04-08-2009, 13:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: SWEDEN, Malmoe Age: 45
Member: 10228 Status: Offline Thanks Meter: 2 | Error and error and error, please HELP! Code: 13:55:18 SE A2 Flasher v1.08 by Cruiser Team 13:55:18 Initializing... ! 13:55:18 1. Choose the phone model ! 13:55:18 2. Select main firmware flash file (*.a2sw) ! 13:55:18 3. Select raw FS flash file (*.a2fs) ! 13:55:18 4. Please connect the phone while holding its C button… 13:55:30 Connecting via SEMC USB Flash Device (USB1)… 13:55:30 Device driver version: 2.2.0.2 13:55:30 Device driver date: 12-5-2008 13:55:30 Connecting to the baseband CPU... 13:55:30 Entering baseband CPU service mode... 13:55:30 Detected chipset: DB3210 P1A/P1B 13:55:30 Boot mode: EROM 13:55:30 EROM version: 1200-4341 SEMCBOOT R6A018 13:55:30 Sending loader... 13:55:32 IMEI: 00440107225678 13:55:32 OTP CID: 49 13:55:32 OTP area status: Locked 13:55:32 Product type: Prototype 13:55:32 Effective color: Red 13:55:33 Sending loader... 13:55:39 Starting file system… E 13:55:40 Error: 0xB79ED6E8 E 13:55:40 Error data: 0xB79ED6E8 - 00000002:0001 E 13:55:40 Error: 0x10C03741 E 13:55:40 Error: 0xC93CBD93 E 13:55:40 Failed to start filesystem E 13:55:40 Failed! ! 13:55:40 Please disconnect battery and cable from the phone! ! 13:55:40 To report errors right-click this window How do I unbrick this c905 prototype? Regards |
04-08-2009, 13:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | use Ultimate Unlocker 3.07, choose C905 and unlock it with setting certificate to red up. then use A2 Flasher 1.09 and choose correct flash files. |
04-08-2009, 13:51 | #3 (permalink) | |
Member: 10228 Status: Offline Thanks Meter: 2 | Quote:
Code: 14:35:55 SE Ultimate Unlocker v3.07 by Cruiser Team 14:35:55 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 14:35:55 Initializing... ! 14:35:55 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 14:35:55 2. Choose the phone model ! 14:35:55 3. Select the desired options ! 14:35:55 4. Please connect the phone either via USB while holding 2-5… ! 14:35:55 - or via a serial cable and double-click on it in the device list 14:36:00 Selected phone: C905 14:36:00 Connecting via Generic EMP USB Flash Device (USB1)… 14:36:00 Device driver version: 2.2.0.2 14:36:01 Device driver date: 12-5-2008 14:36:01 Connecting to the baseband CPU... 14:36:01 Entering baseband CPU service mode... 14:36:02 Detected chipset: DB3210 P1A/P1B 14:36:02 Boot mode: ROM 14:36:02 Sending loader... 14:36:04 IMEI: 00440107225678 14:36:04 OTP CID: 49 14:36:04 Product type: Prototype 14:36:04 Effective color: Red 14:36:05 Sending loader... 14:36:09 Communicating with server… 14:36:14 Remainig credit (supreme): 0.00 14:36:20 Remainig credit (supreme): 0.00 14:36:20 Converting phone to blue… 14:36:21 Restarting phone … 14:36:25 Sending loader... 14:36:28 IMEI: 00440107225678 14:36:28 OTP CID: 49 14:36:28 Product type: Prototype 14:36:28 Effective color: Blue 14:36:29 Sending loader... 14:36:32 Writing flash… 14:36:33 Code NCK for relock: 5295061147374087 14:36:33 Code NSCK for relock: 1618208755252836 14:36:33 Code SPCK for relock: 7137841974009981 14:36:33 Code CCK for relock: 8692483993243927 14:36:33 Code PCK for relock: 2936262896361867 14:36:33 Code ESLCK for relock: 6336919805339249 14:36:33 Code NCK for unlock: 7621982102629967 14:36:33 Code NSCK for unlock: 9815524846982268 14:36:33 Code SPCK for unlock: 2645176422049024 14:36:33 Code CCK for unlock: 2087599252419669 14:36:33 Code PCK for unlock: 5097225377986179 14:36:33 Code ESLCK for unlock: 8633292539216347 14:36:33 To enter a code, type < * * < on the phone with SIM-card inserted 14:36:33 Converting phone to red… 14:36:34 Turning off the phone... 14:36:36 Done. Code: 14:38:32 SE A2 Flasher v1.09 by Cruiser Team 14:38:32 Initializing... ! 14:38:32 1. Choose the phone model ! 14:38:32 2. Select main firmware flash file (*.a2sw) ! 14:38:32 3. Select raw FS flash file (*.a2fs) ! 14:38:32 4. Optionally select customization file (*.zip) ! 14:38:32 5. Please connect the phone while holding its C button… 14:41:05 Connecting via SEMC USB Flash Device (USB1)… 14:41:05 Device driver version: 2.2.0.2 14:41:05 Device driver date: 12-5-2008 14:41:05 Connecting to the baseband CPU... 14:41:05 Entering baseband CPU service mode... 14:41:06 Detected chipset: DB3210 P1A/P1B 14:41:06 Boot mode: EROM 14:41:06 EROM version: 1200-4341 SEMCBOOT R6A018 14:41:06 Sending loader... 14:41:07 IMEI: 00440107225678 14:41:07 OTP CID: 49 14:41:07 OTP area status: Locked 14:41:07 Product type: Prototype 14:41:07 Effective color: Red 14:41:08 Sending loader... 14:41:15 Importing flash files… 14:41:29 About to flash 123 MB of data… 14:41:29 Programming flash… 14:41:29 C:\Documents and Settings\Administratör\Skrivbord\C905i_1205-9079_Generic_R1BA034_Red52.a2sw 14:44:17 Final verification… 14:44:30 Programming flash… 14:44:30 C:\Documents and Settings\Administratör\Skrivbord\C905i_1205-9083_Nordic_R1BA034_Red52.a2fs 14:47:50 Final verification… 14:48:06 Starting file system… E 14:48:06 Error: 0xB79ED6E8 E 14:48:06 Error data: 0xB79ED6E8 - 00000002:0001 E 14:48:06 Error: 0x10C03741 E 14:48:06 Error: 0xC93CBD93 E 14:48:06 Failed to start filesystem E 14:48:06 Failed! ! 14:48:06 Please disconnect battery and cable from the phone! ! 14:48:06 To report errors right-click this window thx anyway! Regards | |
04-08-2009, 14:37 | #4 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | I have done a few pcs of prototype A2 phones..in your case it seems that someone gemaged gdfs. can you turn the phone on? is the battery fully charged? |
04-09-2009, 15:39 | #6 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | It seems that GDFS had been demaged. The only one way is to use SETool. Cruiser suite doesn´t support repair the whole gdfs yet. |
M-Bus Errors on UFS with HWK please help.. | alexbrowne | HWK | 0 | 12-16-2005 20:58 |
U8330 error while flashing last flash.please help!!! | crossings | Cruiser Suite | 9 | 12-03-2005 17:25 |
error 58- driver type invalid please help | mohammed | VygisToolbox | 4 | 11-10-2004 21:00 |
Error when flashing to 8310, please help | hoang | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 11-06-2002 00:13 |
