Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-06-2006, 21:20   #1 (permalink)
Roni1976's Avatar
Member: 51403
Thumbs up How to Repair K750i with Ps Cid49 Brown and Sc Cid36 Brown
How to repair K750i with:
Primary certificate CID: 49
Primary certificate color: Brown
Secondary certificate CID: 36
Secondary certificate color: Brown
Use Version 10.00 ,Do everything as I I will say
1.Attach your phone with boot type:
Normal boot,any cid,use TP.
2.Go to Securyti RSA put v on "Use another methode",and
Replace certificate to Brown Cid49,after convert phone automaticly
Detached.
3.Attach your phone with boot type:
Normal boot.
4.Write raw FS with:
Flash file: "K750i_CXC125953_EMEA5_R1BC002_Red36.ck75fs" or with another
EMEA but CID36 from cruiser support.
5.Customize FS and then Shutdown FS.
6.Attach your phone with boot type:
Normal boot.
7.Flash Main Firmware with:
Flash file: "K750_R1BC002_MAIN_EU_EMEA_CID49.mbn" you can find the
file hire k750i CID49 RED dead repair PROCEDURE.
8.Turn of phone.
And your phone will revive to 100%
b,r
Roni
Old 10-06-2006, 21:39   #2 (permalink)
MaHmUt1982's Avatar
Member: 152266
really good work good solutıon friend thank u very much
Old 10-10-2006, 19:08   #3 (permalink)
ersa's Avatar
Member: 75290
Detached.
Normal boot.
Normal boot.
8.Turn of phone.
b,r
Roni
Nice Avatar
Thank you for help, but for me not work.
ERSA
Sebastian
Old 10-10-2006, 20:29   #4 (permalink)
FilipLudvik's Avatar
Member: 135110
Hi all, reapair!
Conect phone:
-Normal boot with TP2.
-Flash ARM this file: http://PhilipFotos.com/SE/EROM_Brown.erom2
-Detach and Atach Phone: Normal boot (no TP)
Flash ARM: R1CA021
Flash RAW FS: R1CA021
Finalize
Phone 100% working
REPAIR SOLUTION FOR SAYS:
This may indicate damaged EROM area!
Try repairing the phone via testpoint method.
If it is an old phone, try converting it to brown first
BR, FL
The Following 2 Users Say Thank You to FilipLudvik For This Useful Post:
Old 10-10-2006, 20:49   #5 (permalink)
NeTRaW's Avatar
Member: 42553
@FilipLudvik
Can you post an image of TP2?
Old 10-10-2006, 21:21   #6 (permalink)
Member: 135110
Originally Posted by NeTRaW View Post
@FilipLudvik
OMFG!!
Use the Cruiser manual of version 10.00!
Old 10-11-2006, 00:34   #7 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Angry r u mad
we r discasting about w810i where did u get w810i TP2 or any Tp
read first then post
Originally Posted by FilipLudvik View Post
Hi all, reapair!
Conect phone:
Flash ARM: R1CA021
Finalize
Phone 100% working
BR, FL
Old 10-13-2006, 15:47   #8 (permalink)
ersa's Avatar
Member: 75290
Hi all, reapair!
Conect phone:
Flash ARM: R1CA021
Finalize
Phone 100% working
BR, FL
My K750i is ALIVE
Do you have maybe TP to W300i? The same problem
Thank you very much
ERSA
Seb
Old 10-14-2006, 07:22   #9 (permalink)
kasra's Avatar
Member: 103435
how can i do unlock rsa for disable otp imei?
Old 10-15-2006, 07:25   #10 (permalink)
odinb's Avatar
Member: 76964
Press unlock RSA button in Cruiser?
Old 10-18-2006, 11:47   #11 (permalink)
Member: 323031
any1 have testpoint picture plz. email me... mobile.computing@hotmail.com
Old 10-27-2006, 18:31   #12 (permalink)
Member: 147105
How to REpair K750i with Ps Cid49 Brown and SC Cid36
Hi all, reapair!
Conect phone:
Flash ARM: R1CA021
Finalize
Phone 100% working
BR, FL
Hi no have to can conect with:
have only in Cruiser 10.0
Normal Boot, any Cid, use TP
when conect to phone:
Connecting via Fighter USB Cable...
Connect the testpoint!
Powering on the phone...
Baseband chip ID: 0x8040
Protocol version: 3.1
Baudrate = 460800Bd
Trying recovery applet...
Sending applet prologue...
Disconnect the testpoint!
All threads terminated.
and the phone detach automatic and so canīt flasch
EROM_Brown.erom2
but also the next canīt make while the first not work...
Flash ARM: R1CA021
Finalize
pleas can anyone helt...
ths
felix999
Old 10-29-2006, 20:59   #13 (permalink)
Member: 290059
Hi
I have the same problem with erom because I tried to unlock it with usb smart and killed it (k750i silver vodafone uk)
, I will test and let you know
Thanks
Hi all, reapair!
Conect phone:
Flash ARM: R1CA021
Finalize
Phone 100% working
BR, FL
Old 10-30-2006, 10:43   #14 (permalink)
Member: 146369
Baudrate = 460800Bd
EROM_Brown.erom2
Flash ARM: R1CA021
Finalize
ths
felix999
This indicates flat battery... Try a fully charged battery
wbr
Old 10-31-2006, 10:22   #15 (permalink)
Member: 290059
Could someone please attach a photo or a link for tp2
thanks
how to repair phones with problem simlock invalid and start up failed contact retaile ruchito Universalbox 7 04-06-2009 14:08
how to repair phones with problem simlock invalid and start up failed contact retaile ruchito Universalbox 1 04-06-2009 03:52
how to repair K800i red blink cid49? et.com KULANKENDI Server 17 08-21-2007 04:27
HOW TO UNLOCK K750i WITH UFS3 AND FBUS CABLE miecom Sony Ericsson 4 08-10-2006 07:40
how to repair erom in k750 cid49? cevil Cruiser Suite 9 07-26-2006 11:05
Page generated in 0.56720 seconds with 11 queries
