03-20-2009, 17:08 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: SWEDEN
Member: 683086 Status: Offline Thanks Meter: 15 | help with k750 i try to change imei k750i but Through this the phone is dead and red light and i try to make customiz . System diagnostics passed. Version 13.20 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): K750i CXC article: R1CA021 prgCXC125952_EU_1_CL CXC version: R1CA021 Language package: EUROPE_4 Operator: Generic CDA article: CDA102337/12 CDA version: R5A Default article: cxc125953 Default version: R1CA021 Phonecode: 3961 Sending applet... Applet ID: 050909 1014 NPACXC1250165_1_SEMC_CO... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Customize File System --- ] Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... No response This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first. how can i solv this problem. |
03-20-2009, 18:06 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | is that the Full LOG.??? i am a little confused as to Why you Decided to customise the FS. Try to Attach again, please use a fully Charged Battery, Once attached you need to remove RSA , then Procede to disable OTp imei then Change GDFS imei (last 6 didgets only) once Done you need to Restore Firmware, or Flash same Main/arm. if it wont remove RSA, then you are going to Have to attach by Testpoint, for which a K750 is Quite easy.(pictures and procedure in manual.) |
03-20-2009, 18:29 | #3 (permalink) | |
Member: 683086 Status: Offline Thanks Meter: 15 | Quote:
i resev this Message No response This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first. and now i try to flash the phone it is ok .but customize fs sam problem No response This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first. | |
03-20-2009, 18:45 | #4 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | if Rsa wont Remove, then you Must attach by testpoint, Cause you are Not able to Customise Filesystem while Rsa is Active, (its a lock) |
need help with k750 | falak | Cruiser Suite | 12 | 06-02-2006 12:47 |
Plsssssssss Help With K750 Dead Phone / Empty !!!! | MT_LBN | Sony Ericsson | 5 | 02-25-2006 06:26 |
Need help with K750 | struggler | SonyEricsson (USB-Smart) | 6 | 02-19-2006 14:35 |
Help with K750 to W800 | The Repair Shop | SonyEricsson (USB-Smart) | 10 | 10-02-2005 12:16 |
please help with K750 - "Please wait" problem | Motoroller | Cruiser Suite | 3 | 09-07-2005 12:41 |
