05-22-2007, 09:56 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 493553 Status: Offline Thanks Meter: 24 | Help please, w800 can't customize..... the phone now can't customize......... help please...... thank's. |
05-22-2007, 11:21 | #3 (permalink) |
Member: 493553 Status: Offline Thanks Meter: 24 | System diagnostics passed. Version 10.43 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): K750i CXC article: R1BC002 prgCXC1250092_EU_1_CA CXC version: R1BC002 Language package: EMEA_3 Operator: Generic Trade CDA article: CDA102338/36 CDA version: R5A Default article: cxc125953 Default version: R1N035 Phonecode: 0000 (default) Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_CO... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 49 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "K750i_CXC125952_EU1_R1CA021_Red49.ck75sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Replacing secondary certificate... Programming flash... Time: 00:04:55 Flash process done. [ --- Flash Raw File System --- ] Flash file: "K750i_CXC125953_EMEA5_R1CA021_Red49.ck75fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:02:47 Flash process done. [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_S... Initializing CS applet... Could not unlock CS applet... |
05-22-2007, 11:33 | #4 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 65863 Status: Offline Thanks Meter: 15 | well u flashed the phone with red cid so u just need to unlock rsa attach unlock rsa attach customize if not worked then flash gdfs as main then cust dont forget to restor rsa at the end |
05-22-2007, 11:38 | #5 (permalink) |
Member: 493553 Status: Offline Thanks Meter: 24 | System diagnostics passed. Version 10.43 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): K750i CXC article: R1BC002 prgCXC1250092_EU_1_CA CXC version: R1BC002 Language package: EMEA_3 Operator: Generic Trade CDA article: CDA102338/36 CDA version: R5A Default article: cxc125953 Default version: R1N035 Phonecode: 0000 (default) Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_CO... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 49 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "K750i_CXC125952_EU1_R1CA021_Red49.ck75sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Replacing secondary certificate... Programming flash... Time: 00:04:55 Flash process done. [ --- Flash Raw File System --- ] Flash file: "K750i_CXC125953_EMEA5_R1CA021_Red49.ck75fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:02:47 Flash process done. [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_S... Initializing CS applet... [ --- Detach Phone --- ] Terminating threads... All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... [ --- Detach Phone --- ] Terminating threads... All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): K750i CXC article: R1CA021 prgCXC125952_EU_1_CL CXC version: R1CA021 Language package: EMEA_3 Phonecode: 0000 (default) Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_CO... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 49 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "W800i_CXC1250174_China_R1BC002.cw8sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Replacing secondary certificate... Programming flash... Time: 00:05:20 Flash process done. [ --- Flash Raw File System --- ] Flash file: "W800i_CXC1250093_APAC1_R1BC002.cw8fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:02:35 Flash process done. [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_S... Initializing CS applet... Could not unlock CS applet... |
05-22-2007, 11:43 | #6 (permalink) | |
Member: 493553 Status: Offline Thanks Meter: 24 | Quote:
the phone is brown, no need to unlock..... | |
05-22-2007, 11:58 | #8 (permalink) |
Member: 493553 Status: Offline Thanks Meter: 24 | System diagnostics passed. Version 10.43 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): W800i CXC article: R1L002 prgCXC1250092_EU_1_CA CXC version: R1L002 Language package: EUROPE_2 Operator: Generic CDA article: CDA102430/10 CDA version: R2A Default article: cxc1250093 Default version: R1L002 Phonecode: 0000 Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_CO... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 49 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Flash Main Firmware --- ] [ --- Flash Main Firmware --- ] Flash file: "W800i_FullGDFS_version1.cw8sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Programming flash... Time: 00:00:17 Flash process done. [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_S... Initializing CS applet... Could not unlock CS applet... still same problem........... |
05-22-2007, 13:22 | #12 (permalink) | |
System diagnostics passed. Version 10.43 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): W800i CXC article: R1CA021 prgCXC1250514_EU_1_CR CXC version: R1CA021 Language package: EMEA_4 Operator: Generic CDA article: CDA102430/4 CDA version: R2A Default article: cxc1250093 Default version: R1L002 Phonecode: 0000 Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_CO... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "W800i_CXC1250092_EU1_R1N035_Brown36.cw8sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Replacing secondary certificate... Programming flash... Time: 00:04:55 Flash process done. [ --- Flash Raw File System --- ] Flash file: "W800i_CXC1250093_EMEA1_R1N035_Brown36.cw8fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:02:43 Flash process done. [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_S... Initializing CS applet... Could not unlock CS applet... | |
after flash z750 i can't Customize it..help | zablander212 | SETool2 | 2 | 09-20-2008 13:08 |
Please Help with W800 no speaker sound | MPhoneClinic | Sony Ericsson Hardware Repair | 7 | 08-02-2008 13:34 |
Can't Customize FS W810i - See my log & please help | .:.GSM-ANGEL.:. | Cruiser Suite | 14 | 10-25-2007 09:37 |
W800 problem customize FS | 5aaaaa | Cruiser Suite | 0 | 09-20-2007 11:24 |
