05-16-2006, 16:16 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | failed to falsh an 8120 i am trying to flash a 8120 but get error Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd LG 3G phone detected. Phone CID: 17 Phone color: Brown Flash certificate: A1_LG_AS_CUSTOMER Trying Brown CID17 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: AMD Flash ID: 0x017E OTP Security Level: 0 (Developer) OTP CID: 17 Defeating RSA protection... Defeated! Sending applet... Analyzing configuration... Reading primary certificate... Primary certificate CID: 17 Primary certificate color: Brown Secondary certificate not found. GDFS configuration not found. OSE configuration not found. TestProgram configuration not found. Done. The phone contains recovery certificate! You MUST reflash the main firmware part! Phone hardware initialized OK Flash file: "U8120_V105_UK.flp" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Replacing primary certificate... Programming flash... Time: 00:02:49 Preparing to program flash... Analysing flash file... Programming flash... Time: 00:02:29 Preparing to program flash... Analysing flash file... Programming flash.. always get this error Applet error: ERROR|GetFlashInfo| Error flashing block at address: 0x23010000 Script error: Flash error [9.54.75] |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
Server down, I try to do an Z310 and connect server fail. | gsmnice | Seking Server | 2 | 04-29-2008 23:08 |
Failing To Flash A 8120 | chowdary | Cruiser Suite | 2 | 04-22-2006 23:28 |
Twister an E700 Failed to enter TAT mode | Flash0r | Twisterflasher | 6 | 05-09-2005 23:23 |
Logger Failed to unlock LG 8120 v 105 | livewirecebu | Griffin | 0 | 12-30-2004 03:53 |
