01-03-2004, 10:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2003 Location: SL 550 Age: 48
Member: 20490 Status: Offline Thanks Meter: 3 | T68m gdfs imei FFFFFF-FF-FFFFFF. Help! |
01-05-2004, 16:40 | #2 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia Age: 42
Member: 17711 Status: Offline Thanks Meter: 1,858 | Seem like your phone's OTP area is not programmed. May be this is blank PCB, or flash chip is destroyed. Anyway, try to write Patched flash into phone, change IMEI and Rebuild/Recreate GDFS (unfortunately, I have no Fighter, so, I can't tell what options to use). |
01-05-2004, 21:45 | #4 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | @Racer! 1.Attach phone 2. Create security I zone ( with correct imei) and choose write otp and gdfs area 3. Flash avr with normal flash ( from support zone) 4. flash arm! That is it! Roniri |
01-06-2004, 10:01 | #5 (permalink) | |
Member: 17711 Status: Offline Thanks Meter: 1,858 | Quote:
I think these flashes must be in Fighter support area (I suppose you have Fighter, because your post in Fighter support area). If not, you can use cracked DIV 8.2 and Patched flashes. It works with Terminator dongle. Last tme I downloaded them from www.cellular-support.com. After flashing just change IMEI with DIV and Rebuild CRCs if needed. | |
01-12-2004, 11:25 | #8 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Slovakia Age: 46
Member: 5155 Status: Offline Thanks Meter: 7 | Quote:
BR krtko | |
01-12-2004, 12:49 | #9 (permalink) |
Crazy Poster Join Date: Nov 2003 Location: pakistan Age: 44
Member: 45270 Status: Offline Thanks Meter: 2 | @krtko.... please can u give some more details..... in my phone some time the otp gdfs shows the valid iemi... some time 999999999 and... when i rebuild the sec zone 1 it takes too much time and than says fail.. could it be a h/w fault ?... in another phone i can create the sec zone sucessfully... than i have flashed avr / arm and the phone is still dead |
01-12-2004, 22:03 | #10 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Valhalla - Hall of the Slain Age: 44
Member: 6253 Status: Offline Thanks Meter: 10 | @talibshad Seems your phones has hardware problem Best Regards, SphereGSM | [email protected] | ICQ: 38377906 | www.spheregsm.com |
01-14-2004, 07:32 | #12 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | But what is a problem to write IMEI? If after write IMEI is still FF...F, then just change flash IC with new one and reprogram phone. I have maded this on many T68 ... P.S. OTP IMEI can be the FF...F and phone will work OK, but you MUST have the GDFS imei |
T630 imei FFFFF-FF-FFFFFF-F | f.i.t | Cruiser Suite | 8 | 08-22-2007 11:38 |
What can I do....GDFS IMEI: FFFFFF-FF-FFFFFF-F | kosmonaft | Cruiser Suite | 9 | 03-26-2004 21:55 |
t68 GDFS imei = ffffff .... please help | talibshad | Cruiser Suite | 0 | 01-08-2004 08:19 |
IMEI FFFFFF-FF-FFFFFF cannot be repaired with Fighter. | Phantom | Cruiser Suite | 7 | 11-30-2003 13:45 |
GDFS IMEI: FFFFFF-FF-FFFFFF-F , Help!!!!!! | VsH-GsM | Sony Ericsson | 20 | 10-13-2003 09:18 |
