Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-07-2007, 18:38   #1 (permalink)
Member: 229658
Thanks Meter: 60
cruiser installation
the folowing message appear each time i tried to open cruiser s\w. I just formated my system and installed the latest installer 10:43
"An error has occured in the frame window.
The message is:
Acess violation at adress 01AAE288 in module 'slbio4.dll.Read
of address."
N\B
DONT 4GET THAT IT NOT CRUISER PRO.
THANKS
Old 06-07-2007, 19:42   #2 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
Even if you don't have cruiser pro, all next versions of Cruiser will work, only "Cruiser Plus" functions won't be available.
So you can install Cruiser 11.04
Old 10-08-2007, 12:48   #3 (permalink)
Member: 263919
Thanks Meter: 2
how do i install cruiser pro plus 2
hi..got my cruiser plus 2 today..i plugged it in and it said usb device not recognised...need help in installing it please..any help appreciated..thanks in advance..
Old 10-08-2007, 12:56   #4 (permalink)
Member: 318507
Thanks Meter: 17
Install Cruiser software first.
Then plug cruiser Box in.
When you get message new USB device found, navigate to Cruiser folder 'e-gate drivers' and install them.
If you need more detailed inststructions post again.
Let us know if you're successful.
Old 10-08-2007, 13:05   #5 (permalink)
Member: 318507
Thanks Meter: 17
Once the Cruiser software is installed you can:
Run the software
Click 'help'
Click 'intrduction'
Click installing software'
It's a bit outdated now but should still work.
Old 10-08-2007, 14:38   #6 (permalink)
Member: 263919
Thanks Meter: 2
Run the software
Click 'help'
Click 'intrduction'
HI..THANX for reply..i got 06 cruiser cp box installed..do i uninstall that first?and what version should i install?..again thanx
Old 10-08-2007, 14:42   #7 (permalink)
Member: 318507
Thanks Meter: 17
I always un-install old versions of Cruiser before installing new ones.
Once you have got it working check the cruiser website for latest version.
Old 10-08-2007, 14:50   #8 (permalink)
Member: 263919
Thanks Meter: 2
hi...thanx for reply...right then...i uninstalled version 10.43...installed version 11.00 and still cannot install...do i remove cruiser completely and start from the beginning?
Old 10-08-2007, 16:31   #9 (permalink)
Member: 318507
Thanks Meter: 17
Yes
What's happening when you install new version?
Old 10-08-2007, 16:34   #10 (permalink)
Member: 263919
Thanks Meter: 2
Yes
nothing..install lets say...11.00..plug in dongle and computer says usb not recognised..i tried different ports and nothing...tried on my laptop where i also have cruiser installed and it found the drivers and then it said usb not recognised..
Old 10-08-2007, 16:51   #11 (permalink)
Member: 318507
Thanks Meter: 17
Can you read the instructions in the Cruiser software?
Do you get a 'New hardware found' popup window
Old 10-08-2007, 16:58   #12 (permalink)
Member: 263919
Thanks Meter: 2
READ THE INSTRUCTION AGAIN AND AGAIN.."new hardware found" does not pop up..getting a bit cheesed off now...thanx for helping so far..
Old 10-08-2007, 17:11   #13 (permalink)
Member: 318507
Thanks Meter: 17
With Cruiser dongle plugged in:
Go to Control Panel
Click:
System
Hardware
Device manager
view
Show Hidden devices
Universal Serial Bus Controllers
Action
Print
Print to file
Post results here or private me.
Old 10-08-2007, 20:37   #14 (permalink)
Member: 263919
Thanks Meter: 2
Go to Control Panel
Click:
System
Hardware
Device manager
view
Show Hidden devices
Action
Print
Print to file
hi...i could not sort out the drivers..but what i did was change the card from the new one and put it in the old cp box..and it works as far as i know...just a quick question though..does the "direct unlock button" highlight only when i have cruiser logs?...and thank you very much
for your help...keep up the good work...
Old 10-08-2007, 20:59   #15 (permalink)
Member: 318507
Thanks Meter: 17
Beforeyou start using Cruiser just check that your credits are recognised.
Plug in dongle
Run Cruiser
Click:
Extras
Get Credit Info
If this is ok copy and paste your Cruiser log here, when ou work on phone, if you hae problems.
It's the quickest way to a solution.
Cruiser installation error 7th_gear Cruiser Suite 1 07-12-2006 21:14
Cruiser installer 9.23 Downlode khansb Cruiser Suite 6 05-06-2006 12:12
Cruiser Installation Problem tical Cruiser Suite 2 05-28-2005 21:42
Fighter or Cruiser Installation Problem Cables Cruiser Suite 0 12-26-2004 21:04
Cruiser Installation Problem livewirecebu Cruiser Suite 12 12-26-2004 12:19
Page generated in 0.27214 seconds with 9 queries
