11-26-2006, 11:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Kent UK
Member: 290059 Status: Offline Thanks Meter: 72 | Can't connect a dead K800i to Cruiser !!!! I have a K800i that doesn't power up but when you connect the baterie and press on the power button I get flashing red lights next to it. did anyone had the same problem! Can't connect it to cruiser or other online server Please advise what to do next |
11-26-2006, 20:34 | #5 (permalink) |
Member: 290059 Status: Offline Thanks Meter: 72 | I can read the other k800i in less then a second but the dead one can't read at all. Cleaned the connector but no luck will try to replace it Thanks for your advise, I appreciate your support |
11-26-2006, 21:39 | #7 (permalink) |
Member: 290059 Status: Offline Thanks Meter: 72 | I will try to open the phone and change the charging connector if posssible and let you know Could anyone let us know what does the flashing red light (five or six times) next to the baterie means when you insert the baterie and press the on button on a k800i. It must be software problem!!? Thanks |
11-26-2006, 23:53 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Belgium - SYRIA
Member: 39014 Status: Offline Thanks Meter: 7 | I have the same problem too I already changed the System connector , but problem is the same . I thin we have here a H/W issue . maybe the ESD chip that is responsible for flashing line is damages !! anyone has an idea ? Thanks |
can't connect htc ht-03A to unlock | sky_finder | FuriousGold | 1 | 03-09-2010 12:54 |
K550i dead, red blinking,can't connect to cruiser | Civija | Sony Ericsson Hardware Repair | 5 | 05-19-2009 21:12 |
K310a dead due to cruiser unlock | Tantech | Cruiser Suite | 1 | 03-22-2007 11:15 |
K600i can't connect to Cruiser | Alex_G | Cruiser Suite | 3 | 03-24-2006 18:59 |
Cruiser can't connect to C62 | luvu2hrs | Cruiser Suite | 6 | 02-14-2006 00:30 |
