06-16-2006, 16:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia Age: 42
Member: 17711 Status: Offline Thanks Meter: 1,858 | Error on writting CID49 flash file to CID36 K750 phone. [ --- Flash Raw File System --- ] Flash file: "K750i_CXC125953_EMEA1_R1CA021_Red49.ck75fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:03:06 Flash process done. [ --- Customize File System --- ] Sending CS applet... The applet ignored baudrate change request! No response from applet Invalid response |
06-16-2006, 17:53 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: albania Age: 52
Member: 22586 Status: Offline Thanks Meter: 36 | Did he charge colour to brown before flashing ? If he just unlocked RSA and flashed FW & FS, then he must detach phone unlock RSA again and customise phone. BR Mike |
06-19-2006, 09:32 | #4 (permalink) |
Member: 17711 Status: Offline Thanks Meter: 1,858 | Yes, he did. Code: System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Trying CID36 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing RSA protection... RSA protection is normal. Phone hardware initialized OK [ --- Repair Certificate --- ] Preparing to program flash... Programming flash... Time: 00:00:01 Flash process done. [ --- Change Certificate Color --- ] Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F Sending applet... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Defeated! Sending applet... Applet ID: Prepare yourself for a nice surprise! Initializing applet... Replacing primary certificate... Certificate replaced successfully. Turning off phone... Phone automatically detached. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Trying CID36 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing RSA protection... RSA protection is normal. Phone hardware initialized OK [ --- Detach Phone --- ] All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Brown Flash certificate: A1_DB2010_36_BROWN Trying Brown CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Brown Secondary certificate not found. GDFS configuration not found. OSE configuration not found. TestProgram configuration not found. Done. The phone contains recovery certificate! You MUST repair EROM! Analyzing RSA protection... RSA protection is normal. Phone hardware initialized OK [ --- Repair EROM --- ] Preparing to program flash... Baudrate = 921600Bd Programming flash... Primary certificate has been overwritten. Time: 00:00:01 Flash process done. [ --- Flash Main Firmware --- ] Flash file: "K750i_FullGDFS_Brown36.ck75sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:00:14 Flash process done. [ --- Detach Phone --- ] All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Brown Flash certificate: A1_DB2010_36_BROWN Trying Brown CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is normal. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "K750i_CXC125952_EU1_R1CA021_Red49.ck75sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Programming flash... Time: 00:04:40 Flash process done. [ --- Flash Raw File System --- ] Flash file: "K750i_CXC125953_EMEA1_R1CA021_Red49.ck75fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:02:33 Flash process done. [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V23 Initializing CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V23 Baudrate = 921600Bd Starting up GDFS service... (Could not start GDFS service) |
06-19-2006, 09:38 | #5 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Slovakia Age: 46
Member: 5155 Status: Offline Thanks Meter: 7 | Quote:
BR krtko | |
06-19-2006, 10:28 | #6 (permalink) |
Member: 22586 Status: Offline Thanks Meter: 36 | @Fractalizer Maybe the speed reducing could help, if not Tell to your client to try an older flash group. There are so many in the support. Also give some more info and mainly why he flashes the phone. Was it dead ? Simple Upgrade ? BR Mike |
06-19-2006, 15:12 | #7 (permalink) |
Member: 17711 Status: Offline Thanks Meter: 1,858 | Older flashes flash without problems. He just wants to put newer firmware to his phone. Phone was working ok. If you recover it via recovery mode and flash after - it works well with CID36 firmwares, but latest stable from them is R1L, which is very old. R1N is beta (brown itself). |
06-19-2006, 19:07 | #8 (permalink) |
Member: 22586 Status: Offline Thanks Meter: 36 | In fact this is a case that should be studied by LEAD. Also tell your client to try R1BC002 flash group, it is Red36 too. Realy strange though BR Mike |
06-20-2006, 12:28 | #11 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
since yesterday always sx4 error on writting pm | sergioems | J.A.F. By Jafsupport.com | 4 | 12-07-2008 18:44 |
i need k750 cid49 flash files urjent | tiju kkm | Sony Ericsson Hardware Repair | 6 | 11-29-2008 16:20 |
Do you want to see on support original flash files for chinese phones in .bin format? | GSMtricks | PadFinder box | 10 | 07-19-2008 05:16 |
To our supporter i need KG300 flash file to repair a phone | tsarkh | VygisToolbox | 22 | 12-11-2007 06:58 |
K750 R1BC002 CID49 flash files needed! EMEA7 and EU2 | *Diablo* | Cruiser Suite | 1 | 06-20-2006 07:31 |
