01-24-2005, 14:47 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | If it can power on phones automatically (without pressing NO button), it should be able to charge them too. Otherwise your USB port does not give enough power to start charging. |
01-24-2005, 16:04 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 72567 Status: Offline Thanks Meter: 8 | Lead, the phone goes on and off when charging it. I have tried both USB2 and the the standard USB both ports on the computer. I haven't seen any problems using the USB ports for other applications. |
01-24-2005, 16:16 | #4 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | There are 3 types of Fighter cables:
01-24-2005, 18:49 | #5 (permalink) |
Member: 72567 Status: Offline Thanks Meter: 8 | I guess alternative two. I'm thinking of upgrading to Cruiser but I wonder how I'm going to do if I want to run with two phones at the same time? Then I will occupy three USB ports. How does people with pro do? 15 extra OEM Fighter cables? |
01-24-2005, 18:52 | #6 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Yes, if you want to work with 2 phones you need 3 USB ports, one for the Cruiser SmartCard and two for the cables. If you are going to work with more than one phone often, you're best to go and get yourself a powered 4-port (or more) USB hub. That way your Cruiser SmartCard is in the back of your PC and you then have 4 ports (on the hub, which itself is plugged into the other port in the back of your PC) to work with, perfect for Cruiser Pro 4 |
01-24-2005, 20:18 | #8 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | That's correct, yes. Plug them in one at a time, give them a port in Windows and then put a label on them. That way you know what cable is what when you're working with many. |
Charging not supported..... and.....Not charging 100% solution | R@ZIB-BD | Nokia Hardware & Hardware Repair | 20 | 04-06-2010 08:57 |
NOKIA Charging Not Supported & Not Charging NEW HARDWARE EXE | dulal044 | Nokia Hardware & Hardware Repair | 2 | 05-16-2009 15:33 |
XP problems, fighter not starting | Invisible | Cruiser Suite | 4 | 07-13-2004 10:58 |
Hello anybody, my Nokia-3210 is not charging it is showing not charging | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-25-2003 11:27 |
