Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 07-09-2009, 19:01   #1 (permalink)
mobileunlockers's Avatar
Member: 396778
can we use old crusier dongle to unlock s1
hi
i just want to know if we can use old crusir dongle (06) to unlock s1 phones? thanks
Old 07-09-2009, 20:12   #2 (permalink)
Mainboard's Avatar
Member: 25671
Yes you can use 06 dongle with SE Ultimate Unlocker and also with S1 Flasher & Unlocker
Old 07-09-2009, 20:45   #3 (permalink)
Member: 396778
thank you very much for your answer...where can i buy logs and what price of them? thanks
Old 07-09-2009, 21:52   #4 (permalink)
Member: 150570
Buy supreme logs. Just check resellers. There are UK based ones.
Marty
Old 07-09-2009, 23:43   #5 (permalink)
Mainboard's Avatar
Member: 25671
http://www.cruisersuite.com/default....page=resellers
Old 07-11-2009, 16:23   #6 (permalink)
Member: 411831
how to use??
& which software support it.i have supreme credit(no card reqiure)but i have both dongle (06 & 07) i can use that supreme credit with this dongle??but how completly i need help .if possible please any video.
thank you.
Old 07-11-2009, 17:18   #7 (permalink)
Mainboard's Avatar
Member: 25671
I think you want to say that you have supreme credits for D-Ultimate Unlocker? Why you bought these kind of logs if you have USB dongle? Now you can regret this step because you need buy next logs, this time to your USB dongle.
Instructions are in "Info" tab in Cruiser SE Ultimate Unlocker, just read them, no video is needed.
Old 07-11-2009, 19:49   #8 (permalink)
Member: 411831
i try to unlock k800i by d-unlocker show this error
00:37:39 D-Unlocker v2.32 by Cruiser Team
00:37:39 Initializing...
! 00:37:39 1. Please see the documentation first (a PDF installed with the application)
! 00:37:39 2. Make sure the appropriate phone modem drivers are installed (if applicable)
! 00:37:39 3. Fill in the connection settings under settings tab
! 00:37:39 4. Turn the phone ON
! 00:37:39 5. Connect the phone…
00:37:50 Connecting via SEMC USB Flash Device (USB2)…
00:37:50 Device driver version: 1.0.0.8
00:37:50 Device driver date: 3-30-2006
00:37:50 Starting communication...
00:37:51 Connecting to the baseband CPU...
00:37:51 Entering baseband CPU service mode...
00:37:51 Detected chipset: DB2020
00:37:51 Boot mode: EROM
00:37:53 Initializing loader...
00:37:53 Initializing GDFS access...
00:38:07 Communicating with server…
00:38:14 Remainig credit (supreme): 1.00
E 00:38:15 Error: 0x54CF635C
E 00:38:15 Unknown server problem [129]
E 00:38:15 Error: 0x07F5EFDA
E 00:38:15 Error: 0x28FF3CA4
E 00:38:15 Failed!
! 00:38:15 Please disconnect battery and cable from the phone!
! 00:38:15 To report errors right-click this window
what's wrong??
Old 07-11-2009, 20:57   #9 (permalink)
Mainboard's Avatar
Member: 25671
D-Unlocker is not working for a months. I don't see any problem why you can't use D-Ultimate Unlocker instead. Anyway K800 is not a S1 phone so you probably need read more about phones platforms.
Old 07-11-2009, 21:16   #10 (permalink)
Member: 411831
anyway thank you sir.
i use D-Ultimate Unlocker v3.11 sucess.
01:20:04 D-Ultimate Unlocker v3.11 by Cruiser Team
01:20:04 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
01:20:04 Initializing...
! 01:20:04 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 01:20:04 2. Choose the phone model
! 01:20:04 3. Select the desired options
! 01:20:04 4. Please connect the phone either via USB while holding 2-5…
! 01:20:04 - or via a serial cable and double-click on it in the device list
01:20:36 Selected phone: K800
01:20:36 Connecting via Generic EMP USB Flash Device (USB1)…
01:20:36 Device driver version: 2.1.0.0
01:20:36 Device driver date: 3-20-2008
01:20:36 Connecting to the baseband CPU...
01:20:36 Entering baseband CPU service mode...
01:20:36 Detected chipset: DB2020
01:20:36 Boot mode: ROM
01:20:37 Sending loader...
01:20:37 IMEI: 35xxxxxxxxxxxx
01:20:37 OTP CID: 51
01:20:37 Effective CID: 53
01:20:39 Please reconnect the phone (disconnect, connect while holding 2-5)
01:20:50 Sending loader...
01:20:50 Communicating with server…
! 01:20:56 News: Your credit consumption policy: Level 1 (Novice)
01:20:57 Remainig credit (supreme): 1
01:21:01 Remainig credit (supreme): 0.67
01:21:04 Please reconnect the phone (disconnect, connect while holding 2-5)
01:21:13 Sending loader...
01:21:16 Code NCK for relock: 5108932486763461
01:21:16 Code NSCK for relock: 1114871977472168
01:21:16 Code SPCK for relock: 5400474065819450
01:21:16 Code CCK for relock: 2232588828038337
01:21:16 Code PCK for relock: 2385471733025709
01:21:16 Code ESLCK for relock: 7344274308391043
01:21:16 Code NCK for unlock: 6607660484289920
01:21:16 Code NSCK for unlock: 0627280498102606
01:21:16 Code SPCK for unlock: 5589563706616699
01:21:16 Code CCK for unlock: 3262819816526052
01:21:16 Code PCK for unlock: 4466111050089635
01:21:16 Code ESLCK for unlock: 5328740492443377
01:21:16 To enter a code, type < * * < on the phone with SIM-card inserted
01:21:16 Writing flash…
01:21:18 Turning off the phone...
01:21:20 Done.
kindly tell me sir how to repair red blink case??
same process or any other? & i use this D-Ultimate Unlocker v3.11 for red blink case??
thank you.
May I use my BB Dongle to unlock Treo handsets? caremobiles FuriouS TeaM Products 1 02-27-2010 09:17
Can we use EASY CABLE fr 2630 unlocking? eric3859 MT-BOX 1 02-20-2008 09:52
Can we use SE-TOOL flashfiles to unlock with SE-FUT_REMOTE_v1.0.0.1051.rar MohammedSharif My Total Server 1 12-13-2007 12:04
Can i use a v66 cable to unlock at720 JOHN2003. P2k Series 2 06-22-2004 16:16
Can I use a Data cable to unlock SagemMC920? Irishrover Infineon C16X M51 & ARM7 M52 BASED 2 09-21-2003 19:10
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.83908 seconds with 12 queries
