10-09-2006, 02:43 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: mladenovas,serbia Age: 45
Member: 67014 Status: Offline Thanks Meter: 1 | dead lg u8550 i have one lg u8550 killed by setool by patching hi stops on flash. after that i conect him on cruser and make unlock rsa reconect after that and start flash it but hi stoped every time at second flash any idea about that???any solution??? p.s. i"ll tried with and without tp thanks regards zoran |
10-09-2006, 05:21 | #2 (permalink) |
Member: 67014 Status: Offline Thanks Meter: 1 | mr Lead or anyone help please here is log rimary certificate color: Red Secondary certificate not found. GDFS configuration not found. OSE configuration found. TestProgram configuration found. Done. Phone hardware initialized OK [ --- Flash Main Firmware --- ] [ --- Flash Main Firmware --- ] Flash file: "U8550_V10a_Italy_Red54.flp" Waiting for flash file to load... Configuring applet... Enhanced algorithm: ON Check erase: ON Verify data: ON No erase: OFF Preparing to program flash... Programming flash... Primary certificate has been overwritten. [ --- Flash Main Firmware --- ] Flash file: "U8550_V10a_Italy_Red54.flp" Waiting for flash file to load... Preparing to program flash... Programming flash... [ --- Change Certificate Color --- ] Replacing primary certificate... Phone automatically detached. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 230400Bd Trying recovery applet... Disconnect the testpoint! All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 230400Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 230400Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 230400Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! Sending applet body... Time spent entering bootstrap: 8s Initializing phone hardware... Applet ID: 040422 0732 LLECXC1325413_CERTLOADER R3L Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 54 Defeating RSA protection... Defeated! Sending applet... Applet ID: 060207 0226 CRUCXC1325712_PRODUCTION STD Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 54 Analyzing configuration... Primary certificate not found. Secondary certificate not found. GDFS configuration not found. OSE configuration not found. TestProgram configuration not found. Done. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "U8550_V10a_Italy_Red54.flp" Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:14:02 Preparing to program flash... Programming flash... and than this Applet error: ERROR|EraseBlock| 04 FF FF FF 21 Error flashing block at address: 0x22020000 Script error: Flash error [10.00.75] |
10-09-2006, 09:09 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Brother if flashing stops always at the same address then its hardware.....As this is explaind in the sticky....And need to change flash ic or rehot it....And if flashing stops on different addresses then u have to low down or change the baudrate!(Sometimes Sw Bug)....So see which one is ur problem and try as i have suggested and post here the results! Br Muneeb Akhtar Raza |
How to flash dead lg u8550 | sairat | FuriousGold | 10 | 03-08-2018 17:00 |
Unlock LG U880 and LG U8550 Phones with Twister + HWK.... | kanuni | HWK | 4 | 12-19-2005 21:18 |
Lg U8360 Lg U8550 2g sim | iverson | SonyEricsson (USB-Smart) | 3 | 12-04-2005 16:45 |
lg u8550 loader & Firmware released! | tommaso | SonyEricsson (USB-Smart) | 4 | 12-04-2005 12:50 |
