CRUISER PRO 2 BOX with setup? i'm just buy a cruiser pro 2 box. because it don't come with any soft, i have download last setup release of cruiser 11.06 to install. after run that setup, now i connect box and it asking for driver to install. but i can find any driver form those files i donwload. so were to do? does it need any driver and also can this last update 11.06 work with cruiser pro 2. thank. i stop installation when new device installation screem appear. |
the drivers shoul be in the installer, you should have cable drivers and Egate drivers. manualy direct your self to the folders. |
ok i have done that some fews minute ago. but it look like something miss on those drivers.i see egate drivers, usb cable drivers etc... but don't know excatly witch one to choose before another. this because after choose one, pc still ask me to put a disk but i follow the directory of cruiser and can't find that. so i cancel and continue installation until the end. but now don't if installation correct because i ccancel some part. how to know now that all is ok or well install? |
if you have CP Box, windows is looking for 2type of drivers (one for usb card reader and second for fighter cable) 1st drivers is located in cruiser directory (for example, in my case) D:\Program Files\CruiserPlus\Cyberflex Access e-gate Drivers 2nd cable driver is located in directory (for example, in my case) D:\Program Files\CruiserPlus\Cable Drivers\Version 2154 for Win98, WinME, Win2K and WinXP (stable) |
ok i have install those two drivers following the directory as say. but now how to know that all is ok. on comport 17 i find sphere gsmfighter cable should i modified number affected to tht from 17 to 3 for example. what is this cable call UC-10 universal cable?. |
for unlocking and flash old model use fighter cable but for flashing and unlocking DB2020 & DB 2012 use usb cable and goos luck |
i HAVE THE CRUISER PRO 2 What dowload the fofware for cruiser box 2 |
You need to sign up to Support site, its free, Once there you will find all the Files, you need to get you up and Running. http://www.cruisersuite.com/default.aspx?cms.page=index |
