Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 03-05-2009, 17:53   #1 (permalink)
Member: 138583
Thanks Meter: 120
All my phones becomes CID49 BROWN after repair gdfs....
Hi. I have that problem working with SEUltimate Unlocker..... All phones in this state.... What Im doing wrong????
Old 03-06-2009, 05:44   #2 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
i had this problem too try again 2 or 3 times restart software then will change cid brown to red
Old 03-06-2009, 06:30   #3 (permalink)
Member: 138583
Thanks Meter: 120
price is high....,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 03-06-2009, 11:48   #4 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Changing Color is FREE in other Tool.
Old 03-06-2009, 12:57   #5 (permalink)
Member: 952226
Thanks Meter: 20
Write gdfs file and after successful written of gdfs
write erom u want to change to which cid and colour
and flash with new cid file .
Sanoj wayanad
Old 03-06-2009, 18:10   #6 (permalink)
y2y
y2y's Avatar
Member: 166000
Thanks Meter: 26
what type of phone that u hav brown 49?
Old 03-07-2009, 16:00   #7 (permalink)
Member: 138583
Thanks Meter: 120
my phone es w580 friend....
Old 03-07-2009, 17:55   #8 (permalink)
Member: 67277
Thanks Meter: 5,588
Hi,
post here full log of communication so we know exactly what you did. You can convert your W580 brown phone back to red color for free. Read PDF guide for Ultimate Unlocker. You can also find some ideas here.
Mizar
Old 03-09-2009, 12:39   #9 (permalink)
Member: 670274
Thanks Meter: 165
In general, the only supreme-charged operation in Ultimate Unlocker is conversion to brown. Once the phone is brown, you can proceed unlock and reconstructions. The phone should be finally turned back to red (with the default options), unless an error occurs (please post the error log in this case). If you plan to play a bit more with the phone, we recommend to leave it in brown state to prevent multiple credit consumption, selecting the field "Set final certificate to:" to "brown" (for db2020 its brown cid 49, for db2012 it is brown cid51)
If you want just to convert a brown phone (brown with the default cid listed above), you can do the conversion simply for free:
- select "No secZone operation"
- unselect "show codes"
- choose final certificate "Red xx", with the desired target cid
- proceed the operation
with these options selected, no recalculations are done and the phone is just quickly converted to red
GLaDOS
The Following User Says Thank You to GLaDOS For This Useful Post:
Old 03-09-2009, 17:31   #10 (permalink)
Member: 138583
Thanks Meter: 120
  10:27:06  SE Ultimate Unlocker v3.07 by Cruiser Team
  10:27:07  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  10:27:07  Initializing...
! 10:27:07  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 10:27:07  2. Choose the phone model
! 10:27:07  3. Select the desired options
! 10:27:07  4. Please connect the phone either via USB while holding 2-5…
! 10:27:07  - or via a serial cable and double-click on it in the device list
  10:28:48  Selected phone: W850
  10:28:49  Connecting via Generic EMP USB Flash Device (USB3)…
  10:28:49  Device driver version: 1.1.0.12
  10:28:49  Device driver date: 9-25-2006
  10:28:49  Connecting to the baseband CPU...
  10:28:49  Entering baseband CPU service mode...
  10:28:49  Detected chipset: DB2020
  10:28:49  Boot mode: ROM
  10:28:49  Sending loader...
  10:28:50  IMEI: 35282601897296
  10:28:50  OTP CID: 51
  10:28:50  Effective CID: 49
  10:28:52  Please reconnect the phone (disconnect, connect while holding 2-5)
  10:28:58  Sending loader...
  10:28:58  Writing flash…
  10:28:59  Turning off the phone...
  10:29:01  Done.
Old 03-09-2009, 21:11   #11 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 363
Looks like your phone isnt actually CID49 ...
Old 03-10-2009, 00:14   #12 (permalink)
renaldo2's Avatar
Member: 745550
Thanks Meter: 117
after repair gdfs phone convert in CID49 BROWN
but after repair gdfs
you can convert in red cid-49-51-52-53 for freeeeee
without log
k550i after repair gdfs cid53 with log phone onley sony ericsson logo ..:::Gsm india:::.. SETool2 7 02-27-2010 04:34
k550 cid52 to cid49 after repair GDFS why !!!!!!! seddik-gsm Sony Ericsson 4 01-28-2009 06:59
After repaired GDFS phone cid become CID 49 supermatrix SETool2 4 08-19-2008 20:00
C62 - Freezes after repair GDFS *MaTeOoSh* NON Siemens Brand (ODM Phones) 3 10-30-2004 19:55
Page generated in 0.23236 seconds with 9 queries
