Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-07-2008, 10:44   #1 (permalink)
javish's Avatar
Member: 535130
Red face Help K510 TestPoint Failed!
Help I've SE K510i CID50 GDFS is error, i want to repair with cruiser TP full Unlocker, but failed!(TP1 & TP2 is done)
please help,this is the log
  16:22:38  SE Testpoint Full Unlocker v1.03 by Cruiser Team
  16:22:38  Initializing...
! 16:22:39  1. Choose the phone model
! 16:22:39  2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation)
! 16:22:39  3. If you want to perform restore, select GDFS backup file (*.gdfs)
! 16:22:39  4. Connect the data cable and the power supply clips to the phone
! 16:22:39  5. Double-click on cruiser UC-20 test-point cable
  16:22:44  Connecting via Cruiser UC-20 Cable (COM6)…
  16:22:44  Device driver version: 2.4.6.0
  16:22:44  Device driver date: 3-13-2008
  16:22:47  Connecting to the baseband CPU...
  16:22:48  Entering baseband CPU service mode...
  16:22:48  Detected chipset: DB2012
  16:22:48  Boot mode: ROM
  16:22:51  Sending loader...
  16:22:52  Sending loader...
! 16:22:53  Connect the Testpoint Stage 1
  16:23:17  Testpoint connected successfully
! 16:23:17  You may release the test-point now
E 16:24:17  Error: 0x6C729765
E 16:24:17  Error: 0x8CDFAB78
E 16:24:17  Error: 0xFA7863EC
E 16:24:17  Error: 0x780BA8B0
E 16:24:17  Error: 0x48B70E40
E 16:24:17  Error: 0x93DB6CBB
E 16:24:17  Failed!
! 16:24:17  Please disconnect battery and cable from the phone!
! 16:24:17  To report errors right-click this window
  16:21:02  SE Testpoint Full Unlocker v1.03 by Cruiser Team
  16:21:02  Initializing...
! 16:21:02  1. Choose the phone model
! 16:21:02  2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation)
! 16:21:02  3. If you want to perform restore, select GDFS backup file (*.gdfs)
! 16:21:02  4. Connect the data cable and the power supply clips to the phone
! 16:21:02  5. Double-click on cruiser UC-20 test-point cable
  16:21:07  Connecting via Cruiser UC-20 Cable (COM6)…
  16:21:07  Device driver version: 2.4.6.0
  16:21:07  Device driver date: 3-13-2008
  16:21:10  Connecting to the baseband CPU...
  16:21:10  Entering baseband CPU service mode...
  16:21:10  Detected chipset: DB2012
  16:21:10  Boot mode: ROM
  16:21:14  Sending loader...
  16:21:14  Restarting phone …
! 16:21:15  Connect the Testpoint Stage 2
  16:22:15  Testpoint connected successfully
  16:22:15  Connecting to the baseband CPU...
  16:22:15  Entering baseband CPU service mode...
  16:22:16  Sending loader...
E 16:22:16  Error: 0x19BD941D
E 16:22:16  Error data: 0x19BD941D - 00000003:0032A9
E 16:22:16  Error: 0xBABAC469
E 16:22:16  Error: 0x8CA05E14
E 16:22:16  Error: 0x93DB6CBB
E 16:22:16  Failed!
! 16:22:16  Please disconnect battery and cable from the phone!
! 16:22:16  To report errors right-click this window
Old 10-07-2008, 11:31   #2 (permalink)
javish's Avatar
Member: 535130
help please..... but don't suggest for use ultimate unclocker
Old 10-07-2008, 12:22   #3 (permalink)
FilipLudvik's Avatar
Member: 135110
I will not but I say that there is necessary to use the latest version of the TP Unlocker. It's 1.05.
The Following User Says Thank You to FilipLudvik For This Useful Post:
Old 10-07-2008, 12:25   #4 (permalink)
javish's Avatar
Member: 535130
please anyone can help my problem hik...hik...hik....
Old 10-07-2008, 12:31   #5 (permalink)
Member: 135110
I said the solution:
go to support area:
Downloads / Software_GSM / CruiserSuite / Cruiser_SeTestPointFullUnlocker /
SeTestpointFullUnlocker_v1.05-installer.rar
Old 10-07-2008, 12:42   #6 (permalink)
javish's Avatar
Member: 535130
ok i'll try using ver 1.05,thanks
Old 10-07-2008, 13:47   #7 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
dear Mizar or PilipLudvic.....
Me too I got error everytime using TestpointFull Unlocker 1.05 for W830 red blink...
here is the log..
  19:56:12  SE Testpoint Full Unlocker v1.05 by Cruiser Team
  19:56:12  Initializing...
! 19:56:12  1. Choose the phone model
! 19:56:12  2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation)
! 19:56:12  3. If you want to perform restore, select GDFS backup file (*.gdfs)
! 19:56:12  4. Connect the data cable and the power supply clips to the phone
! 19:56:12  5. Double-click on cruiser UC-20 test-point cable
  19:56:28  Connecting via Cruiser UC-20 Cable (COM5)…
  19:56:28  Device driver version: 2.4.6.0
  19:56:28  Device driver date: 3-13-2008
  19:56:31  Connecting to the baseband CPU...
