Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-14-2008, 07:09   #1 (permalink)
joe cellular's Avatar
Member: 340957
help using a1 javaunlocker
  07:52:34  SE A1 Java Unlocker v1.02 by Cruiser Team
  07:52:34  Initializing...
! 07:52:34  1. Choose the phone model
! 07:52:34  2. Select main firmware flash file (*.a1sw)
! 07:52:34  3. Select raw FS flash file (*.a1fs)
! 07:52:34  4. Please connect the phone while holding its C button…
  07:53:43  Connecting via SEMC USB Flash Device (USB1)…
  07:53:43  Device driver version: 1.1.0.12
  07:53:43  Device driver date: 9-25-2006
  07:53:43  Connecting to the baseband CPU...
  07:53:43  Entering baseband CPU service mode...
  07:53:43  Detected chipset: DB2020
  07:53:43  Boot mode: EROM
  07:53:43  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  07:53:43  Initializing flash files...
  07:53:47  Sending loader...
  07:53:48  Sending loader...
  07:53:48  About to flash 45 MB of data…
  07:59:49  Sending loader...
  07:59:51  System starting up...
  07:59:51  GDFS starting up...
  08:00:13  FS starting up...
  08:00:35  FS data uploading...
! 08:00:45  1. Please disconnect battery and cable from the phone!
! 08:00:45  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 08:00:45  3. Wait to customize finish
! 08:00:45  4. Turn off the phone
! 08:00:45  5. Please connect the phone while holding its C button…
  08:01:00  Connecting via SEMC USB Flash Device (USB1)…
  08:01:00  Device driver version: 1.1.0.12
  08:01:00  Device driver date: 9-25-2006
  08:01:00  Connecting to the baseband CPU...
  08:01:00  Entering baseband CPU service mode...
  08:01:01  Detected chipset: DB2020
  08:01:01  Boot mode: EROM
  08:01:01  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  08:01:01  Sending loader...
  08:01:02  Sending loader...
  08:01:04  System starting up...
  08:01:04  GDFS starting up...
  08:01:26  FS starting up...
  08:01:28  FS data uploading...
! 08:01:42  1. Please disconnect battery and cable from the phone!
! 08:01:42  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 08:01:42  3. Connect the phone again
! 08:01:42  4. If asked, Install phone drivers
! 08:01:42  5. Choose 'PHONE MODE' in the phone
! 08:02:11  After choosing 'PHONE MODE' press the Ready button
  08:03:19  Connecting via SEMC WMC Device (COM9, COM8)…
  08:03:19  Device driver version: 4.34.0.2705
  08:03:19  Device driver date: 5-1-2006
  08:03:22  File executor wasn't find.
E 08:03:32  Error: 0x05190628
E 08:03:32  Error: 0xA8A269DB
E 08:03:32  Error: 0x53E0AA3B
E 08:03:32  Error: 0xB3721AB7
E 08:03:32  Error: 0xFD9ABCA6
E 08:03:32  Error: 0x0370C306
E 08:03:32  Error: 0xF8146F89
E 08:03:32  Error: 0xAD85D3B1
E 08:03:32  Error: 0x156B39A6
E 08:03:32  Cable disconnect detected
E 08:03:32  Failed!
! 08:03:32  Please disconnect battery and cable from the phone!
! 08:03:32  To report errors right-click this window
plz coud som 1 tell me wat im missing 2 complete dis fone
Old 06-14-2008, 11:57   #2 (permalink)
Mainboard's Avatar
Member: 25671
You don't follow steps exactly as JavaUnlocker ask you. Always when JavaUnlocker ask you to power on phone, you must power on phone, wait for customization and power off phone by power on/off button - never remove battery when phone is powered on. And in phone must be Test SIM card or Card which phone accept (so you can enter phone menu etc.).
The Following User Says Thank You to Mainboard For This Useful Post:
Always Use This Driver For Using A1 JAVA Fast Unlocker rajinder1978 Cruiser Suite 11 09-03-2009 07:21
plsssssssssss help me A1 team siraj_nathani A1-Services.org 1 05-18-2009 12:08
need help with A1 service client and my account Allan Bulanadi A1-Services.org 4 08-18-2008 08:49
help with a1 java unlocker RAND CELLULAR Cruiser Suite 1 06-21-2008 05:49
need other account to using A1 java & full unlocker msantar Cruiser Suite 2 06-10-2008 21:12
Page generated in 0.21268 seconds with 11 queries
