06-01-2005, 15:05 | #1 (permalink) |
Junior Member Join Date: May 2005
Member: 147279 Status: Offline Thanks Meter: 0 | Flash ARM on t630 stuck on 60% (v3.91) After upgrading to v3.91 I cannot longer flash ARM on t630. Trying to downgrade to 3.82 seems not to be possible due to a 7-veek constraint in the software. Is it possible to set back the computer clock to make 3.82 work again? Or are any other workarounds possible? UPDATE: Workaround by setting back system clock and reinstalling 3.82 solves the problem. Regards, Zoo Last edited by Zoo; 06-01-2005 at 15:20. |
06-01-2005, 23:28 | #2 (permalink) |
Member: 147279 Status: Offline Thanks Meter: 0 | Stuck on 60% now on 3.92 UPDATE2: After trying T630 debranding file on a unbranded T630 it is now a brick (well you have to try, don't you :-D) All three versions 3.82,3.91,3.92 fails to flash AVR to the phone, it gets stuck on 60%.... Any suggestions anyone? Regards, Zoo |
06-02-2005, 11:44 | #4 (permalink) |
Member: 147279 Status: Offline Thanks Meter: 0 | Stuck on 60% It gets stuck on "Sending ARM flash applet..." at 60% then the wierd stuff happens. Still on "Sending ARM flash applet..." 60% the grayed out icons for "Flash AVR" and "Flash ARM" etc. suddenly gets clickable again. Even if my phone is toast it seems that Cruiser behaves wierd. |
06-02-2005, 20:47 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Oh right, it might be a baud rate bug. Try selecting the lowest baud rate possible before attaching to the phone, then try and flash ARM. Also, what are you using to flash ARM with, T28, Fighter or DSS cable? |
06-03-2005, 22:07 | #9 (permalink) |
Member: 147279 Status: Offline Thanks Meter: 0 | Tested with uc10 cable and 3.93 and now it works, I don't know if it was the cable or the verions but I don't care :-) ------------------- Tried to connect a Z800 CID36 and it does connect but I dont get any options, how does the converting work and can anyone explain to a newbie how and why the red to brown conversion works? Thanks, Zoo |
V3 Stuck on White Screen LCD | olaleye | Motorola Hardware Repair | 0 | 04-02-2007 10:39 |
v3 stuck on hello moto logo | gamdadda | Smart-Clip | 2 | 10-13-2005 03:52 |
How can i flash arm t630 | libya_phone | DIV | 1 | 11-21-2004 20:38 |
Problem flashing ARM in T630 (Lead, can you help me?) | NeTRaW | Cruiser Suite | 5 | 09-23-2004 07:20 |
