03-01-2005, 11:17 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Enschede, Netherlands Age: 41
Member: 34652 Status: Offline Thanks Meter: 5 | Best way to install Fighter onto XP But what is the best way to get in install; which steps do I have to take? Because untill now I can't get it installed properly.... |
03-01-2005, 13:28 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | Quote:
@muppet posted this at the time i had probs and went 100% for me 1) Open up a command prompt (Start -> Run -> type in 'cmd' and press enter) 2) Type in this: regsvr32 c:\windows\system32\scardssp.dll Press return and click on "Ok" with the box that pops up. 3) Type in this: scardsvr reinstall Press return. You'll get no message. 4) Rename the attached file from fix.txt to fix.reg and double click on it. When it asks if you want to install the settings say yes! 5) Go to Start->Settings->Control Panel->Administrative Tools->Services. Double Click Services. In the list you now see, find the Service called "Smart Card" (not Smart Card Helper) and right click on it. Select "Properties" and left click. When the box opens up, change the "Startup Type" to automatic. Click on "Apply" then on "Ok" 6) Reboot Your PC! Do not try to "test" Fighter before doing this step! Your Fighter should now work perfectly! I do hope this helps a bit long winded but it got mine working rgds | |
03-01-2005, 13:38 | #3 (permalink) | ||
Member: 34652 Status: Offline Thanks Meter: 5 | Quote:
Which installation files can I use the best? The latest v4.33? I'll try to start from scratch again. Maybe it's possible for me to ad you to my ICQ or whatever? | ||
03-01-2005, 19:23 | #6 (permalink) |
Member: 34652 Status: Offline Thanks Meter: 5 | I just read the complete manual to install under XP (same as 2000) and they're talking about 'Drivers and OS Update' and download this file from the support page. But I can't find thta file anywhere on that support page. If I can get that file from somebody maybe I could go on installing Fighter. |
03-01-2005, 21:01 | #7 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Guys! Just use the new Cruiser3 Installer, but when it asks what you want to install, select everything apart from the Cruiser binary. Well, you can even install that too but it won't be of any use to you.... Change the directory it installs to C:\Program Files\Fighter (Or whatever you prefer) and then copy the latest fighter4.33 exe file into that new directory. The new Cruiser install does everything, including making sure the SmartCard drivers are installed correct under Windows2000/WindowsXP. @Mastah-GSi: This new installer installs all the cable drivers for you. Follow above and you'll be fine. |
03-02-2005, 11:35 | #8 (permalink) |
Member: 34652 Status: Offline Thanks Meter: 5 | I got everything fixed last night. Just followed the steps of you Muppet. Everything works now. What are the benefits of using the Cruiser installer? |
03-02-2005, 19:42 | #9 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | The Cruiser installer automatically sets everything up correctly, makes sure the SmartCard service is running properly and also installs the middleware. Basically it's an "all in one" package, the old preinstaller didn't do everything, you also had to remember to install the middleware etc. Basically, it's just easier |
03-13-2005, 17:37 | #11 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 49
Member: 88444 Status: Offline Thanks Meter: 0 | So, does it mean I can straight away install Cruiser 3.2 without installing the preinstaller? Also, @muppet, after installing cruiser software, you recommended fighter433.exe to be copied into the install directory. I just downloaded fighter443.exe, which is a self extracting exe file from the cruiser website. Do I just need to copy this self-extracting file into the install directory? |
03-13-2005, 19:31 | #12 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | Cruiser 3.20 installer contains the preinstaller software and everything else required. You only need to copy the Fighter.exe if you're trying to install Fighter... |
Best way to install Phoenix 2006.20.9.148 | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 189 | 10-11-2013 05:28 |
Best way to install Phoenix 2006.20.14.153 | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 3 | 07-09-2013 02:02 |
Best way to install Phoenix 2006 without any dongle | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 10 | 07-31-2007 11:00 |
Best Way To Install New Ust Pro Ii ? | neo_49 | UST Pro II | 7 | 06-28-2007 07:41 |
Best way to install any later version of Phoenix 2006 and USB Dead phone flashing | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 16 | 06-25-2007 21:58 |
