03-09-2005, 02:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2003
Member: 38307 Status: Offline Thanks Meter: 66 | Cruiser V3.20 Problem!!!! Some time it's start to read and this is what happened. Last edited by yueyo; 03-09-2005 at 03:52. |
03-09-2005, 04:44 | #4 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Hmmm, it does that, then crashes? I haven't had that problem ever, so I doubt it's a major bug in Cruiser. Make sure you're using the latest cable drivers to start with, also try unticking the "Analyse configuration" and see if that helps you at all. Also try disabling any anti-virus software you have (probably uninstall it is the best way to test) though I have not heard of Anti-virus software causing conflicts with Cruiser. |
03-09-2005, 06:34 | #7 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 53
Member: 87481 Status: Offline Thanks Meter: 3 | Mine is working fine under XP pro, tested on 2 PCs, with & without SP2. McAfee VirusScan Enterprice 8 & windows security features is active on both PC, still V3.20 running smoothly. Did you try to use the .exe of the previous version under v3.20 installation? If it works and the .exe of V3.20 don't, then may G_o-d be with you.. |
03-09-2005, 07:09 | #9 (permalink) |
Member: 87481 Status: Offline Thanks Meter: 3 | How about playing with your com-port setting (lower speed, etc.)? this is just my experience when I made my own application, nothing to do with cruiser, but worth to try since the master is not here. |
03-10-2005, 02:01 | #10 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Try turning off the "analyze configuration" option before attaching the phone. If anyone wants to see Cruiser crashed, just upload V800 EROM into a Z1010 CID29 and attach... I had no time to fix it yet. |
03-10-2005, 02:04 | #11 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Yueyo's problem can't be solved by any of the usual methods. We spoke on the phone today. The program crashes completely, as exemplified in his screenshot. He also has an 802SE with corrupt RSA certificate, I think. It will not boot normally, but Cruiser attaches. Repair files and EEP do not seem to solve it. Strange thing is he is running XPSP2 and had no problems before 3.0. 3.0 and 3.20 work fine for me on Win2k. Could this be an OS-related problem? |
03-10-2005, 02:37 | #12 (permalink) | |
Member: 38307 Status: Offline Thanks Meter: 66 | Quote:
Yes, it boot okay but I still can't fix the damage V802 SE. I can flash the Recovery_3G_Series_Red29.crec without problem but when I try to flash the V800_EROM_RedCID29.cv8sw it shows "Script error: Flash error [3.20 beta.59]" | |
03-10-2005, 05:18 | #14 (permalink) |
Member: 87481 Status: Offline Thanks Meter: 3 | Hehe.. your problem is solved by the first responder, muppet, I tought his suggestion didn't work. I believe I saw Lead mention about the "analyze configuration" a while ago in another thread. Anyway, keep sharing, I'd love to learn more everyday. |
03-10-2005, 06:28 | #15 (permalink) | |
We got it fixed by using Lead suggestion plus make sure that your battery is fully charge. Thank you very much for all your help Lead & muppet. | |
cruiser 13.20 server problem.??? | jayanthabandara | Cruiser Suite | 5 | 12-26-2008 11:34 |
Problem with K510 CID50 & Cruiser 13.20 | g-zona | Cruiser Suite | 9 | 11-07-2008 17:14 |
--== Cruiser 13.20 - UC-20 cable is now supported ==-- | Mainboard | Cruiser Suite | 40 | 07-09-2008 07:22 |
Problem with Cruiser 9.20 | Ryu | Cruiser Suite | 6 | 02-26-2006 17:34 |
cruiser 2.10 can't unlock z500a (but cruiser 2.20 already can) | baomobile | Cruiser Suite | 75 | 03-03-2005 14:17 |
