Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 07-22-2008, 20:07   #1 (permalink)
Black_Daimond's Avatar
Member: 179391
Cruiser PLEASE HELP, Problem in S500i after Unlocking
I have did more S500i before with cruiser, and all went ok
But right now I have 2 pcs S500i and both after Unlock RSA, Flash ARM, Write Raw Fs, Direct Unlock, Customize FS, Power Off phone is giving Very BIG abnormal Fonts.
I first did the procedure with Cruiser V13.1 Trying 3 different flash files CID52.
Today I downloaded Cruiser V13.2 and tryed again, but still problem with Big Fonts.
Please help.., its urgent!!!
Old 07-22-2008, 20:27   #2 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
can u post ur log please
Old 07-22-2008, 20:58   #3 (permalink)
Member: 179391
See it in previous post S500i posted by me!
Old 07-22-2008, 21:53   #4 (permalink)
mony_valley's Avatar
Member: 194207
post ur log
so we can help u
mony_valley
Old 07-22-2008, 22:08   #5 (permalink)
Member: 179391
Here is my full log
Originally Posted by mony_valley View Post
post ur log
so we can help u
mony_valley
System diagnostics passed.
Version 13.20 ready!
Do NOT connect the phone at this time!
[ --- Attach to Phone --- ]
Connecting via SEMC DCU-60...
Connect the phone while holding its C button!
USB connection established.
Baseband chip ID: 0x9900
Protocol version: 3.1
Booting via EROM...
Sony Ericsson phone detected.
Phone CID: 52
Phone color: Red
EROM version: R3A022
Trying CID52 recovery applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 0s
Initializing phone hardware...
Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Applet ID: 061205 1523 HANCXC9876543210_DB2020...
Sending applet...
Applet ID: 061201 1314 HANCXC1329129_DB2020_FL...
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
[ --- Unlock RSA --- ]
Preparing to program flash...
Programming flash...
Time: 00:00:22
Flash process done.
Time: 00:00:02
Flash process done.
Sending CS applet...
Applet ID: 070410 1557 HANCXC1250562_DB2020_CS...
Initializing CS applet...
Starting up GDFS service...
Starting up filesystem, please wait...
Removing RSA lock...
Restarting phone...
Sending applet...
Sending applet...
Time: 00:03:23
Flash process done.
Please disconnect the phone and reinsert its battery!
Failed!
Failed!
[ --- Detach Phone --- ]
Terminating threads...
All threads terminated.
Booting via EROM...
Phone CID: 52
Phone color: Red
Flash ID: 0x897E
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Sending applet...
Time: 00:00:22
Flash process done.
Time: 00:00:02
Flash process done.
Restarting phone...
Sending applet...
Sending applet...
Time: 00:03:23
Flash process done.
Waiting for acknowledge...
Applet ID: 070516 0311 CRU4_CXC1329130_DB2020_...
Sending applet...
Applet ID: 070516 0201 CRUCXC1329134_DB2020_PR...
Done.
[ --- Flash Main Firmware --- ]
Flash file: "S500i_CXC1123326_Generic_R6AC003_Red52.cs5sw"
Waiting for flash file to load...
Time: 00:03:48
Flash process done.
[ --- Direct Unlock --- ]
Analyzing firmware...
Preparing for direct unlock...
Processing...
Status: Success [O]
Creating firmware backup file...
Time: 00:00:02
Flash process done.
If the phone cannot be turned on anymore, report its type and firmware version.
Unlocking phone...
Recalculating CRCs...
Done.
[ --- Customize File System --- ]
Applet ID: 061114 0304 CRUCXC1250562_DB2020_CS...
Building customization...
Customizing phone...
Done.
Writing CDA Article MS string...
New value: CDA102568/11
Done.
Writing CDA Version MS string...
New value: R8A
Done.
Writing Default Article MS string...
New value: cxc1123328
Done.
Writing Default Version MS string...
New value: R6AC003
Done.
Writing langpack string...
New value: EUROPE_2
Done.
Writing country...
New value: Generic Trade
Done.
[ --- Turn off Phone --- ]
Turning off phone...
Phone turned off.
Phone automatically detached.
Old 07-22-2008, 22:18   #6 (permalink)
Member: 194207
i think the problem in Customize
do it again if not working try to flash only without unlock
if not working try to use Se A1 Java Unlocker
& post ur log again
mony_valley
Old 07-22-2008, 22:29   #7 (permalink)
Member: 179391
I did costumize more then 8 times. I think the problem is in costumize too, but how to fix it.
When I check the box, "Costumize after write Raw_FS, it fails after 100% writing Raw_FS. And ill have to restart Cruiser to write the Raw_FS.
Ill try the SE A1 Java Unlocker and post again
Old 07-22-2008, 22:39   #8 (permalink)
Member: 194207
dont mark Costumize after write Raw_FS
do it manual
mony_valley
Old 07-22-2008, 22:54   #9 (permalink)
Member: 179391
I'm doing it manualy, after the first time error, im doing it manualy only.
Im trying the A1 Java unlocker, im in "PHONE MODE" trying to install the drivers! But @ this point, fonts are still big!
Old 07-22-2008, 22:58   #10 (permalink)
Member: 179391
2. Turn on the phone with test card or sim card for which is the phone locked
This simcard I had to use, is a non accepteble sim, or the sim wich the phone came with?
Old 07-22-2008, 23:08   #11 (permalink)
Member: 179391
Step 3. Go to Entertainment and select Games.
4. Delete executor file.
5. Turn off the phone
I did all this.
What now???
I turned on the phone back and Fonts are the same!
And I cannot copy paste the log of the Se A1 Java Unlocker
Old 07-22-2008, 23:10   #12 (permalink)
Member: 194207
u have the original sim card which the network was locked on it or use test sim card
by test sim card u can browse any menu in any phone locked
u must have it to do unlock
mony_valley
Old 07-22-2008, 23:18   #13 (permalink)
Member: 179391
Yes I do have the sim card the phone was locked to.
That one only I used. The phone is unlocked succesfully but the Fonts are still abnormal BIG.
It makes it uncomfortable when browsing the phone menu.
All text will come one un top of each other.
Please help me solve this problem.
Old 07-22-2008, 23:20   #14 (permalink)
Member: 194207
ok uninstall 13.20 & install 13.11 do it by the oldest way of unlocking DB2020 CID52
1- attach phone
2- write raw fs
3- unlock rsa
4- flash ARM
5- direct unlock
6- Costumize choose it as it shown in flash
post ur result
mony_valley
Old 07-22-2008, 23:41   #15 (permalink)
renaldo2's Avatar
Member: 745550
First please check the operator who sold this cell phone. If this phone is sold in France, go at the Cruise support, carefully look and then you should find ARM & FS that say FRANCE. Download this and flash your phone. Your problem should now be solved.10000000000000...........%
problem in 6233 after unlock saamzaa MT-BOX 1 10-28-2007 12:36
problem in 6233 after unlock saamzaa BB5BOX 6 10-28-2007 07:20
problem in 6233 after unlock saamzaa BB5 Box by D.K. 1 10-28-2007 06:48
Problem In V360 After Unlock !!!! younessebeni Smart-Clip 2 01-05-2006 17:26
Page generated in 0.54969 seconds with 11 queries
