03-02-2008, 09:39 | #4 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | setool solution: 1 - Flash muna ng MAIN + FS using USB interface (DCU-60) 2 - Change to COM interface, sa "Settings" lagyan ng check ang "USE SERVER FOR CSCA UNLOCK/FLASH", go to "MISC" and select the attached script "READ_SEC_UNITS.txt", than click on "WRITE SCRIPT" Makikita ang script file sa (ex. GUI_v0.914023\script), parang ganito "IMEI_NUMBER.txt" (ex. 35177865674873.txt) 3 - Go to "MISC" again and select the attached file "GDFS_(model).bin" than "WRITE GDFS" 4 - DO NOT POWER ON THE PHONE YET. Go again to "MISC", select the security zone file readed before (ex. 35177865674873.txt), than "WRITE SCRIPT" 5 - If everything will be ok, your phone must be fully working now. Sometimes you donīt need to flash phone before. Just backup security, write GDFS and restore security. But, to be sure that is all clear, you shoud flash phone first. Remember that GDFS R/W operations must be done with COM interface, and Flash operations must be done with USB interface. were is CRUISER???????? |
03-02-2008, 12:07 | #5 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Cross the power connectors with 3 volts , so positive connector, to negative, and negative to positive, do this for ONLY a couple of seconds, use a phones battery, or if you have ublight, use TP cable. then attach with fighter cable, and repair erom. Hope this helps you. |
The Following User Says Thank You to THE CLASH For This Useful Post: |
03-02-2008, 23:08 | #6 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: ALGERIA
Member: 54116 Status: Offline Thanks Meter: 218 | 100% True great tuto friend u are 100 true Quote:
03-03-2008, 16:39 | #9 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: -Inside RAP3g
Member: 299448 Status: Offline Thanks Meter: 13 | Quote:
br | |
03-04-2008, 09:48 | #10 (permalink) |
Crazy Poster Join Date: Oct 2005
Member: 188545 Status: Offline Thanks Meter: 8 | Hello Dear, cellkeith very nice & great info & help can explane TP CABLE sir. Is it a any special cable for tp ?any info about external tp cable sir. Sir, also what should i do to repair damage errom area K750i cid49 red .try to repair tp method but cell did not boot. Thanks Advance |
03-04-2008, 11:54 | #11 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | The Testpoint cable i was Refaairing to in post, has + & -,, power supplys this is why i suggested this, if you require to boot phone via Testpoint all you need is piece of wire and this must be connected to ground, on phones board,and touch TP when software TELLS you to connect. |
04-25-2008, 18:09 | #13 (permalink) | |
No Life Poster Join Date: May 2006 Location: Bsb, DF Brasil
Member: 283943 Status: Offline Thanks Meter: 124 | W580i DB2020 Cid 52 Quote:
did not work for me... System diagnostics passed. Version 13.02 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Repair EROM --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Sending applet... Phone automatically detached. EROM upgrade works for R3A011 only. N other way to try? B. r | |
04-25-2008, 20:40 | #14 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | what you mean it didnt work for you....?? Your phone is being Read by Cruiser... You cant repair erom on your phone as its a cid 52.... What is Problem with your Phone..?? |
k810i red blink how to revive using hwk | jecams | Sony Ericsson | 1 | 12-05-2009 14:01 |
How to revive a db2020 with gdfs corrupted | moulnisky | SETool2 | 6 | 03-25-2009 12:50 |
Error on stage 2, how to solve. . .??? (K800 Red blink) | kashi4gul | Cruiser Suite | 6 | 02-07-2009 22:37 |
how to revive a dead k800i(no red light blink) Tested | sergio__f | KULANKENDI Server | 0 | 12-07-2007 21:41 |
How to revive 100% dead ME45 and how to tell if it is ba20??? | Genata | x1x to x45/x50 | 2 | 03-01-2004 21:48 |
