. will erom for this phone be avaible soon? Last edited by mambo; 05-17-2006 at 12:15. |
05-17-2006, 14:20 | #8 (permalink) |
Member: 94508 Status: Offline Thanks Meter: 0 | already tried; after flashing erom; Sony Ericsson phone detected. Phone CID: 36 Phone color: Red Flash certificate: A1_DB2010_36_RED Trying Red CID36 flash applet... Sending applet prologue... Trying CID16 recovery applet... All threads terminated. cruiser cant detect phone normally so i use tp and change cert. to red49 but phone dead always... |
05-17-2006, 14:23 | #9 (permalink) |
Member: 94508 Status: Offline Thanks Meter: 0 | and by the way the file with k750i extension is; DB2010_EROMRed36_signed_by_Brown36.erom2 i flashed with that file you are saying brown49 only file with brown49 is; DB2010_W810_EROMBrown49_signed_by_Brown49.erom4 its for w810, thanks anyway... |
05-17-2006, 15:42 | #10 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 92178 Status: Offline Thanks Meter: 14 | I have the same problem as you.. hangs at Waiting for acknowledge and if use a testpoint says no erom available so can't repair. Seems a problem that is spreading. Hopefully a solution is found soon |
k750i CID49 flash problems | all-gsm | Sony Ericsson | 9 | 10-08-2007 11:44 |
K750i CID49 problem | ayaz ali | Cruiser Suite | 4 | 06-10-2007 16:03 |
k750i cid49 problem it says erom may be damaged | vish_thakkar786 | Cruiser Suite | 17 | 11-09-2006 03:58 |
K750i CID49 error 302324 OR 303041 - need CID49 EROM? | DarrenNewsgroup | SonyEricsson (USB-Smart) | 2 | 08-25-2006 12:46 |
K750i CID49 Red ??? | blackrose | Cruiser Suite | 3 | 04-15-2006 10:34 |
