01-30-2009, 14:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | Credit gone but still sa,e problem Code: 19:05:39 SE Ultimate Unlocker v3.07 by Cruiser Team 19:05:39 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:05:39 Initializing... ! 19:05:39 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:05:39 2. Choose the phone model ! 19:05:39 3. Select the desired options ! 19:05:39 4. Please connect the phone either via USB while holding 2-5… ! 19:05:39 - or via a serial cable and double-click on it in the device list 19:05:49 Selected phone: W710 19:05:49 Connecting via Generic EMP USB Flash Device (USB1)… 19:05:49 Device driver version: 2.1.0.0 19:05:49 Device driver date: 3-20-2008 19:05:49 Connecting to the baseband CPU... 19:05:50 Entering baseband CPU service mode... 19:05:50 Detected chipset: DB2020 19:05:50 Boot mode: ROM 19:05:50 Sending loader... 19:05:50 IMEI: 35306601472024 19:05:50 OTP CID: 49 19:05:50 Effective CID: 52 19:05:52 Please reconnect the phone (disconnect, connect while holding 2-5) 19:06:02 Sending loader... 19:06:02 Communicating with server… ! 19:06:08 News: Your credit consumption policy: Level 1 (Novice) 19:06:08 Remainig credit (supreme): 0.67 19:06:12 Remainig credit (supreme): 0.34 19:06:15 Please reconnect the phone (disconnect, connect while holding 2-5) 19:06:23 Sending loader... E 19:06:25 Error: 0xFE6D44E2 E 19:06:25 Error: 0xE9B26D61 E 19:06:25 Error: 0x8118A648 E 19:06:25 Error: 0x59AF7680 E 19:06:25 Failed! ! 19:06:25 To report errors right-click this window |
01-30-2009, 14:39 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | perform gdfs reconstruction using Ultimate Unlocker 3.07. gdfs files are on the support or you can ask people here for creating an image from a working phone. also, you can make the image by yourself if you have an another working W710. |
01-30-2009, 20:54 | #3 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 670274 Status: Offline Thanks Meter: 165 | Right, credit gone, because of successfull conversion to brown (development) state. You are now enabled to perform advanced repair methods on that phone. The error means that you selected an incompatible file for GDFS reconstruction. Please use a file produced from GDFS Backuper & restorer. Those files are in text format, and are recognizable using e.g. notepad. Note: please, at first, make sure that the GDFS reconstruction is really required (there is no other option how to revive the phone), because GDFS reconstruction destroys phone unique calibration data. GLaDOS |
3110c Connect Service. 30 Credit gone but Problem is Same. | Qaisar Mahmood | Universalbox | 17 | 05-05-2011 15:18 |
why still cost credit unlock dct4? 30 credit gone, phone still locked | snowtown | Universalbox | 4 | 10-09-2009 15:04 |
Credit gone but still phone lock. | haider | BB5 Box by D.K. | 4 | 02-16-2009 11:00 |
credit gone but problem not solved | cgsm | D-Unlock Suite | 5 | 12-05-2008 08:11 |
