12-22-2004, 10:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Cebu, Philippines
Member: 15652 Status: Offline Thanks Meter: 344 | Cruiser Installation Problem 1. Unpack and install CruiserPrepareA_v1.00.rar 2. Restart PC 3. Install required drivers, they should be located in "C:\Program Files\OS Update and Drivers" 4. Unpack and install CruiserPrepareB_v1.00.rar 5. Restart PC 6. Unpack and install CruiserInstall_v1.00.rar It gives me this error. Any help is appreciated. |
12-22-2004, 10:55 | #2 (permalink) |
No Life Poster Join Date: May 2009
Member: 67277 Status: Offline Thanks Meter: 5,588 | This is a matter of middleware installation. The best would be if you could install the fighter first and than Cruiser exe. Lead is working on new installer - the INNO was not very good choice. If that didn't help, go to winnt system32 directory and regsvr32 iopCOM3.dll restart the comp and try to run it. mizar |
12-22-2004, 11:29 | #3 (permalink) |
Member: 15652 Status: Offline Thanks Meter: 344 | thank you mizar for the quick reply. But i dont have FIGHTER Installer. I have not used fighter. regsvr32 iopCOM3.dll tells me LoadLibrary("iopCOM3.dll") failed - The specified module could not be found. |
12-22-2004, 12:42 | #5 (permalink) |
Member: 15652 Status: Offline Thanks Meter: 344 | @sandman thank you for the offer. I have unlocked several units now. @mizar This should not be the case for a 700USD device with problems with installation software. Regards, |
12-23-2004, 19:18 | #8 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Australia Age: 41
Member: 3671 Status: Offline Thanks Meter: 28 | Hi Mizar, Same problem here. Installing old fighter wont help. I am using new computer. Pls give me information when update is ready. I want to use my new dongle!!! |
12-23-2004, 19:29 | #9 (permalink) |
No Life Poster Join Date: Jul 2004 Location: 0xBA, 0xBE Age: 38
Member: 73743 Status: Offline Thanks Meter: 2 | @alro if you are a fighter user then i would install it using the fighter setup. I installed cruiser onto a new computer today and i installed older fighter version by following instructions exactly and then i just added the cruiser exe to fighter directory and it worked great for me. very easy. |
12-24-2004, 06:53 | #11 (permalink) | |
Member: 15652 Status: Offline Thanks Meter: 344 | install prepareA, prepareB, installer of cruiser, and installer of fighter in this order. RUn cruiser. it should work this way. Quote:
12-24-2004, 07:34 | #12 (permalink) |
Junior Member Join Date: Dec 2004 Age: 54
Member: 99741 Status: Offline Thanks Meter: 0 | I managed to get mine installed this way. Install fighter preinstall, install fighter, install cruiser.exe into fighter folder. Run cruiser. Worked for my pc's & laptop. HTH. |
cruiser fighter cable instalation problem | bombayteji | Nokia Hardware & Hardware Repair | 2 | 09-17-2008 12:31 |
Installation Problems Of Cruiser | P1C1 | Cruiser Suite | 6 | 01-28-2006 20:51 |
Cruiser Cable instalation problem. HELP .... | baboom | Cruiser Suite | 5 | 06-25-2005 21:51 |
Cruiser Installation Problem | tical | Cruiser Suite | 2 | 05-28-2005 21:42 |
Fighter or Cruiser Installation Problem | Cables | Cruiser Suite | 0 | 12-26-2004 21:04 |
