Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-10-2009, 07:43   #1 (permalink)
Member: 367723
cruiser server problem
cruiser team server not working.please solve.
thanku.
  13:14:12  SE Ultimate Unlocker v3.07 by Cruiser Team
  13:14:12  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:14:12  Initializing...
! 13:14:13  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:14:13  2. Choose the phone model
! 13:14:13  3. Select the desired options
! 13:14:13  4. Please connect the phone either via USB while holding 2-5…
! 13:14:13  - or via a serial cable and double-click on it in the device list
  13:14:38  Communicating with server…
E 13:15:40  Error: 0xB3A47971
E 13:15:40  Login to server failed
E 13:15:40  Failed!
! 13:15:40  To report errors right-click this window
and
  13:15:02  D-Ultimate Unlocker v3.07 by Cruiser Team
  13:15:02  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:15:02  Initializing...
! 13:15:02  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:15:02  2. Choose the phone model
! 13:15:02  3. Select the desired options
! 13:15:03  4. Please connect the phone either via USB while holding 2-5…
! 13:15:03  - or via a serial cable and double-click on it in the device list
  13:15:13  Communicating with server…
E 13:16:15  Error: 0xB3A47971
E 13:16:15  Login to server failed
E 13:16:15  Failed!
! 13:16:15  To report errors right-click this window
here is the results of d unlocker and cruiser ultimate unlocker
Old 01-10-2009, 08:37   #2 (permalink)
IkaMazini's Avatar
Member: 162473
same problem, cruiser team please check server
  12:28:58  SE Ultimate Unlocker v3.07 by Cruiser Team
  12:28:58  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  12:28:58  Initializing...
! 12:28:58  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 12:28:58  2. Choose the phone model
! 12:28:58  3. Select the desired options
! 12:28:58  4. Please connect the phone either via USB while holding 2-5…
! 12:28:58  - or via a serial cable and double-click on it in the device list
  12:29:15  Selected phone: K770
  12:29:15  Connecting via Generic EMP USB Flash Device (USB1)…
  12:29:15  Device driver version: 2.2.0.0
  12:29:15  Device driver date: 9-18-2008
  12:29:15  Connecting to the baseband CPU...
  12:29:15  Entering baseband CPU service mode...
  12:29:15  Detected chipset: DB2020
  12:29:15  Boot mode: ROM
  12:29:15  Sending loader...
  12:29:16  IMEI: 352**************
  12:29:16  OTP CID: 51
  12:29:16  Effective CID: 53
  12:29:18  Please reconnect the phone (disconnect, connect while holding 2-5)
  12:29:23  Sending loader...
  12:29:23  Communicating with server…
E 12:30:28  Error: 0x3173E984
E 12:30:28  Error: 0x4B055A8F
E 12:30:28  Error: 0x0B22373D
E 12:30:28  Error: 0xB3A47971
E 12:30:28  Error: 0x41F19ADB
E 12:30:28  Error: 0x51A411A0
E 12:30:28  Error: 0x78E56923
E 12:30:28  Error: 0x5C5AEBE3
E 12:30:28  Error: 0x3D35EAF1
E 12:30:29  Login to server failed
E 12:30:29  Failed!
! 12:30:29  To report errors right-click this window
Old 01-10-2009, 08:53   #3 (permalink)
Formingus's Avatar
Member: 322417
Cruiser as i see don't have support off all
i post one or 2 thread 5-7 day's ago no one answer
Sad to say but m disappointed after buy Cruiser Dongle
Regards
Old 01-10-2009, 08:55   #4 (permalink)
Member: 367723
waiting for reply...................
Old 01-10-2009, 09:39   #5 (permalink)
FilipLudvik's Avatar
Member: 135110
the server needs to be restarted. wait till monday.
Old 01-10-2009, 10:19   #6 (permalink)
paedy's Avatar
Member: 119552
Oh My..
Why SO Long..
Plz Fix A porblem A.S.A.P.
PAEDY
Old 01-10-2009, 10:28   #7 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
  11:25:45  SE Ultimate Unlocker v3.07 by Cruiser Team
  11:25:45  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  11:25:45  Initializing...
! 11:25:45  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 11:25:45  2. Choose the phone model
! 11:25:46  3. Select the desired options
! 11:25:46  4. Please connect the phone either via USB while holding 2-5…
! 11:25:46  - or via a serial cable and double-click on it in the device list
  11:26:13  Selected phone: V640
  11:26:13  Connecting via Generic EMP USB Flash Device (USB5)…
  11:26:13  Device driver version: 2.0.0.4
  11:26:13  Device driver date: 9-12-2007
  11:26:14  Connecting to the baseband CPU...