  19:56:31  Entering baseband CPU service mode...
  19:56:31  Detected chipset: DB2020
  19:56:31  Boot mode: ROM
  19:56:34  Sending loader...
  19:56:35  Sending loader...
  19:56:36  Writing flash…
! 19:56:40  Connect the Testpoint Stage 1
  19:57:42  Testpoint connected successfully
! 19:57:42  You may release the test-point now
E 19:57:42  Error: 0xB15407B1
E 19:57:42  Failed!
! 19:57:42  Please disconnect battery and cable from the phone!
! 19:57:42  To report errors right-click this window
Please advise us what is the solution for this error... me and all member of this forum need help from product supporter or anyone else
Old 10-07-2008, 13:57   #8 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
here is the log..
E 19:57:42  Failed!
Old 10-07-2008, 14:13   #9 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
sorry double post because of unstable network connection....
Please admin delete it..
Old 10-07-2008, 14:17   #10 (permalink)
Member: 135110
send me a identify log from Cruiser 13.20. thx
Old 10-07-2008, 14:45   #11 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
ok will post it tomorrow sir..
Old 10-07-2008, 20:46   #12 (permalink)
javish's Avatar
Member: 535130
@FilipLudvik
I've try using ver 1.05 but still get error massage.
this is the log
  02:40:02  SE Testpoint Full Unlocker v1.05 by Cruiser Team
  02:40:02  Initializing...
! 02:40:03  1. Choose the phone model
! 02:40:03  2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation)
! 02:40:03  3. If you want to perform restore, select GDFS backup file (*.gdfs)
! 02:40:03  4. Connect the data cable and the power supply clips to the phone
! 02:40:03  5. Double-click on cruiser UC-20 test-point cable
  02:41:36  Connecting via Cruiser UC-20 Cable (COM6)…
  02:41:36  Device driver version: 2.4.6.0
  02:41:36  Device driver date: 3-13-2008
  02:41:40  Connecting to the baseband CPU...
  02:41:40  Entering baseband CPU service mode...
  02:41:40  Detected chipset: DB2012
  02:41:40  Boot mode: ROM
  02:41:43  Sending loader...
  02:41:44  Sending loader...
! 02:41:45  Connect the Testpoint Stage 1
  02:41:56  Testpoint connected successfully
! 02:41:56  You may release the test-point now
E 02:42:56  Error: 0x6C729765
E 02:42:56  Error: 0x8CDFAB78
E 02:42:56  Error: 0xFA7863EC
E 02:42:56  Error: 0x780BA8B0
E 02:42:56  Error: 0x48B70E40
E 02:42:56  Error: 0x93DB6CBB
E 02:42:56  Failed!
! 02:42:56  Please disconnect battery and cable from the phone!
! 02:42:56  To report errors right-click this window
Old 10-07-2008, 20:54   #13 (permalink)
javish's Avatar
Member: 535130
this is log "skip tp stage 1"
  02:48:34  SE Testpoint Full Unlocker v1.05 by Cruiser Team
  02:48:34  Initializing...
! 02:48:35  1. Choose the phone model
! 02:48:35  2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation)
! 02:48:35  3. If you want to perform restore, select GDFS backup file (*.gdfs)
! 02:48:35  4. Connect the data cable and the power supply clips to the phone
! 02:48:35  5. Double-click on cruiser UC-20 test-point cable
  02:48:40  Connecting via Cruiser UC-20 Cable (COM6)…
  02:48:40  Device driver version: 2.4.6.0
  02:48:40  Device driver date: 3-13-2008
  02:48:43  Connecting to the baseband CPU...
  02:48:44  Entering baseband CPU service mode...
  02:48:44  Detected chipset: DB2012
  02:48:44  Boot mode: ROM
  02:48:47  Sending loader...
  02:48:48  Restarting phone …
! 02:48:48  Connect the Testpoint Stage 2
  02:49:00  Testpoint connected successfully
  02:49:00  Connecting to the baseband CPU...
E 02:50:48  Error: 0x11990C76
E 02:50:48  Error: 0xBF2BC19B
E 02:50:48  Error: 0x93DB6CBB
E 02:50:48  Failed!
! 02:50:48  Please disconnect battery and cable from the phone!
! 02:50:48  To report errors right-click this window
Old 10-07-2008, 21:09   #14 (permalink)
Member: 135110
let me see an identify log from Cruiser 13.20. thx
Old 10-07-2008, 21:52   #15 (permalink)
Member: 310458
its mean gdfs corupted.
nothing to do with cruiser or setool for gdfs corupted Db2012.
only with supreme log,UB or DBSE
The Following User Says Thank You to utuh For This Useful Post:
v3re need some help testpoint failed wirelesshelpers Smart-Clip 4 02-23-2009 19:58
k510 testpoint need faizan15 Sony Ericsson 2 10-28-2008 19:35
Testpoint Failed Help Needed moni108 MT-BOX 4 02-06-2008 09:03
help 6300 TESTPOINT FAILED hassan35278 MT-BOX 11 09-08-2007 17:23
TestPoint Failed ALNOOR MT-BOX 8 06-08-2007 14:21
Page generated in 0.69662 seconds with 11 queries
