Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 03-06-2009, 14:12   #31 (permalink)
sidah-gsm's Avatar
Member: 600493
Sonork: 0550106737
Thanks Meter: 39
BIG BIG BIG THANK TO MIZAR
  14:09:25  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  14:09:25  Initializing...
! 14:09:25  1. Choose the phone model
! 14:09:25  2. For flashing, select flash files and additional options
! 14:09:25  3. Double-click on the appropriate device (serial cable)
! 14:09:25  - or connect the phone via USB while holding its C button
  14:09:38  Connecting via SEMC USB Flash Device (USB2)…
  14:09:38  Device driver version: 2.1.0.0
  14:09:38  Device driver date: 3-20-2008
  14:09:39  Connecting to the baseband CPU...
  14:09:39  Entering baseband CPU service mode...
  14:09:39  IMEI: 35653502266034
  14:09:39  Phone type: W302
  14:09:39  CDA info: 1212-2192 R12A
  14:09:39  Phone software: 1207-2375_GENERIC R1AC004
  14:09:39  Sending loader...
  14:09:43  Reading TA…
  14:09:46  Communicating with server…
  14:09:51  Remainig credit (supreme): 11.17
  14:09:54  Remainig credit (supreme): 10.77
  14:09:54  Searching...
  14:09:54  Unlocking…
  14:09:55  Turning off the phone...
  14:09:55  Done.
! 14:09:55  Please disconnect battery and cable from the phone!
Old 03-06-2009, 15:28   #32 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 64
Originally Posted by shaheen15 View Post
What should i fill in password field. I cant remember to have a password on my credits????
Start -> RUN -> regedit
Then open:
HKEY_CURRENT_USER\Software\Cruiser Team\SeFullUnlocker\Internet
Find a string value named "Password" and copy from Data field. There you have it.
The Following User Says Thank You to g-zona For This Useful Post:
Old 03-06-2009, 16:46   #33 (permalink)
shaheen15's Avatar
Member: 137426
Thanks Meter: 50
Is it possible to unlock K330 with RJ45 cable. I keep getting error messages. Or can i use USB for K330
Old 03-06-2009, 20:22   #34 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
ohhh what's wrong with me I can't understand
it's giving error till now !!!!!!
  01:19:41  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  01:19:41  Initializing...
! 01:19:41  1. Choose the phone model
! 01:19:41  2. For flashing, select flash files and additional options
! 01:19:41  3. Double-click on the appropriate device (serial cable)
! 01:19:41  - or connect the phone via USB while holding its C button
  01:19:59  Connecting via Generic FTDI Cable (COM14)…
  01:19:59  Device driver version: 2.0.0.0
  01:19:59  Device driver date: 5-19-2006
! 01:19:59  Connect the phone now
  01:20:00  Connecting to the baseband CPU...
  01:20:07  Entering baseband CPU service mode...
  01:20:08  IMEI: 3565xxxxxxx299
  01:20:08  Phone type: K330
  01:20:08  CDA info: 1217-4992 R3A
  01:20:08  Phone software: 1211-9436 R1CD001
  01:20:08  Sending loader...
E 01:21:10  Error: 0xE1E2479D
E 01:21:10  Error: 0x4835B81D
E 01:21:10  Error: 0xE09A592A
E 01:21:10  Error: 0xB40A84A8
E 01:21:10  Error: 0xBD26CE5A
E 01:21:10  Error: 0x1D5EF9BD
E 01:21:10  Error: 0x93D2F1E5
E 01:21:10  Error: 0xC41C185B
E 01:21:10  Failed!
! 01:21:10  Please disconnect battery and cable from the phone!
! 01:21:10  To report errors right-click this window
Old 03-06-2009, 20:37   #35 (permalink)
Black_Daimond's Avatar
Member: 179391
Thanks Meter: 57
I'm having exactly the same problem
E 01:21:10  Failed!
  15:31:43  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  15:31:43  Initializing...
! 15:31:43  1. Choose the phone model
! 15:31:43  2. For flashing, select flash files and additional options
! 15:31:43  3. Double-click on the appropriate device (serial cable)
! 15:31:43  - or connect the phone via USB while holding its C button
  15:32:03  Connecting via Cruiser UC-10 Cable (COM14)…
  15:32:03  Device driver version: 1.0.2176.0
  15:32:03  Device driver date: 12-12-2005
! 15:32:03  Connect the phone now
  15:32:03  Connecting to the baseband CPU...
  15:32:06  Entering baseband CPU service mode...
  15:32:08  IMEI: 3565xxxxxxxx47
  15:32:08  Phone type: K330
  15:32:08  CDA info: 1218-3639 R4A
  15:32:08  Phone software: 1211-9436 R1CD001
  15:32:08  Sending loader...
E 15:33:09  Error: 0x4835B81D
E 15:33:09  Error: 0xE09A592A
E 15:33:09  Error: 0xB40A84A8
E 15:33:09  Error: 0xBD26CE5A
E 15:33:09  Error: 0x1D5EF9BD
E 15:33:09  Error: 0x93D2F1E5
E 15:33:09  Error: 0xC41C185B
E 15:33:09  Failed!
! 15:33:09  Please disconnect battery and cable from the phone!
! 15:33:09  To report errors right-click this window
If any of you having this problem and knows how to solve it, please share with us. Thanks!
Old 03-06-2009, 21:02   #36 (permalink)
Member: 179391
Thanks Meter: 57
I have now try to reflash phone with a cruiser available flash, but...
  15:38:38  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  15:38:38  Initializing...
