09-07-2006, 14:27 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 274214 Status: Offline Thanks Meter: 4 | Cruiser installation - not runing with full functions...help Would it be the cable problem? It apears in Windows Devive Manager as USB Serial Port(COM9) & USB Serial Convertor. In Cruiser program it detected as Fighter USB Cable but wouldn't attach to any phone...help please. Last edited by steca; 09-07-2006 at 14:38. |
09-07-2006, 14:32 | #3 (permalink) |
No Life Poster Join Date: May 2009
Member: 67277 Status: Offline Thanks Meter: 5,588 | Hello, no need to be frustrated. Better to read manual. Your Cruiser is at state of showing only tabs with functions that are allowed for selected / connected phone. You can switch this option off at setup. Also make sure you selected correct phone or let it on autodetection. BR, Mizar |
09-07-2006, 15:04 | #4 (permalink) |
Member: 274214 Status: Offline Thanks Meter: 4 | Thanks Insight and Mizar. I have got other tabs up on the screen now. But it's still stuck at "powering on phone...". then when detach the phone it says "Bootstrap error: EAccessViolation" I have tried other phones (W300i, K750...) and with autodetect too...no luck. Seems it's communication problem...how do you check that if the cable is working OK? when I was installing cable Windows XP showing something like this "new hardware... UniUSB Box by unlocker.net". then it installed cable driver automatically. But My cable is Cruiser 4 in 1 set...nothing to do with this UniUSB Box... Last edited by steca; 09-07-2006 at 15:27. |
09-07-2006, 15:33 | #6 (permalink) |
Member: 274214 Status: Offline Thanks Meter: 4 | Thanks DeDaMrAz. I did that too...upgrading driver with the one came with Cruiser installation...But Windows XP wouldn't upgrad it...maybe I need diferent driver for this cable? Anybody knows about this UniUSB...unlocker.net thing? |
09-07-2006, 16:27 | #8 (permalink) | |
Freak Poster Join Date: Jun 2003 Location: Denmark Age: 56
Member: 31243 Status: Offline Thanks Meter: 13 | Quote:
Cables are almost never the BIG problem, so I expect you have a working Cruiser real soon. BUT, please dont install other Egate-smartcard based programs... Then the real wierd conflicts start ;-)) | |
09-07-2006, 19:46 | #9 (permalink) |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | T6xx-phones can be hard to boot if they have old firmware that does not contain RSA. Also, like insight said, if the connectors on the phone are dirty, you will have a problem booting, the phone usually just powers on instead. Read this for more info: http://forum.gsmhosting.com/vbb/show...31&postcount=9 |
09-09-2006, 02:34 | #10 (permalink) |
Member: 274214 Status: Offline Thanks Meter: 4 | I have managed to reinstall the cable driver. Cruiser is now working!!! Deeply appreciate all your help. T630 is working 100%. Still have problem with W300i...stuck on "powering on the phone..." thing. |
09-10-2006, 14:02 | #12 (permalink) |
Member: 274214 Status: Offline Thanks Meter: 4 | Thanks Insight, tried that....no luck. sometimes it showing "Bootstrap error: TSerialPort is not opened" while it stuck on "powering on the phone..." and the phone has been switched on and showing USB cable connecting info. |
09-10-2006, 16:36 | #14 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 46
Member: 307245 Status: Offline Thanks Meter: 1 | Your best option for older SE phone like T610, T630 etc is SEMCtool which you will find attached to this post. You can use the Cruiser box with this software all you do is select Fighter Cable and the port your Cruiser is using. SEMC Tools cracked http://www.megaupload.com/?d=769VD2UQ |
09-15-2006, 05:10 | #15 (permalink) |
Member: 274214 Status: Offline Thanks Meter: 4 | Hi Guys, Thank you all for your help. Worked out today about W300i stuck on "powering on the phone...". The prob is my cable. It's a 4 in 1 cable came with Cruiser. I have found that the pins on the plug are on opposite order. It's brand new bought two weeks ago...Unbelievable. |
Cruiser card not registered on the server, HELP!!! | andy_gal | Cruiser Suite | 2 | 10-24-2008 18:15 |
Samsung T639 Not supported with NS, pls help with unlocking? | Boshko_Alfa | NSPRO | 24 | 02-28-2008 11:37 |
Furious Box 2 Not Working With New Update....help | francogsm | FuriouS II | 2 | 06-10-2006 14:22 |
x610 can not flash with ufs-3.............HELP!! | faisi | UFS2 + UFS3-Tornadoflasher | 1 | 06-03-2006 03:29 |
You don't have Cruiser ? GET IT NOW, with full support of W900, W600, W550 | Mizar | Main Sales Section | 0 | 02-02-2006 09:46 |
