Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-10-2006, 08:48   #1 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Cruiser 9.54 flashing w800 error
Mr Lead
when flashing w800 customize fs got error
Old 05-10-2006, 09:00   #2 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,691
yeah that Applet baudrate Change Problem is BAD.....i know happened to Me on K600i but then Solve Trying Again and Again...
LEAD must need to Release a Stable version and ALSO a BIG PDF MANUAL
Old 05-10-2006, 10:01   #3 (permalink)
zigma300's Avatar
Member: 175822
Thanks Meter: 4
After alot of trials and errors , well there is nothing wrong with the applet really it should be right. understanding the concept will allow easy unlocking and flashing. RED CID 49 will not allow you to do anything with the fone. only if RSA is unlocked which means temporary access to the fone. could be bug which should be corrected but this how it should work. ex. Customizing a fone after flashing fone will be ready. And RSA locked. you wont be able to customize. unlocking RSA will allow you to customize. Flashing Restore files will make the fone switch on after customize. Fone ready.... So in reality one has to unlock RSA TWICE..once for flashing and once for customizing. and then restoring the fone...
br
ziggy
Old 05-10-2006, 10:31   #4 (permalink)
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
yes i have try many set all got same problem...need customise FS by manual
Old 05-10-2006, 11:34   #5 (permalink)
Member: 91045
Thanks Meter: 8,691
so Solution is Do the Manual Thing.....Ok Guide me i got one K600i Dead I flash it It Came Alive but When open menu its Freezed and need to Take out battery and Again Attach to make it Power On ......Any Suggestion
Old 05-10-2006, 11:39   #6 (permalink)
zigma300's Avatar
Member: 175822
Thanks Meter: 4
@amir
Exactly apply by dot and comma this to k600i should work baud rate at 115200
100 % sure method to unlock k608i
new software ust pro2 9.9.54 tommyvo UST Pro II 2 09-21-2009 02:53
Cruiser 9.72 flash LG 8360 with U8360_V10e_UK_Red42. phone can not swith on. leviswang Cruiser Suite 1 06-07-2006 21:06
Flashing w900 error with cruiser 9.52 desmond2727 Cruiser Suite 12 05-22-2006 05:56
how to useing cruiser 9.63 flash k600&k608 tonytan Cruiser Suite 1 05-13-2006 18:49
Script error: Timeout [9.54.34] when flash ARM T616 by T610 file Ahahahaaaa Cruiser Suite 1 05-10-2006 08:33
Page generated in 0.39440 seconds with 9 queries