! 15:38:38  1. Choose the phone model
! 15:38:38  2. For flashing, select flash files and additional options
! 15:38:38  3. Double-click on the appropriate device (serial cable)
! 15:38:38  - or connect the phone via USB while holding its C button
  15:39:23  Connecting via Cruiser UC-10 Cable (COM14)…
  15:39:23  Device driver version: 1.0.2176.0
  15:39:23  Device driver date: 12-12-2005
! 15:39:23  Connect the phone now
  15:39:23  Connecting to the baseband CPU...
  15:39:31  Entering baseband CPU service mode...
  15:39:32  IMEI: 3565xxxxxxxx47
  15:39:32  Phone type: K330
  15:39:32  CDA info: 1218-3639 R4A
  15:39:32  Phone software: 1211-9436 R1CD001
  15:39:32  Sending loader...
  15:39:50  Reading TA…
  15:39:53  About to flash 17 MB of data…
  15:39:53  Writing files…
E 15:44:21  Error: 0xDDD701AA
E 15:44:21  Error: 0x4835B81D
E 15:44:21  Error: 0xE09A592A
E 15:44:21  Error: 0xB40A84A8
E 15:44:21  Error: 0x669C5698
E 15:44:21  Error: 0x17E98CB1
E 15:44:21  Error: 0x7C7E4156
E 15:44:21  Error: 0x764E5397
E 15:44:21  Error: 0xC51C2544
E 15:44:21  Error: 0x9BB5AB51
E 15:44:21  Error: 0x55D37C39
E 15:44:21  Error: 0x568034E8
E 15:44:21  Incompatible flash file or flashing error
E 15:44:21  Failed!
! 15:44:21  Please disconnect battery and cable from the phone!
! 15:44:21  To report errors right-click this window
Old 03-07-2009, 08:05   #37 (permalink)
Member: 67277
Thanks Meter: 5,588
Hi, we will look at it by monday morning.
The Following 2 Users Say Thank You to Mizar For This Useful Post:
Old 03-08-2009, 14:50   #38 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 224
We are waiting for the best SUPPORTER
Old 03-08-2009, 18:12   #39 (permalink)
SmilingFace's Avatar
Member: 188445
Thanks Meter: 86
E 01:21:10  Failed!
to patch unock the fone u should have same version of file.u download the only main file 4m support site.select the file and unlock with signed mode n use server.try this method, im sure ur problem is sloved.tested 10000000000%.
Old 03-08-2009, 20:20   #40 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
tried with all possible ways
but no luck for me
@ Mizar . waiting for ur reply on monday .......
Old 03-09-2009, 11:14   #41 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
whats the difrent between signed and unsigned mode ??
Old 03-09-2009, 12:18   #42 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 64
New frmware is done by Unlock-by-Patch via Server, in signed mode. You really need to read first post.
Old 03-09-2009, 13:22   #43 (permalink)
Member: 670274
Thanks Meter: 165
K330 error sequence ...
The error sequence posted by sharmin and Black_Daimond
Error: 0x4835B81D
Error: 0xE09A592A
Error: 0xB40A84A8
Error: 0xBD26CE5A
Error: 0x1D5EF9BD
Error: 0x93D2F1E5
Error: 0xC41C185B
needs a deeper inspection. Anybody who experience this, contact me via PM, please.
GLaDOS
Old 03-09-2009, 19:44   #44 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
thanks I will inform u , customer will bring that tomorrow
Old 03-10-2009, 13:37   #45 (permalink)
shaheen15's Avatar
Member: 137426
Thanks Meter: 50
3 x k330 giving all the same problem
  12:14:13  SE S1 Flasher & Unlocker v2.01 by Cruiser Team
  12:14:13  Initializing...
! 12:14:13  1. Choose the phone model
! 12:14:13  2. For flashing, select flash files and additional options
! 12:14:13  3. Double-click on the appropriate device (serial cable)
! 12:14:13  - or connect the phone via USB while holding its C button
  12:14:27  Connecting via Cruiser UC-10 Cable (COM15)…
  12:14:27  Device driver version: 1.0.2176.0
  12:14:27  Device driver date: 12-12-2005
! 12:14:27  Connect the phone now
  12:14:28  Connecting to the baseband CPU...
  12:14:28  Entering baseband CPU service mode...
  12:14:29  IMEI: 356574021
  12:14:29  Phone type: K330
  12:14:29  CDA info: 1218-3639 R4A
  12:14:29  Phone software: 1211-9436 R1CD001
  12:14:29  Sending loader...
E 12:15:31  Error: 0x4835B81D
E 12:15:31  Error: 0xE09A592A
E 12:15:31  Error: 0xB40A84A8
E 12:15:31  Error: 0xBD26CE5A
E 12:15:31  Error: 0x1D5EF9BD
E 12:15:31  Error: 0x93D2F1E5
E 12:15:31  Error: 0xC41C185B
E 12:15:31  Failed!
! 12:15:31  Please disconnect battery and cable from the phone!
! 12:15:31  To report errors right-click this window
.: News: CruiserSuite S1 Flasher & Unlocker v3.00 released - Satio now supported :. Mizar Cruiser Suite 40 11-04-2017 11:14
.: News: CruiserSuite S1 Flasher & Unlocker v3.00 released - Satio now supported :. Mizar Service Products News & Updates 0 12-19-2009 11:36
.: News: S1 Flasher & Unlocker v2.10 - Instant S1 unlock, AID 03 Neptune supported :. Mizar Cruiser Suite 7 09-29-2009 08:44
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock in many languages :. Mizar Cruiser Suite 71 09-16-2009 06:59
.: New release: CruiserSuite S1 Flasher & Unlocker - Instant unlock now supported :. Mizar Service Products News & Updates 1 03-06-2009 00:42
Page generated in 0.45082 seconds with 9 queries
