02-03-2009, 21:54 | #1 (permalink) |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Error on stage 2, how to solve. . .??? (K800 Red blink) (K800 Red blink) Log is here: Code: 01:43:48 SE Testpoint Full Unlocker v1.03 by Cruiser Team 01:43:48 Initializing... ! 01:43:49 1. Choose the phone model ! 01:43:49 2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation) ! 01:43:49 3. If you want to perform restore, select GDFS backup file (*.gdfs) ! 01:43:49 4. Connect the data cable and the power supply clips to the phone ! 01:43:49 5. Double-click on cruiser UC-20 test-point cable 01:44:15 Connecting via Cruiser UC-20 Cable (COM3)… 01:44:15 Device driver version: 2.4.6.0 01:44:15 Device driver date: 3-13-2008 01:44:19 Connecting to the baseband CPU... 01:44:19 Entering baseband CPU service mode... 01:44:19 Detected chipset: DB2020 01:44:19 Boot mode: ROM 01:44:22 Sending loader... 01:44:23 Sending loader... 01:44:24 Writing flash… ! 01:44:27 Connect the Testpoint Stage 1 01:44:42 Testpoint connected successfully ! 01:44:42 You may release the test-point now 01:44:42 Sending loader... 01:44:56 Writing flash… 01:44:57 Restarting phone … ! 01:44:57 Connect the Testpoint Stage 2 01:45:11 Testpoint connected successfully 01:45:11 Connecting to the baseband CPU... 01:45:11 Entering baseband CPU service mode... 01:45:11 Sending loader... E 01:45:12 Error: 0x5EC13786 E 01:45:12 Error: 0xB15407B1 E 01:45:12 Failed! ! 01:45:12 Please disconnect battery and cable from the phone! ! 01:45:12 To report errors right-click this window plz assist me how to remove this problem, is there any problem with my TP Cable (box) or some other problem ?????? B.R., kashi4gul |
02-04-2009, 05:05 | #4 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
WBR, DebeliaMark, BG | |
02-06-2009, 08:10 | #6 (permalink) |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | cruiser team forced you to use credit, ultima unlocker, tp not stable because managed by software it self,db more table ------------------------------- -- Reading Info--------------------------------------------------------------- User selected phone K800 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone K800 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... Error : Failed. --- Loading GDFS file---------------------------------------------------------- Loading "E:\DREAMBOX\ERICSSON\GDFS\K800_gdfs.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone K800 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Finalizing ... Stage 2 completed succesfully Done. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Finalizing ... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Reading GDFS... Error : Failed. --- Loading GDFS file---------------------------------------------------------- Done. --- Write GDFS----------------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359088-01-799613-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380B07A15D037C3 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
02-07-2009, 22:37 | #7 (permalink) | |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
See my Log: (K800 Successfully Rapair Via TP with SETool) Code: v0.915026/UNI CARD SERIAL: xxxxxx Loaded 51 flash descriptors TESTPOINT REPAIR STAGE #1 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908801088228 CERT:N/A FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 PREPARING... ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY:D RELEASE TP #2 AND PRESS "READY" INT LDR:DB2020_PRELOADER_FOR_SETOOL2 WRITING EROM... DONE Elapsed: 19 secs. B.R., kashi4gul Last edited by kashi4gul; 02-07-2009 at 22:43. | |
Wrong Software on a36 :( How to solve this shi*** ? | CyberKareca | x1x to x45/x50 | 38 | 11-09-2009 04:38 |
EUB Power Surge on Hub Port?how to solv | rana4star | Easy-Unlocker | 3 | 09-30-2008 02:49 |
Final checksum error when flashing p900; how to solve? | monsterpassword | Cruiser Suite | 2 | 05-29-2007 00:08 |
