10-23-2005, 16:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: anywhere there is freedom Age: 47
Member: 106700 Status: Offline Thanks Meter: 47 | freinds, can somebody explain the right procedure to unlock lg 8120v1.05 thank |
10-23-2005, 19:26 | #2 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 49
Member: 88410 Status: Offline Thanks Meter: 1 | Hi there It's pretty easy if you follow these instructions: 1. Download U8120_drive_c_v101_Brown17.flp from Cruiser support site 2. Make sure the handset is turned off and connect the cable# 3. Press "Attach". 4 Go to "Flash" tab and click "Flash ARM", select the U8120_drive_c_v101_Brown17.flp file 5. Once flashing is complete, go to "Locks" tab and click "Read Codes", phone will automatically detach once reading codes is complete, unplug cable from the handset 6. Put un-accepted sim into the handset and when "Usim Blocked" message appears tap in 2945#*88110 and then click ok when unlock menu appears 7. Type in NCK code from the list of codes cruiser gives you and then tap OK 8. If all goes ok, the handset should say "Success!" 9. Restart the handset, and voiala! The phone is unlocked! Hope this helps! FWC |
will any one tell me the right methode to unlock s5230? plz masters help me | neeraj1st | UST Pro II | 2 | 01-14-2010 10:37 |
Can someone explain the CRC1 value to me? | kryppy | Various CDMA/TDMA Cell Phones | 0 | 11-14-2009 03:16 |
what is the right step to unlock blackberry 8100?? | MPhoneClinic | FuriousGold | 10 | 10-06-2009 02:39 |
Procedure to unlock LG CG225 | LiLBoiNam | Phone Unlocking Codes & Maps | 19 | 09-05-2009 00:33 |
THE RIGHT WAY TO UNLOCK j750 | herbie_ma | Easy-Unlocker | 14 | 06-09-2008 17:01 |
