03-07-2004, 10:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Earth
Member: 38573 Status: Offline Thanks Meter: 0 | About P900 flashing... Can anyone tell me how to flash it step by step.... I'm so scare to kill it. Regards. |
03-07-2004, 10:40 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | It's easy as!! Read my post here: http://www.gsmbb.com/showthread.php?t=1415 You know you can upgrade the P900 online though, right? http://www.sonyericsson.com/updateservice/P900/ Cheers, Muppet |
03-31-2004, 12:04 | #3 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Palestine-Iraq-Afghanistan.... Age: 25
Member: 6478 Status: Offline Thanks Meter: 3 | @muppet I try to read your post but following appears: Error: 502 Bad Gateway. DNS Host name resolution failed. (www.gsmbb.com) please can you either PM or post on this forum |
03-31-2004, 21:51 | #4 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | How To Flash a P900 With Fighter Yea, the gsmbb site seems to have gone away. I hope it's back soon, it's a wealth of good information. Anyway, I'll post what to do instead First! Read the Fighter documentation under Language Packs for the P900. It's got great information in the footnotes which will help clarify the steps for you. All files referenced here are available from the Fighter Support area under the "P90x/P900 pR3C006 sR4A06 cR4A04 bR5D" folder, which is the latest firmware at the time of posting. Steps: Attach to phone part (Select Standard in "Phone to be attached") and flash the R3C006 firmware onto it using "Flash AVR". Detach the phone, pull the battery out and put it back in (don't turn the phone on) Now select "P80x/P90x (PDA-part)" and attach to phone again. You'll now get two options under the "Write Flash" tab, Flash PDA and Flash ARM. Select "Flash PDA" and then flash the phone with R4A06 Symbian part1 Select "Flash PDA" and then flash the phone with R4A06 Symbian part2 Select "Flash PDA" and then flash the phone with CDA/ROLF R4A04 (pick the language pack you want, read the Fighter docs for which file is which) Select "Flash PDA" and then flash the phone with CDA/USERDATA R4A04 (pick the langauge pack again) !!!!THIS STEP WILL ERASE ALL USERDATA!!!! Select "Flash ARM" and then flash the phone with Bluetooth R5D Pull the battery and put it back in again, power up the phone! This has worked for me before with a P900. Mostly though for trouble free operation I'd recommend using the Official P900 Online Update Service, that way if it breaks you can blame SonyEricsson instead! Note: These steps also work for the P800, but BE SURE to use the P800 firmware files. Also, the P800 CDA files aren't split into two, so flashing CDA will erase all userdata. Last edited by muppet; 03-31-2004 at 22:02. Reason: Fixing up bad spelling and grammer! |
04-06-2004, 00:12 | #5 (permalink) |
Member: 6478 Status: Offline Thanks Meter: 3 | @muppet thnx 4 ur help-will get SEfighter to do what u mention--I tried the SE update thru SE site however didnt work-I think its got prob with BOOTarea. probably 2 do with it being flashed by bypass BOOT previously. maybe new firmwares?...problem http://forum.gsmhosting.com/vbb/showthread.php?t=135049 |
04-06-2004, 01:41 | #6 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | @Hakika: I don't think there is any firmware for the P900 that disables flashing of the phone. It probably exists but I don't think SE has released it. I did a phone upgrade 3 days ago via the online update, and I was still able to attach to it (both Phone Part and PDA part) without any problems. |
05-01-2004, 07:10 | #7 (permalink) |
No Life Poster Join Date: Apr 2000 Location: near you Age: 60
Member: 1196 Status: Offline Thanks Meter: 6 | some P900 have hardware problem on PCB ,flash IC is not underfiled with glue,BGA balls may be broken ,and phone stopped to work ,white screen,bluetooth not work ,this is very often case .PCB is fixed with 2 small screws in the middle of the board,some IC around this area have broken BGA and must be reflowed with HOT air tool |
12-10-2004, 11:05 | #9 (permalink) |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | hi i tried to flash my p900 but I chosed p910 flash by mistake. i flashed MCU and now i get Insert Correct Simcard I tried to flash it back but phone doesnt boot. I press Go ( UFS-3 ) and it starting secure booting but it doesnt stop. I also press RSA and I got this msg : McuId: 5B 08 02 01 FF FF FF FF Certificate Accepted Prologue Ok PayLoader Error 2: Certificated Boot Failed, 00:19 what should i do ? plz help Hope to hear soon moly |
12-21-2004, 01:06 | #10 (permalink) |
Junior Member Join Date: Aug 2004 Location: Nottingham,UK Age: 41
Member: 78824 Status: Offline Thanks Meter: 0 | i flashed my p900 to dead by ufs3!!! so i tried to flash it back to normal, the phone will not boot up, it will just try again and again to boot up, never stops(and not boot up). so my curren situation is: cant boot up the phone in order to flash it. anyone have any idea what happened and what i should do. Thanks |
p900 flash to P910 problem .. Howto flash back ?? | kit_kit | Cruiser Suite | 4 | 12-07-2006 08:36 |
P900 flash CDA "Invalid Response" | champion72 | Cruiser Suite | 4 | 04-30-2004 16:35 |
i need p900 FLash for DIV USB | DEBLOQUETOUT | Sony Ericsson | 0 | 03-02-2004 11:26 |
P900 flash problem... | isdnman | Cruiser Suite | 1 | 12-19-2003 16:08 |
Free for all P900 flashing :) | SFlood | Sony Ericsson | 4 | 12-05-2003 08:50 |
