Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 03-06-2009, 08:49   #16 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 64
@cruiser team
Any chance to upload S302 flash files?
Old 03-06-2009, 08:50   #17 (permalink)
Member: 67277
Thanks Meter: 5,588
Originally Posted by sharmin View Post
but problem with server still now
  13:16:56  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  13:16:56  Initializing...
! 13:16:56  1. Choose the phone model
! 13:16:56  2. For flashing, select flash files and additional options
! 13:16:56  3. Double-click on the appropriate device (serial cable)
! 13:16:56  - or connect the phone via USB while holding its C button
! 13:17:12  Your card activation ID is: 0B6B0xxxxxxxxxxxxxxxxxx8A095-07
  13:17:12  Communicating with server…
E 13:17:14  Error: 0x4A84684E
E 13:17:14  Error: 0xFEC2C417
E 13:17:14  Error: 0xB3A47971
E 13:17:14  Login to server failed
E 13:17:15  Failed!
! 13:17:15  To report errors right-click this window
Login to server failed means that you should check the spelling of your password.
Old 03-06-2009, 08:51   #18 (permalink)
Member: 67277
Thanks Meter: 5,588
Originally Posted by g-zona View Post
@cruiser team
I'll check what we can do about this.
The Following User Says Thank You to Mizar For This Useful Post:
Old 03-06-2009, 09:24   #19 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 64
Settings:
Server address: 60.54.216.58 Port: 80
And you get this error:
  09:21:04  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  09:21:04  Initializing...
! 09:21:04  1. Choose the phone model
! 09:21:04  2. For flashing, select flash files and additional options
! 09:21:04  3. Double-click on the appropriate device (serial cable)
! 09:21:04  - or connect the phone via USB while holding its C button
! 09:21:15  Your card activation ID is: xxxxx-07
  09:21:15  Communicating with server…
E 09:21:17  Error: 0x4A84684E
E 09:21:17  Error: 0xFEC2C417
E 09:21:17  Error: 0xB3A47971
E 09:21:17  Login to server failed
E 09:21:17  Failed!
! 09:21:17  To report errors right-click this window
Settings:
Server address: 60.54.216.58 Port: 9001
And you get this:
  09:23:27  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  09:23:27  Initializing...
! 09:23:27  1. Choose the phone model
! 09:23:27  2. For flashing, select flash files and additional options
! 09:23:27  3. Double-click on the appropriate device (serial cable)
! 09:23:27  - or connect the phone via USB while holding its C button
! 09:23:32  Your card activation ID is: xxxxx-07
  09:23:32  Communicating with server…
  09:23:39  Remainig credit (supreme): 8.40
  09:23:39  Done.
So I guess that his problem is most likely in his server port, cause default is 80 instead of 9001.
Old 03-06-2009, 09:44   #20 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
using 9001 instead of 80 login ok now
but unlocking error
here is log
  14:41:36  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  14:41:36  Initializing...
! 14:41:36  1. Choose the phone model
! 14:41:36  2. For flashing, select flash files and additional options
! 14:41:36  3. Double-click on the appropriate device (serial cable)
! 14:41:36  - or connect the phone via USB while holding its C button
  14:41:41  Connecting via Generic FTDI Cable (COM10)…
  14:41:41  Device driver version: 2.2.4.0
  14:41:41  Device driver date: 6-27-2007
! 14:41:41  Connect the phone now
  14:41:41  Connecting to the baseband CPU...
  14:41:46  Entering baseband CPU service mode...
  14:41:47  IMEI: 356xxxxxxxxx6299
  14:41:47  Phone type: K330
  14:41:47  CDA info: 1217-4992 R3A
  14:41:47  Phone software: 1211-9436 R1CD001
  14:41:47  Sending loader...
E 14:42:49  Error: 0x4835B81D
E 14:42:49  Error: 0xE09A592A
E 14:42:49  Error: 0xB40A84A8
E 14:42:49  Error: 0xBD26CE5A
E 14:42:49  Error: 0x1D5EF9BD
E 14:42:49  Error: 0x93D2F1E5
E 14:42:49  Error: 0xC41C185B
E 14:42:49  Failed!
