cruiser team plz help w850i died after flash i new user cruiser box and I did eror loading flash by cable com and not usb plz what do i do thanks team :confused: |
It does not Matter, what you Flash it with, USB is Faster.... Just Have correct Files and Flash again, use files from Same Firmware dont Mix. you need a main /sw.... and an Filesystem /fs if you want to Use USB, select Usb icon at end of com port row. |
whene u attach ur phone ,u will say some info about color and cid its important 2 check both before flashing cause u must flash with same cid and color flash main first fs with marking cs |
brother use setool flash with proper CID |
cel_phon: don´t say these words on Cruiser Forum. Cruiser can properly fix any phone as SETool can do. Both are great boxes. One is better for something, second for something else but both can make the same job (on the end) |
