03-28-2007, 01:10 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: palestine Age: 52
Member: 214205 Status: Offline Thanks Meter: 3 | Help plz with u8330 i have strange problem with Lg 8330 and am hoping one of you can help me. i have full flashed phone using cruiser.phone accepts the flash ok but still will not power and i think customer is getting very close to killing me. the strange bit is that when i plug charger into phone phone appears to charge but when i try to power on when charger is inserted keypad lights come on but nothing else no sound no lcd or any other signs of life. any ideas? |
03-28-2007, 11:36 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 49
Member: 174660 Status: Offline Thanks Meter: 3 | Probably certificate is damaged. Try this: 1. On Primary page select exact phone type LG U8330, Select boot type: Recovery boot, CID=42, use TP. Click Attach to phone btn. You will need testpoint. Open Cruiser help to see where TP is. Just connect the testpoint to GND when asked by Cruiser. Then simply disconnect it when Cruiser prompts you to do so. 2. On Security RSA page click Repair certificate (or Replace certificate with Red42). 3. Primary -> Turn off phone. (don't need TP in next steps) 4. Select boot type: Normal boot. 5. Attach to phone. 6. Flash -> Flash ARM. Select a flash file - "U8330_V20a_Austria_Red42.flp" for example. 7. Turn off phone. If this don't help you, then the problem is more serious - maybe hardware. If the phone is locked use Unlock by patching. br |
03-29-2007, 15:21 | #4 (permalink) | |
Member: 214205 Status: Offline Thanks Meter: 3 | Quote:
03-29-2007, 16:19 | #6 (permalink) |
Member: 174660 Status: Offline Thanks Meter: 3 | Yes, Vygis is other tool that may help. On Vygis support site LG section find the "Repair_flashes_for_LG3G" folder and "U81xx GDFS" folder and download files you need and flash the phone using testpoint. |
04-08-2007, 09:12 | #8 (permalink) |
Freak Poster Join Date: Nov 2005 Location: KSA
Member: 201126 Status: Offline Thanks Meter: 1 | hi friends i have also a u8330 for software butt when i connect it i also used full battery butt can't connect also use recovery what i do? please help [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... LG 3G phone detected. Phone CID: 17 Phone color: Brown Flash certificate: A1_LG_AS_CUSTOMER Trying Brown CID17 flash applet... Sending applet prologue... Trying CID16 recovery applet... Terminating threads... All threads terminated. I NEED SOME HELP PLEASE KINDLY? |
help help plz with C139 | Durango Unlock | Smart-Clip | 3 | 12-09-2006 03:18 |
Help Plz With Dead Gd67 | blinet | Panasonic | 2 | 02-28-2004 21:42 |
help plz with 3310 | lasttime | Nokia Hardware & Hardware Repair | 6 | 01-13-2004 18:59 |
Help plz with unlock Siemens C62 | tiq | Phone Unlocking Codes & Maps | 0 | 12-17-2003 13:07 |
Help plz with unlock Siemens C62 | tiq | NON Siemens Brand (ODM Phones) | 0 | 12-17-2003 13:02 |