! 14:42:49  Please disconnect battery and cable from the phone!
! 14:42:49  To report errors right-click this window
Old 03-06-2009, 09:50   #21 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 64
Try signed mode unlock! (need supreme credit)
Old 03-06-2009, 09:58   #22 (permalink)
Member: 533827
Thanks Meter: 34
sir Mizar i have 25 old credit left dongle 07 how to convert this is to SUPREME LOG?thanks
System diagnostics passed.
Version 13.20 ready!
Do NOT connect the phone at this time!
Connecting via SEMC DCU-60...
Connecting to server...
Connection established, checking server status...
Server version: 2.55
Retrieving credit info...
Your ID: xxxxxxxxxx
Credit: 25
_Prepaid time: 0d 0:0:0
_Free operations: 0
Time: 00:00:04
Old 03-06-2009, 10:15   #23 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
s1 flasher and unlocker 2.01
signed mode checked
checked uses server and supreme credit
pls check here again error !!!!!!!
Old 03-06-2009, 10:30   #24 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
all ready 3 set returned from yesterday for this problem
pls tell me where is the problem !!!!!
Old 03-06-2009, 10:39   #25 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
full flash the phone to the latest version and try again.
Old 03-06-2009, 10:42   #26 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 81
how many cradit for 1 unlock?
Old 03-06-2009, 10:49   #27 (permalink)
Member: 335082
Thanks Meter: 69
After unlock phone dead.
  09:45:08  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  09:45:08  Initializing...
! 09:45:08  1. Choose the phone model
! 09:45:08  2. For flashing, select flash files and additional options
! 09:45:08  3. Double-click on the appropriate device (serial cable)
! 09:45:08  - or connect the phone via USB while holding its C button
  09:45:24  Connecting via SEMC USB Flash Device (USB7)…
  09:45:24  Device driver version: 2.2.0.0
  09:45:24  Device driver date: 9-18-2008
  09:45:24  Connecting to the baseband CPU...
  09:45:24  Entering baseband CPU service mode...
  09:45:25  IMEI: 358****
  09:45:25  Phone type: T303
  09:45:25  CDA info: 1210-3321 R9A
  09:45:25  Phone software: 1209-8242 R2CA005
  09:45:25  Sending loader...
  09:45:31  Reading TA…
  09:45:32  Communicating with server…
  09:45:36  Remainig credit (supreme): 1.00
  09:45:39  Remainig credit (supreme): 0.60
  09:45:39  Searching...
  09:45:40  Unlocking…
  09:45:41  Turning off the phone...
  09:45:41  Done.
! 09:45:41  Please disconnect battery and cable from the phone!
Old 03-06-2009, 12:36   #28 (permalink)
shaheen15's Avatar
Member: 137426
Thanks Meter: 50
What should i fill in password field. I cant remember to have a password on my credits????
Old 03-06-2009, 13:14   #29 (permalink)
Member: 670274
Thanks Meter: 165
The phone freezes while sending the loader. Is the battery charged enough? Isn't there a hardware problem with the cable?
but unlocking error
here is log
E 14:42:49  Failed!
Old 03-06-2009, 13:17   #30 (permalink)
Member: 670274
Thanks Meter: 165
We need to inspect the particular firmware. Meanwhile you can flash any our supported firmware to the phone to revive it.
GLaDOS
  09:45:40  Unlocking…
  09:45:41  Done.
.: News: CruiserSuite S1 Flasher & Unlocker v3.00 released - Satio now supported :. Mizar Cruiser Suite 40 11-04-2017 11:14
.: News: CruiserSuite S1 Flasher & Unlocker v3.00 released - Satio now supported :. Mizar Service Products News & Updates 0 12-19-2009 11:36
.: News: S1 Flasher & Unlocker v2.10 - Instant S1 unlock, AID 03 Neptune supported :. Mizar Cruiser Suite 7 09-29-2009 08:44
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock in many languages :. Mizar Cruiser Suite 71 09-16-2009 06:59
.: New release: CruiserSuite S1 Flasher & Unlocker - Instant unlock now supported :. Mizar Service Products News & Updates 1 03-06-2009 00:42
Page generated in 0.71858 seconds with 9 queries
