10-15-2006, 07:42 | #3 (permalink) | |
Freak Poster Join Date: Nov 2004
Member: 92178 Status: Offline Thanks Meter: 14 | Quote:
Easy Fix this one. Had the same problem couple of weeks ago and fixed it 100%. you need to email Cruiser Team explaining the error and also you need to read your Dongle Card ID and let them have it, after a couple of days you will get a new activation code to enter and you box login will be fixed. You generate new cardid by going to settings -> licensing tab ONLY Read Dongle ONCE as If you do it again another time after you have told mizar the code the required code will change and it will be different and not work.. mailto: [email protected] | |
10-15-2006, 20:32 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | You don't need to play with activation! First check the driver of cable you using. You should delete and install driver correctly. |
10-15-2006, 21:13 | #5 (permalink) | |
Its not normally the driver thats the problem with the box logon fail error, because if the driver isn't installed properly you won't be able to select a com port in cruiser to get the actual box login fail error if you know what I mean... When cruiser has come up against a problem with the dongle i.e. lost the activation status it will still find it but will fail the security check/activation status.. thus Box login Fail. whereas if the drivers are not installed correctly you won't be able to get as far as Box login fail error. But of course Hopefully ami236 has checked his cruiser drivers to rule out any other problems.. | |
10-27-2006, 19:49 | #10 (permalink) |
Freak Poster Join Date: May 2004 Location: GSM World
Member: 64602 Status: Offline Thanks Meter: 4 | Cruiser team what's the mater with u??????? Cruiser why u don't reply to my E-mail ???? I think that u'r job is to resolve our problems , or just take a money |
10-27-2006, 20:46 | #11 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Read in Cruiser User' Guide : Quote:
To Cruiser Team, Help With My Cruiser Box | ASHRIFF | Cruiser Suite | 12 | 03-16-2011 21:24 |
Problem with my Cruiser Suite | ferrari6 | Cruiser Suite | 7 | 11-08-2008 08:53 |
Whats the problem with my cruiser? help!!! | cellkeith | Cruiser Suite | 16 | 11-08-2006 06:53 |
Whats the problem with my cruiser? help!!! | cellkeith | Cruiser Suite | 0 | 11-03-2006 04:05 |
I Have A Problem With My Cruiser | mitko8103 | Cruiser Suite | 1 | 05-09-2006 09:21 |
