10-23-2007, 16:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Denmark Age: 62
Member: 42264 Status: Offline Thanks Meter: 4 | 610i cant repair EROM Flash ID: 0x2019 OTP Security Level: 1 (Retail) OTP CID: 49 Phone CID: 49 Phone color: Red Sending applet... Applet ID: 060721 1022 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "DB2020_EROM_Thelma_Red49_R3A011_signed_by_Brown49 .erom5" Waiting for flash file to load... Preparing to program flash... Baudrate = 921600Bd The applet ignored baudrate change request! Programming flash...' Flash color/CID mismatch! Script error: Flash error [12.02.77] |
10-23-2007, 16:27 | #3 (permalink) |
Freak Poster Join Date: Jan 2005 Location: thai Age: 43
Member: 106250 Status: Offline Thanks Meter: 26 | Upgrade red CID49 EROM R3A011 to R3A016 To upgrade red CID49 EROM R3A011 to R3A016 via Cruiser cable, just boot the phone in Normal mode and use the Repair EROM function. If you wish to accomplish the same task via a DCU-60 cable, follow this list: · For the boot type select the Recovery boot, CID=49 item. · Press the Attach to phone button. · Now, instead of holding the C key, hold keys 2 and 5 simultaneously and insert the cable to the phone bottom connector. · Then press the Repair EROM button and the phone's EROM will be upgraded to R3A016. |
10-23-2007, 16:41 | #4 (permalink) | |
Member: 42264 Status: Offline Thanks Meter: 4 | Quote:
10-24-2007, 15:12 | #5 (permalink) |
Member: 42264 Status: Offline Thanks Meter: 4 | Problem solved but end up whide a phone ther say confguration error please contact network operator. I fount out that is customise problem flash it 3 times but the same problem. Then I tride to setool2lite upload a cust pack and unloc and repair the the phone is ok now! Thanks to badillo tip http://forum.gsmhosting.com/vbb/show...=configuration |
01-15-2008, 05:26 | #8 (permalink) |
Insane Poster Join Date: May 2007
Member: 518262 Status: Offline Thanks Meter: 1 | ic., Thanks for the info.. so no need to repair erom..have 1 qestion though, how to fix the white screen for k800? i tried flashing firmware, customize, but still same problem.. I thought it can be fix in repair erom function, but u said no need to update erom.. |
t/p 2 cant write erom with t/p | ahamed imran | Sony Ericsson | 0 | 02-20-2009 15:03 |
w550i hang up when i am trying to repair erom need help :( | speedstarrr | Cruiser Suite | 0 | 09-18-2006 19:56 |
how to repair erom in k750 cid49? | cevil | Cruiser Suite | 9 | 07-26-2006 11:05 |
how to repair erom whith ub for w800i | ketan.d.chauhan | Universalbox | 0 | 07-24-2006 15:18 |
I can not make repair EROM K608i... | gsm_tele_com | Cruiser Suite | 4 | 01-09-2006 10:00 |
