04-27-2004, 17:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | Create(intfObj): Class not registered ??? Win98SE :( I reinstall Win and after that unable to start Fighter. Every time get error message: 'Create(intfObj)': Class not registered @ C:\PROGRA~1\Borland\CBUILD~1\Bin\..\include\vcl\ut ilcls.h/3254 Press [Y]es to terminate, [N]o to continue and [C]ancel to Debug I try with google.com to find info for this problem but no success. Can anybody help ? Svetli |
04-27-2004, 20:10 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | msvcp60.dll Do you have that file on your PC anywhere? I think you need it for Fighter to work. If you don't, get it from http://se-fighter.com/support/msvcp60.dll and copy it to your windows (or maybe windows/system) folder. That should fix the problem I _think_ |
05-01-2004, 09:54 | #4 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | i have this file http://se-fighter.com/support/msvcp60.dll but software not run, again same error other idea ? Svetli |
05-02-2004, 05:50 | #5 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Svetli, call me when you have a time. In most cases for Fighter is better to use Win 2000 / XP, because USB communication is not major advance in old OS like Win98. There also is one more hint - better put to trash Fighter card reader or remade it with UST card reader shematic - then e-gate dongle will work well on all PC-s without problems! |
05-02-2004, 23:16 | #6 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | i found solution: my OS is Win98SE just install Fighter 2.54b for WinXP !!! when install begin will message you that your OS is "Win98 !!!" press OK and finish instalation, restart PC. if you try to start fighter only will get error. uninstall fighter and install version for Win98, restart again PC and software will work fine i test this on two PCs w/o problem. |
Class not registered??? | The Beast | Infinity-Box | 2 | 05-23-2005 21:07 |
