10-20-2004, 09:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Solution: How to Fix Fighter/Cruiser Smart Card Problem! FINALLY! After reading about so many people with Fighter Smart Card problems, I spent quite a long time stuffing around with my laptop, breaking the smart card stuff and getting it to work again. This solution tries to address the problem of the Smart Card service not starting correctly as is what causes Fighter to fail. It is somewhat similar to a post by Invisible he made a few months earlier, which you can view here. Note: This is only for Windows XP or Windows 2000. I can't help with Windows 98. Get in the real world people! Ok, so if when you put your dongle in it's red light flashes and you can see it in Device Manager, but when you run Fighter it doesn't work (or crashes) then please try this. It has worked for me and I've tested it on two PCs! I'm sure it'll work for you too!! This proves the Fighter Software is fine, it's Windows that has problems with the Smart Card Services that causes 99% of the "It Doesn't Work" problems I see posted here. Here's the steps to fix it: 1) Open up a command prompt (Start -> Run -> type in 'cmd' and press enter) 2) Type in this: regsvr32 c:\windows\system32\scardssp.dll Press return and click on "Ok" with the box that pops up. 3) Type in this: scardsvr reinstall Press return. You'll get no message. 4) Rename the attached file from fix.txt to fix.reg and double click on it. When it asks if you want to install the settings say yes! 5) Go to Start->Settings->Control Panel->Administrative Tools->Services. Double Click Services. In the list you now see, find the Service called "Smart Card" (not Smart Card Helper) and right click on it. Select "Properties" and left click. When the box opens up, change the "Startup Type" to automatic. Click on "Apply" then on "Ok" 6) Reboot Your PC! Do not try to "test" Fighter before doing this step! Your Fighter should now work perfectly! Please post here and tell me how you went. I tried this on two PCs and got it work, so I'm sure you can get Fighter to work for you doing this. Tim aka muppet. Last edited by Lead; 03-21-2005 at 23:32. |
10-20-2004, 13:22 | #2 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Spain
Member: 9489 Status: Offline Thanks Meter: 35 | Im at this point Quote:
10-20-2004, 17:37 | #4 (permalink) | |
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
10-20-2004, 17:47 | #6 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | EDV11: Good to hear, you must have the Smart Card Service running somewhere. With all my testing, if that service isn't running (or is stopped) Fighter will either just not work or will crash on startup. |
10-20-2004, 18:52 | #7 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Wales Age: 61
Member: 81787 Status: Offline Thanks Meter: 4 | i'm trying to save/change the fix.txt file but every time I open it it just opens up as word pad document. I'm using firefox as a browser do you think that is the problem. any suggestions please doggo |
10-20-2004, 20:31 | #8 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | doggo: If the file appears in wordpad that's fine. Just save the file as fix.reg and execute it. All it does is put a couple of settings in the registry. |
10-20-2004, 20:44 | #10 (permalink) |
Member: 81787 Status: Offline Thanks Meter: 4 | thanks fells, I'll give it a try, all I'm waiting for now is the activation code, I've managed to get everything installed on one of my machines (just waiting for the codes) but thats the backup machine, it's my main machine thats the problem. hopefuly this will sort things out. regards doggo |
dongle not found how to deal with smart card broken | leroi | Infinity-Box | 5 | 08-19-2008 20:05 |
how to fix n82 spread restart problem? | koonfedg | SpiderMan | 5 | 07-17-2008 00:48 |
How to fix 7650 wtith Hanging Problem?????? | essojay | WD2 & APE (Symbian Phones) | 2 | 03-18-2003 14:09 |
how to fix the V50 LCD Problems | moguth | Motorola Old Legacy (EMMI) | 1 | 05-10-2002 02:11 |
How to fix "Sim card not accepted" problem | rahimhd | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-11-2001 20:14 |
