09-08-2006, 06:51 | #1 (permalink) |
Insane Poster Join Date: May 2003 Location: Ind Age: 43
Member: 28831 Status: Offline Thanks Meter: 0 | Help 2 pcs of k700i contact service centre System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Sedang menyambung melalui SEMC DSS-25 SyncStation... Sedang Nyalain HP... Baseband chip ID: 0x8000 Versi Protokol: 3.1 Baudrate = 921600Bd Sony Ericsson phone detected. Phone CID = 36 Phone color: Brown Flash certificate: A1_DB2010_36_BROWN Trying Brown CID36 flash applet... Applet Prologue sedang dikirim... Mengirim applet body... Waktu yang digunakan untuk masuk ke dalam bootstrap: 1s Sedang cek ponsel... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Menganalisa konfigurasi... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Selesai ! Menganalisa proteksi RSA... Proteksi RSA lemah. Type kelemahan proteksi RSA: PERMANENT Pengenalan hardware ponsel OK [ --- Unlock RSA --- ] Restarting phone... Mengalahkan proteksi RSA... Menunggu HP dimatikan... Komunikasi hang, pasang kembali battery. Baudrate = 921600Bd Applet Prologue sedang dikirim... Mengirim applet body... Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F Applet sedang dikirim... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Terkalahkan! Mengirim CS applet... Applet ID: 060119 0203 CRUCXC1327364_COMPACT_SEMC_CS_LOADER_V20 Initializing CS applet... Starting up GDFS service... Menulis unsigned code... Ponsel akan power off Selesai ! Sambungan ponsel otomatis terputus [ --- Attach to Phone --- ] Sedang menyambung melalui SEMC DSS-25 SyncStation... Sedang Nyalain HP... Baseband chip ID: 0x8000 Versi Protokol: 3.1 Baudrate = 921600Bd Sony Ericsson phone detected. Phone CID = 36 Phone color: Brown Flash certificate: A1_DB2010_36_BROWN Trying Brown CID36 flash applet... Applet Prologue sedang dikirim... Mengirim applet body... Waktu yang digunakan untuk masuk ke dalam bootstrap: 1s Sedang cek ponsel... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Menganalisa konfigurasi... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Selesai ! Menganalisa proteksi RSA... Proteksi RSA lemah. Type kelemahan proteksi RSA: PERMANENT Pengenalan hardware ponsel OK [ --- Change Certificate Color --- ] Mengalahkan proteksi RSA... Menunggu HP dimatikan... Komunikasi hang, pasang kembali battery. Baudrate = 921600Bd Applet Prologue sedang dikirim... Mengirim applet body... Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F Applet sedang dikirim... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Terkalahkan! Applet sedang dikirim... Applet ID: Prepare yourself for a nice surprise! Initializing applet... Replacing primary certificate... Certificate replaced successfully. Ponsel akan power off Sambungan ponsel otomatis terputus [ --- Attach to Phone --- ] Sedang menyambung melalui SEMC DSS-25 SyncStation... Sedang Nyalain HP... Baseband chip ID: 0x8000 Versi Protokol: 3.1 Baudrate = 921600Bd Sony Ericsson phone detected. Phone CID = 36 Phone color: Red Flash certificate: A1_DB2010_36_RED Trying Red CID36 flash applet... Applet Prologue sedang dikirim... Mengirim applet body... Waktu yang digunakan untuk masuk ke dalam bootstrap: 1s Sedang cek ponsel... Applet ID: 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Menganalisa konfigurasi... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Red Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Selesai ! Menganalisa proteksi RSA... Proteksi RSA lemah. Type kelemahan proteksi RSA: PERMANENT Pengenalan hardware ponsel OK [ --- Flash Main Firmware --- ] [ --- Flash Main Firmware --- ] File flash: "K700c_CXC125881_China_R2CA001_Red36.ck7sw" File flash: "K700i_CXC125822_AsianLatin2_R2CA001_Red36.ck7 fs" Sedang menunggu file flash yang akan di masukan... Reading phone RSA certificate... Sedang program flash... Program flash... Primary certificate has been overwritten. Time: 00:04:26 Sedang program flash... Program flash... Time: 00:01:42 Proses flash selesai [ --- Customize File System --- ] Mengalahkan proteksi RSA... Menunggu HP dimatikan... Komunikasi hang, pasang kembali battery. Baudrate = 921600Bd Applet Prologue sedang dikirim... Mengirim applet body... Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F Applet sedang dikirim... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Terkalahkan! Mengirim CS applet... Applet ID: 060119 0203 CRUCXC1327364_COMPACT_SEMC_CS_LOADER_V20 Initializing CS applet... Starting up GDFS service... Memulai filesystem, silahkan tunggu... Building customization... [ --- Shutdown File System --- ] Ponsel akan power off Akses GDFS diakhiri Sambungan ponsel otomatis terputus Everytime customize file system appear this message GDFS salah: The specified module could not be found It is never happen before, lately i reinstall 9.74 coz seem problem appear |
09-08-2006, 12:21 | #2 (permalink) |
Freak Poster Join Date: May 2006
Member: 277942 Status: Offline Thanks Meter: 0 | You have to attach phone in recovery mode (CID 36). Repair cert. Reattach in normal mode. Change cert. to brown 36. Then you flashed the phone. For CID 36, you don't use Unlock RSA. And from your log I see that you flash both Main & RAW FS together. Flash Main, flash FS then customise. |
Huwaei C2900 phone locked contact service centre...plz help | rk_grover77 | Various CDMA/TDMA Cell Phones | 16 | 06-28-2014 11:58 |
haier c100 contact service centre | farsi_007 | Various CDMA/TDMA Cell Phones | 8 | 07-21-2011 08:43 |
Huawei c506 please contact service centre | Rin2 | Various CDMA/TDMA Cell Phones | 3 | 08-14-2009 12:44 |
plz halp 3308 huawei phone lokrd plz contact servic centre | rajni | Various CDMA/TDMA Cell Phones | 2 | 02-28-2009 09:30 |
huwai c2900i phone locked please contact service centre | royal_electronics | Various CDMA/TDMA Cell Phones | 3 | 11-26-2008 18:14 |