  11:26:14  Entering baseband CPU service mode...
  11:26:15  Detected chipset: DB3150 P2B/R2A
  11:26:15  Boot mode: ROM
  11:26:15  Sending loader...
  11:26:18  IMEI: 3588010173XXXX
  11:26:18  OTP CID: 52
  11:26:18  Product type: Retail
  11:26:19  Effective color: Red
  11:26:20  Sending loader...
  11:26:23  Communicating with server…
E 11:27:25  Error: 0xB3A47971
E 11:27:25  Error: 0xB1A5E70E
E 11:27:25  Error: 0xCDFE8536
E 11:27:25  Error: 0x3D1C4CBE
E 11:27:25  Error: 0x3D35EAF1
E 11:27:25  Login to server failed
E 11:27:25  Failed!
! 11:27:25  To report errors right-click this window
Old 01-10-2009, 11:07   #8 (permalink)
cdma-india's Avatar
Member: 98139
SAME PROBLEM HERE plz fix problem cruiser team
Old 01-10-2009, 11:36   #9 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
now those who have package will get 4 days more ?
Old 01-10-2009, 12:01   #10 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
  11:56:37  SE Ultimate Unlocker v3.07 by Cruiser Team
  11:56:37  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  11:56:37  Initializing...
! 11:56:37  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 11:56:37  2. Choose the phone model
! 11:56:37  3. Select the desired options
! 11:56:37  4. Please connect the phone either via USB while holding 2-5…
! 11:56:37  - or via a serial cable and double-click on it in the device list
  11:56:40  Communicating with server…
E 11:57:41  Error: 0xB3A47971
E 11:57:41  Login to server failed
E 11:57:41  Failed!
! 11:57:41  To report errors right-click this window
i am also having same problem ///
when will it start?
Old 01-10-2009, 12:15   #11 (permalink)
Member: 173199
same problem too
please fix this problem ASAP
Old 01-10-2009, 12:25   #12 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
E 11:57:41  Failed!
when will it start?
i heared this word " MONDAY "
Old 01-10-2009, 12:33   #13 (permalink)
harun_warsanto's Avatar
Member: 718412
I've got some problem too....
Please fix it ASAP cruiser team....
Old 01-10-2009, 12:53   #14 (permalink)
Member: 182006
same here
  11:35:17  SE Ultimate Unlocker v3.06 (Beta) by Cruiser Team
  11:35:17  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  11:35:17  Initializing...
! 11:35:17  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 11:35:17  2. Choose the phone model
! 11:35:17  3. Select the desired options
! 11:35:17  4. Please connect the phone either via USB while holding 2-5…
! 11:35:17  - or via a serial cable and double-click on it in the device list
  11:35:55  Selected phone: C905
  11:35:55  Connecting via Generic EMP USB Flash Device (USB4)…
  11:35:55  Device driver version: 1.1.0.12
  11:35:55  Device driver date: 9-25-2006
  11:35:56  Connecting to the baseband CPU...
  11:35:56  Entering baseband CPU service mode...
  11:35:57  Detected chipset: DB3210 P1A/P1B
  11:35:57  Boot mode: ROM
  11:35:57  Sending loader...
  11:35:59  IMEI: 35760202489226
  11:35:59  OTP CID: 52
  11:35:59  Product type: Retail
  11:35:59  Effective color: Red
  11:36:00  Sending loader...
  11:36:04  Communicating with server…
E 11:37:10  Error: 0xB3A47971
E 11:37:10  Error: 0xB1A5E70E
E 11:37:10  Error: 0xCDFE8536
E 11:37:10  Error: 0x3D1C4CBE
E 11:37:10  Error: 0x3D35EAF1
E 11:37:10  Login to server failed
E 11:37:10  Failed!
! 11:37:10  To report errors right-click this window
This seems to happen last two saturdays (my busiest day of the week )
This is the biggest problem with server based unlock solutions .
Steve
Old 01-10-2009, 15:12   #15 (permalink)
IkaMazini's Avatar
Member: 162473
Server working, tested! 19:00 10.01.2009
SERVER STATUS USE V 2.2.0.0 - HWK Upgrade/Installation/Support Server Problem Discuss GsmMunna HWK 845 Yesterday 07:04
cruiser 13.20 server problem.??? jayanthabandara Cruiser Suite 5 12-26-2008 10:34
cruiser conecting problem with server ...:::JamalMustafa:::... Cruiser Suite 1 04-08-2007 15:06
We need cruiser server with emma3 MOBICOM Cruiser Suite 1 10-05-2006 21:23
cruiser server problem lwilson Cruiser Suite 2 05-09-2006 11:35
Page generated in 0.49508 seconds with 11 queries
