05-17-2007, 04:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433756 Status: Offline Thanks Meter: 18 | can't attach a K800. Before was attaching. I am having a rpob to attach a k800 System diagnostics passed. Version 10.43 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Terminating threads... All threads terminated. The applet has intentionally turned the phone off! Script error: Unspecified [10.43.88] Phone is having a white screen. did try other SE Box also, but there also cannot attach it. Can any make a sugestion. *Battery is ok thks |
05-17-2007, 04:54 | #2 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | its a problem caused by charging ic , first try clean conector if not working then you have to replace ic be shure battery is fully charged..... |
05-20-2007, 19:40 | #4 (permalink) |
Member: 433756 Status: Offline Thanks Meter: 18 | mate i have this sometimes from the k800. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID52 recovery applet... Time spent entering bootstrap: 10s Unsupported flash certificate Terminating threads... All threads terminated. who can help? |
05-21-2007, 04:23 | #8 (permalink) |
Member: 433756 Status: Offline Thanks Meter: 18 | already this these mate, but cruiser seesm not to attach it. did try with mt trial, again same prob. once it did attach with mt trial, but there was an error on something like otp ffffff reported |
05-23-2007, 05:36 | #9 (permalink) |
Member: 209722 Status: Offline Thanks Meter: 818 | if you have a modified ignation cable then so good but if you have not then attach direct power supply at 4.5 voltage (its should be 4.5 not more not less) with cable and try its the way i have done many sets before which have poor conectiviy.so you...... Last edited by CONCORDIA GSM; 05-23-2007 at 05:48. |
05-23-2007, 05:43 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | did u try to connect with fbus interface with any other tool m facing same problem so many time solved via fbus inter face if u have any other tool check it |
K800 can't attach to cruiser | Jiminay2000 | Cruiser Suite | 7 | 04-24-2007 15:30 |
Please help - i can't attach k800 and k750 | Nikola Jolov | Cruiser Suite | 6 | 03-23-2007 13:26 |
I can't attached K800 with cruiser I think this is problem cristal for connection | Freshbol | Sony Ericsson Hardware Repair | 0 | 01-03-2007 19:23 |
K800 Attached To Cruiser.. But.... | davidliu21 | Cruiser Suite | 5 | 11-06-2006 17:39 |
