11-16-2006, 20:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Canada
Member: 219362 Status: Offline Thanks Meter: 31 | Can Cruiser fix this? "Open the Lens Cover" when it is open The problem is that when he tries to access the Camera (or Video Camera), it continually asks him to "open the Lens Cover" - even if the Cover is already open (screen is black regardless). Is this something anyone has come across before, and would a simple flash help this, or is it hardware related. Thanks in advance. |
11-16-2006, 21:16 | #3 (permalink) | |
Member: 219362 Status: Offline Thanks Meter: 31 | Quote:
I opened it up, and the switch just fell out (the small thing with the lever). Is there anyway that is supposed to be secured to the frame, or does it just rest on top? | |
11-17-2006, 00:25 | #4 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 92178 Status: Offline Thanks Meter: 14 | The switch is soldered/glued to the ribbon and the ribbon has a small amount of sticky to hold it to the plastic chassis.. If the pads are Ok you should be able to re-solder it, if not just buy a new ribbon, comes with new switch aswell .. Not an expensive item and are widely available.. ebay included |
K800i "opens the lens cover" | max89 | Sony Ericsson Hardware Repair | 4 | 03-01-2009 16:20 |
When select 1680 software after 2-3 secound close can you fix this I got 3.11 NFF | wgmmmx | Nokia Fault Finder Box | 1 | 07-16-2008 16:53 |
Can Cruiser do this, I'll buy it at once.. | Hicky | Cruiser Suite | 0 | 07-18-2007 18:35 |
can i fix this problem with cruiser | Zein Zozza | Cruiser Suite | 3 | 09-04-2006 21:15 |
K750i "Command Error", can Cruiser Fix this? | gwaai | Cruiser Suite | 1 | 07-23-2005 05:23 |
